#226 |
Re: My suburban's Twisted Little Sister
In the nicest way possible, you are a mad builder, and I love this van.
You guys are doing so well. I have soon to start welding and cutting and grinding on my truck. I am sure it will turn out OK, but do hope it gets to a point like your build where I can step back and say "Wow" Looking forward to every update on here.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. Last edited by Grizz1963; 06-26-2015 at 03:01 AM. |
#227 |
Thanks Jon. With all the salt they use on the roads here rust repair is usually a given. On this truck most of what rusted away I don't want any way.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#228 | |
#229 | |
I look forward to watching your progress as well. It must be a lot tougher building a truck there when you're so far from the suppliers
#230 |
Not a lot to post today because we have a pile of welding to finish before we can put the roof on. And welding takes up a lot of time. Here's a couple of spots we got finished.
#231 |
Did more welding and grinding today. We got the pass side B pillar finished. Then we moved to the C pillar to fix the window frame. We cut out the corner then moved it back about 1.5" and clamped it in place.
#232 |
Here's a few more pictures showing the piece tacked in place and some of the finish welding. We just have a small 1.5" gap left to fill.
#233 |
![]() Join Date: Aug 2013
#234 |
![]() Join Date: Jul 2012
Nice fix on the C pillar. I had been looking it over and wondered which way to go to bring it all in line. Love it.
#235 | |
Thanks pimpston. I'm not sure about plastic surgeon but maybe Dr Frankenstien.
here's some shots of the outside finished and the inside almost done
#236 |
Just out of curiosity how long does it take to make the weld in the first pic, just trying to guage how long for metal wharpage. Great job. can't wait to see the finished product.
#237 |
Thanks for the interest Jeff. Tacking that piece in place both inside and out took about 2 hours. A lot of the time between tacks gets used for panel alignment. Patience is the key for sheetmetal welding. For us if it's too hot to rest your bare hand on the weld comfortably it's too hot for the next tack.
#238 | |
#239 |
I wish I had half your metal working skills
Ya... Wait!!! WHAT?!? ![]() |
#240 |
65sub,
I'm really enjoying the step-by-step body surgery pics. Its looking really good.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
#241 | ||
Thanks CShaver. See the link above Quote:
Here's a couple of shots of the drivers side C pillar from Friday and today. We still have some finish welding to do, We also hung some wall art above the shop door. ![]()
#242 |
We spent quite a bit of time today trying to fit the roof skin. The skin is actually wider at the front than the back which makes it difficult to fit on a square truck. so we decided to think about it for awhile. We moved on to making mounting tabs to hold the body to the frame.
#243 |
![]() Join Date: Feb 2015
This build is CRAZY in an awesome way...I'm just 50 mins East of you in Belmont...awesome man!
#244 |
I'm subscribed because there is too much going on that I don't want to miss.
#245 | ||
![]() Friday we welded a bunch of brackets on to connect the body to the frame. Here's a couple of pictures from the passenger side.
#246 |
Yes, I'd like to. It would be my first time attending their show. Maybe a few other local C10 guys would be interested?
#247 |
Bothwell is cool ...yes man my boy plays Hockey against Dresden all the time....
#248 |
This is truly an awesome build. I started on the last page, but after seeing just a couple pictures, decided it was best to start from the beginning. Wow. I can't wait to see how this turns out.
James
'64 C10 Build Officially LQ/NV3500 swapped and Bagged |
#249 | |
#250 | |
We cut out a patch from an old suburban roof then trimmed it to fit.
