Old 11-17-2011, 05:24 PM   #251
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project "My Happy Mess"
Hey, where did you get your radiator from? I'm looking for one for my 76 and want to get a good one. I'm leary of buying one from ebay if you know what I mean. Thanks Ryan.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-17-2011, 06:41 PM   #252
litew8
litew8's Avatar
Ebay
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-17-2011, 07:12 PM   #253
litew8
litew8's Avatar
This particular radiator is hard to find, I found. Summit has one for more $$.
If you're not looking for this exact one, there are tons of retailers for aluminum radiators Ryan, right?
Old 11-17-2011, 08:22 PM   #254
litew8
litew8's Avatar
I'll even add for the viewers that I got the radiator from kennysrodandkustom on ebay (99.9% PF).
Summit sells it for $100 more. You could price match it with Summit, but I wanted to give my money to kennysrodandkustom.
Couldn't have asked for better service from Kenny's. Both radiator and retailer are U.S.A..
Old 11-17-2011, 10:49 PM   #255
Dieselwrencher
Thanks for the heads up and I'll check them out. There is so much knock off stuff on ebay any more I'm really leery of giving money out to half of them if you know what I mean.
Ryan
Old 11-18-2011, 02:23 AM   #256
litew8
litew8's Avatar
You're welcome. Any other questions (from anyone) for anything other product PM and I'll try and answer.
Old 11-18-2011, 05:18 PM   #257
litew8
litew8's Avatar
Friday Update - Got a little accomplished.
Parts painted with Zero Rust -
New repro battery tray. Scuffed and painted with a semi-gloss black paint.
Still need to attach this retainer to the oil pan to hold the transmission
lines up, off/away from the engine cross-member.
Soon enough, I'll lay black Hushmat sound deadened on the cab floor.
This is the same brand/material used on today's automobiles. Should be nice.
Old 11-18-2011, 07:22 PM   #258
El Campo
El Campo's Avatar
Serpentine setup off of a late 80s-early 90s SBC? Less than 200 bucks from junk yard with EVERYTHING included and never have a squeaking belt again. Plus that alternator will be 105 amps I think. Just my 2 cents...
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 11-18-2011, 08:00 PM   #259
litew8
litew8's Avatar
No serpentine setup and not spending $200 = $200 in my pocket, and 100 amp alternator. Just my $200
P.S. I've never had a squeaky belt, ever.
Old 11-19-2011, 12:13 AM   #260
El Campo
El Campo's Avatar
You must be a better mechanic than I am then, brother! Haha I have them before at higher RPM no matter what I did I could not get it to stop at high RPM. Good luck though, by all means if that works for you then rock on!
Hook em Horns!!!
Old 11-19-2011, 12:28 AM   #261
litew8
litew8's Avatar
, it's all tension my friend. The bottom side of the alt. belt shouldn't be tight, or at least it should have very "slight" movement when pressed up on from the underside (from 5 o'clock if driver's side).
The extent of my automotive mechanical aptitude is old-school SouthSide (high school) autoshop, metalshop, woodshop and street smarts. Everything else I learned in kindergarten.
Old 11-19-2011, 03:45 AM   #262
VA72C10
VA72C10
VA72C10's Avatar
looking good.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-20-2011, 03:01 AM   #263
litew8
litew8's Avatar
Got the heater box (metal) sanded and painted with Zero Rust Saturday.
Extra - 1979 Mustang Pace Car
(pics for The Pit Boss)
For the viewers: Believe it or not, this use to be one of the fastest/toughest street cars in town back in the day! This might be The Fixer's personal project next (it use to be The Pit Boss's car). The extent of rust damage was a little more than expected.
Old 11-20-2011, 03:52 AM   #264
litew8
litew8's Avatar
Revisiting this picture, just so everyone knows - we're aware that these welds are sloppy It's due to running low on gas for the mig welder.
Old 11-20-2011, 11:29 AM   #265
oldman3
oldman3's Avatar
Litew8, I think you use about as much Zero Rust paint as I did encapsulator paint....Jim
oldman3 is offline   Reply With Quote
Old 11-20-2011, 11:41 AM   #266
litew8
litew8's Avatar
Good morning Jim. I have about 4 cans of ZR left. I have a box of sandblasted parts yet to be paint. ZR is for bare metal so I figure it goes good. If it truly does bond to metal and starve the surface from oxygen - I guess it's well worth it. I like the satin (flat) black look, and it comes in an spray can.
Description / Zero Rust
Zero Rust is a direct-to-metal, phenolic modified alkyd rust and corrosion control coating which puts down an impermeable barrier at the steel level. Zero Rust has two superior traits:
(1) It provides maximum adhesion to steel – this is called chemical affinity.
