Old 04-10-2010, 07:25 PM   #251
OrrieG
OrrieG's Avatar
Re: Lurker OrrieG Progress Pics
Seat frame and glove box door (primed). Wish I could remember how the bottom of the door got beat up.
OrrieG is offline   Reply With Quote
Old 04-10-2010, 07:32 PM   #252
msgross
msgross's Avatar
any extra info on the hard lines from NAPA? part # price? length? I am going the same route on my 68... thanks.. pics of the fuel filter and pump hookup?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-10-2010, 07:45 PM   #253
OrrieG
OrrieG's Avatar
Here is a shot of the filter. I will probably get a braided stainless hose between the filter and pump. Post 246 shows the filter and the fuel pump.
I don't know the NAPA part numbers but they come in lengths from 12" to 72" in about one foot increments. Looking at the photo I need to go out and make sure I put a nut on that bottom bracket bolt!
update: here is a link to the tubing on NAPA's online catalog. The last two numbers in the part number is the length in inches.
http://www.napaonline.com/Search/Det...620_0076392459
Old 04-10-2010, 09:07 PM   #254
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Its lookin good Orrie!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-12-2010, 06:09 PM   #255
OrrieG
OrrieG's Avatar
Thanks. Decided to work on something different. Here's teaser...
Old 04-12-2010, 07:06 PM   #256
Kim57
Kim57's Avatar
looks like a speaker enclosure.
Kim
Kim57 is offline   Reply With Quote
Old 04-14-2010, 01:04 PM   #257
NONHOG
NONHOG's Avatar
Man ! Looking real nice !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 04-14-2010, 01:14 PM   #258
BBEEP
Junior Member
BBEEP's Avatar
Nice detail!
48 GMC Panel Sold 12-14-15
52 White/Chevrolet School Bus
52 GMC Burb/Envoy Meld
61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13
67 c/10 SOLD 2012
71 SS454
77 c/20 Sold 11-11-15
08 TBSS The Wife's car!!
50 GMC School Bus SOLD 11-7-10
29 F**D Delivery (Chevy powered) SOLD 11-4-11
53 GMC 630 Firetruck/Ramp Truck
BBEEP is offline   Reply With Quote
Old 04-15-2010, 03:47 PM   #259
chevynutt58
chevynutt58's Avatar
Thumbs up Re: Lurker OrrieG Progress Pics
I like what your doing. I cant wait to see your motor when its done.I like the original chevy look.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=396157
chevynutt58 is offline   Reply With Quote
Old 04-15-2010, 07:04 PM   #260
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice work on the pod. What's the thickness of the plywood you're using, I tried to make my base for the kickpods using FG but it didn't trun out so good and I thrashed it, so now I'm going to use 3/16" ply if that's available. Do tell what the hole is for?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 04-15-2010, 09:07 PM   #261
OrrieG
OrrieG's Avatar
I am using 3/8" plywood and will ease the edge parallel to the door. Upper hole is for ac outlet. I do not like the underdash holders. I have been collecting interior photos off the web and saw one with the ac outlets on the side. I ran the 2.5" hose and routes ok and keeps the under dash clear. I am going to put a raised bowtie in the space between the ac and speaker pod. First time doing this, kind of like body work put in on, sand it off, repeat until smooth!
Old 04-18-2010, 09:16 PM   #262
OrrieG
OrrieG's Avatar
Photos of the speaker kick panels. One with bondo used to smooth out the fiberglass (short story tried to use matt instead of cloth, did not work), primed and installed. They will be covered with fake leather to match the seats so they are not perfect. Also worked on the glove box lid, started thinking about the speaker/gun rack/ behind the seat enclosure too.
Old 04-18-2010, 10:37 PM   #263
Tri5Nerd
Tri5Nerd's Avatar
Very good idea of wanting to run the AC duct through the pod, how did you route the AC duct? From the bottom? I was also thinking of adding some type of lights to come on when the doors are open.
What's that square hole for?
Tri5
Old 04-18-2010, 11:10 PM   #264
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That will look pretty neat when finished!
Tony
Old 04-19-2010, 12:21 AM   #265
OrrieG
OrrieG's Avatar
Tri5
The duct routes from the top in the dash, there is an existing opening from the dash into the space between the kick panel location and outside of the cab tight against the door pillar. I have thought about lights too in a bowtie pattern, tied to the new door switchs I am adding. The square hole is the stock fresh air intake, air is routed from the grille in front of the windshield, down the passenger side, into the heater box. I had it blanked off, aftermarket ac does not use it. I pulled the plate so I can see how to route the ac and heater hoses for the VA setup I have. I finally figured out that the PO of the system had it ran through tire side of the fender. Current VA setups have hard lines that do a 180 and exit out towards the center of the firewall.
Old 04-21-2010, 12:47 PM   #266
OrrieG
OrrieG's Avatar
Located the VA set up and decided on hose routing. Goal is to keep them as high and close to kick panel as possible. The heater hoses will run in the engine compartment, AC will run on the wheel side of inner fender panel up high to the radiator support then condenser. The pics show the VA hose locations for compariaon, I did not like them right where passengers could be kicking them.
Has anyone here used the Aeroquip EZ connection system for the AC hoses?
Old 04-21-2010, 01:00 PM   #267
sgtusmc
sgtusmc's Avatar
Kick panels turned out great. Hope you don't mind if I copy you someday.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 04-21-2010, 06:37 PM   #268
OrrieG
OrrieG's Avatar
No problem, I probably got the idea from some one else on line. For more ideas go to fiberglassforums.com, I just found them yesterday.
Old 04-27-2010, 03:13 AM   #269
tmoble
Hi Orrie
Darned if you don't look familiar.
tmoble (aka Tom Mobley) looks like you're makiing good progress.
tmoble is offline   Reply With Quote
Old 04-27-2010, 01:23 PM   #270
OrrieG
OrrieG's Avatar
I used to spend a lot of time over at Chevelles.com until I started working on the truck in 07. I keep my gold membership active over there. I also lived and went to school in Tempe at ASU from 74-78.
Work on the truck this weekend was getting the elevator bolts welded in to support the ac unit and pulling the new trans pan to retap and replace the drain bolt I cannot get to stop weeping. Tonight we will see if the fix works. Good news is I landed a side job that is going to buy be some new paint guns and paint I need to get the cab interior and firewall done and the cab mounted. Should also have enough $ to set some seals, etc. Might also get the single piece door glass cut.
Old 05-01-2010, 12:54 PM   #271
BlueBowtie
BlueBowtie's Avatar
Looking really good man.
http://www.cardomain.com/ride/3110793
1951 3100 RCSB
2000 K2500 CCSB
BlueBowtie is offline   Reply With Quote
Old 05-01-2010, 08:16 PM   #272
renegade6
I stole your idea on putting the AC vents on the kick panels.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 05-01-2010, 10:34 PM   #273
OrrieG
OrrieG's Avatar
I noticed that but it wasn't an original idea. I got it from a pic I found online while looking for ac install info.
Old 05-11-2010, 07:56 PM   #274
OrrieG
OrrieG's Avatar
Bump so I can be on top. Last weekend I got the leaky trans pan fixed and installed and the converter cover. Sounds easy but remember I left in the stock second crossmember so converter cover was built in two pieces. Supposed to be nice this weekend so yard sale to get rid of old parts for $ to continue. I feel more body work coming on Sunday.
Old 05-13-2010, 12:17 AM   #275
kustombrad
kustombrad's Avatar
I'm diggin' it! Very cool!!!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
