#1 | ||
Re: Rustbuket 67 build "Georgia"
![]() ![]() Quote:
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#2 | |
is it done yet? |
I have a headliner idea that I think might solve two problems in one. Since you have two roofs available you could cut the inner skin on the one being used on the truck to do any rust cleanup and add sound deadener, then cut the inner from the original roof about an inch bigger all the way around and use that as your headliner. It could be attached with sheetmetal screws or captured nuts and some nice "dress up" screws and that would solve your bracing concerns. You could paint it the same color, a contrasting color or upholster and you know it would fit perfect. And the bonus part that is right up my alley is that it wouldn't cost you a dime.
#4 | ||
Here are a few pics!! working the rest of the cab corner, and a lot more to come ![]()
Cut down the front pillars a little longer than what I intend to keep in the roofadectomy, also removed the rear of the cab section from the donor roof.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 07-15-2012 at 12:43 AM. Reason: spellllll |
I finally manipulated the rockers around the top where they did not quite fit the profile of the pillars. I used an old press brake die for motivation
Next up I made a real fancy cab removal jig modeled after some I found on here. I decided to use 2x6 rather than 2x4s for strength as my best friend is overkill and man it worked great! Way too easy, Only problem was my hoist seems to be too tall or the truck was too low so I modified on of the 2x6 ends to clear. Now I am running out of room! it is difficult to do a complete frame off in a 2 car garage.
#8 | ||
Hey Dan, it looks like it is coming along nicely. I did not realize you still had the passenger side of the truck to do. Glad I checked your post. I must have unsubscribed by mistake again. I did not get notified of your updates and I have not been on in a while. Last edited by DD1; 07-22-2012 at 12:29 AM. |
I also used a yellow ratchet strap to anchor the hoist extension to the engine hoist so I would not have to worry about balancing it.
Here she is sitting on a couple jack stands and cinder blocks for the moment. I have to go out to the father in laws and get some round structural steel and make a cab dolly on wheels to move this monster around. I will be removing the engine and trans and trailer the frame out to be blasted and then I will spray some paint and begin assembling the rolling chassis as well as doing more rust repair on the cab. I have parts now stashed all over the garage (obviously), in the side yard, in the attic, and maybe a few hiding in the house! cant wait to start putting a few BACK ON THE TRUCK!!
Hey Dan do u mind looking down in between the inner and outer cab skin and letting us all know how much clearance is in there? Would help me a bunch by letting me know how much space is available for sound deadening. Great process!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
Still Learning
Nice work on the cab Dan.
Posted via Mobile Device |
#13 |
your garage is looking nice and cozy like mine.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#14 |
lookin good man keep up the ingenious work
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#15 | ||
Thanks Mike, I'm a bit slow in this heatwave!!!! Cozy?! ![]() Thanks man, I dont know about ingenious I think I'm more like a slightly skilled boob. I see you have some paint on that truck in your avatar pic. I will have to check that out havent checked in on you in a while. ![]() Okay so I made a cab dolly in 107 degree heat in a shop (no ac)with a lincoln ranger 250 stick welder and I hate stick welding. I think I lost 10lbs in sweat while doing it. It is not pretty just a bunch of leftover construction steel lying around the property at the inlaws. A little angle iron, square tube, rectangle tube, an old hardware store sign frame. I made it 3'x4' x2' tall and used 3" casters from tractor supply. It will get cleaned up later and a steel plate top so I can use it as a work table when I'm done with this truck. Here's the pics! also cut the high hump hole out. I think I will make a couple C channels to weld the nuts to on the long sides and weld those to the underside of the floor. Similar to what they did originally but GM only used a flat strip. Now I can get back to stripping the frame down and send it out to be blasted and begin the chassis assembly.
#16 |
Thanks for that! Cab dolly looks nice. I need to build one myself. Hate the idea of welding or grinding on anything on a freshly painted frame.
#17 |
Master Procrastinator
More quality work and great design on the picker
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#18 | ||
![]() I have been slacking in this heat as I noticed many have on here. It was 112f today!!!! ![]() ![]() Yeah the pics are at night sorry, did I mention it was 112f today? It is miserable working in the garage even at 10 pm when it is 95 degrees! Any way I stripped everything off of the frame except the rear suspension. I removed all the bolts that were attached to the frame and left the trailing arm bolts in. Then picked up the front of the frame and walked it halfway on the trailer, think chariot. Then my neighbor came over and we removed the trailing arm bolts and dropped the rear suspension and shoved the frame the rest of the way on. Then I flipped it over because it wont sit very well right side up. Here are a few pics.
#19 |
Bought a new daily driver too. I will be selling the old one once I fix a few things but it sure is nice to have two trucks! drive one to work and load up a trailer on the other. It is older but low miles and the price was right.
#20 |
Still Learning
Umm Dan, you changed your mind on just getting it running and driving it for a while? I told you to watch out, these projects can get out of hand in a hurry. Before you know it you're right in the middle of a frame off restoration......
#21 |
Smart man getting older DD but low miles! My old Powerstroke I bought when it had 90,000 miles and was several years old but now has nearly 290,000 with virtually no problems. Pay them off quick and drive them forever! Congrats on getting frame blasted !
#22 | ||
![]() Quote:
![]() The "new" one is an '01 with 77k miles on a 4.8l. I am very impressed with the engine. I was concerned it might be a little doggy after owning a 5.3 boy was I wrong this thing has some nuts!
#23 |
Frame is back
#24 |
Got it off loaded into the "cozy" garage. I will return the trailer and pick up some paint and primer in the morning. I also will be taking the control arms, trailing arms, and a few other thing to the blaster next week.
#25 |
Looks like they did a great job on it! Happy for you man. Now go and get some primer on it ASAP
