Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 06-07-2021, 01:02 PM   #226
biketopia
Re: 63-87 rack and pinion
Rob hasn't been on since October, I would call no limit, they are super friendly and helpful over the phone!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 06-07-2021, 02:10 PM   #227
Skinsman
Thanks for the heads up biketopia! Yes, I can see Rob is fantastic with being helpful & he is the kind of builder I'd strive to be! Amazing guy!
Skinsman is offline   Reply With Quote
Old 12-12-2021, 11:47 PM   #228
tallic68
Active Member
Some of the other kits I’ve seen say they may not or will not work with 5.3 truck low mount power steering pumps. Does anyone know if this kit will work with low mount ps pump on 02 5.3 truck LS?
tallic68 is offline   Reply With Quote
Old 12-27-2021, 03:33 PM   #229
Custom 68
Custom 68's Avatar
I was going to try to get some pictures but with the holidays it has been busy. I will say that I have this on mine and the stock 02 5.3 PS pump clears. I will also say it is dependent on how and where the engine is mounted. Since the rack portion is mounted to the front cross member this location is fixed. The variable is on the engine placement. There are quite a few options that move them up and down as well as front to rear. Some of these variations could lead to some interference with something. I will try to get some photos in the next couple days as I remember mine was close to something but I don't remember for sure.
I had built my own mounts so mine is sitting different than most others out there.
Long story but yes it will work but some checks will need to be made.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-05-2022, 01:38 PM   #230
aggie91
I'm just glad to be here!
aggie91's Avatar
Look through the pictures of "Sunburn" in my signature. I used exactly what you are asking and my set up worked great. Look at posts 258, 259 and another on post 445. I will say this: I built custom engine mounts that moved the engine lower and BACK toward the firewall, but everything cleared and did not have an issue with interference between the engine accessories and the rack or crossmember.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-05-2022, 03:09 PM   #231
tallic68
Active Member
Thanks for the replies fellas. Much appreciated.