(2) Its dielectric ability is extraordinary – steel is isolated from the electrolysis process which converts steel to rust. In laymen's terms, this means that if you can starve the oxygen from the substrate, oxidation (rust) cannot occur.
Zero Rust
Can you tell I don't like rust
Old 11-21-2011, 02:19 AM   #267
litew8
litew8's Avatar
Sunday Update -
Didn't do a whole lot today, but I try and accomplish little things
per day even if they're minor. It all ads up eventually.
Decided to paint the heater box and get it out of the way. Scuffed it all,
cleaned off and painted. I went to the local hardware store and picked
up some paint on impulse. Decided a textured paint was needed, so I found
something that I thought would look decent. I thought about spraying black
paint over it slightly to darken it up, but maybe I'll just leave it.
Here are the results.
Before -
After -
This is the product I used.
Then on to hooking up the instrument cluster. I know I mentioned
I was going to connect this the other day, but hey - I'm lazy
First thing I notice after getting comfortable laying on my back
Can you spot what's wrong with this picture? The oil pressure line
is on the wrong side of the defrost vent hose. It isn't going to connect!
I ask myself, why me? And how did THAT happen?!?!
So, to correct it, I have to re-bend the line to the other side of
the vent hose. Wow, that was fun
The outlined light is the original light/wire. I removed the one that
came pre-installed and replaced with the original. This is for illuminating
the shift indicator on the steering column. cool -
Look! @ my work bench Pretty cool huh?
Can anyone guess what these are?
The Pit Boss's engineering from the late 80's early 90's!
Old 11-21-2011, 08:52 AM   #268
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
its for speakers... i think.
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 11-21-2011, 10:12 AM   #269
oldman3
oldman3's Avatar
Like the paint on the heater box....Jim
Old 11-21-2011, 10:38 AM   #270
litew8
litew8's Avatar
Originally Posted by VA72C10 View Post
looking good.
Thanks VA
good eye chevy2racr - 6x9 mounting plate.
Thanks Jim. The Fixer likes it too.
I think we're fitting fenders, etc... today. Or wait? Shouldn't I be wanting to fire the engine? Not sure why we are side stepping the engine now. All we have left for the engine firing is to bolt the torque converter to the transmission, run some electrical wires, replace small sections of rubber gas line, and hook up the electric fan. Thinking about going to the junkyard for a pigtail connector for the fan. I guess I was jumping the gun earlier in wanting to fire it, but not by much.
Thanks for looking all, maybe some pics later this afternoon.
Old 11-21-2011, 04:10 PM   #271
El Campo
El Campo's Avatar
Heater box looks REALLY good! Was wondering what to use on it and it looks like you found the perfect thing! Going to write that one down on my list of things to do
Hook em Horns!!!
Old 11-21-2011, 05:06 PM   #272
litew8
litew8's Avatar
Thanks! I was hoping it turn out with bigger looking specs of white, but it still looks nice. Put it up against the firewall today just to take a look I noticed that it sprays bigger particles when the can is full to half full, and spraying at different angles produces a more rough texture. When the can gets near empty, not so much texture.
Old 11-22-2011, 02:41 AM   #273
litew8
litew8's Avatar
Monday Update -
Took the shroud off to paint.
Scuffed with (red) scotch bright pad, air hosed off and wiped clean with lacquer thinner after.
(I do for nearly everything I've painted)
Here's the connector The Fixer used to affix the fan to the shroud.
Screwed into the shroud. Plastic spacer and rubber washer.
Backside -
And painted. Not too happy with the paint coverage.
Universal Rust-oleum Flat Black with stupid spray away nozzle.
Do yourself a favor and NEVER buy this type of spray can!
It was spitting blobs paint constantly. I might even redo the shroud because of it.
Fitted fenders, cowl and hood. The aftermarket fender fits "ok".
I do not like the top/front end. Where the hood runs along side, the fender
curves to the outside rather than straight or slightly to the inside like the OEM
fender does on the driver's side. It doesn't look great, and I hope it doesn't
mess with the grille alignment. If there's a way to get it to straighten up,
I'd like to try (if at all possible within reason). No picture of that here though.
I'll try and get a shot of it later. It's a Goodmark fender I think.
Should I keep the pinstripe work on the underside nah
Got them "close", but still need little adjustments.
Old 11-23-2011, 03:11 AM   #274
litew8
litew8's Avatar
Close call
Tuesday Update -
We started the day fitting the fenders, hood, rad support and grille surround.
It went something like this -
My worst assumption was right on mark. The aftermarket passenger side
fender (it's a Woodall fender, I was wrong to say Goodmark earlier) didn't align worth a crap.
The part I was concerned with turned out to be a big POS. The whole front of the fender
pulled outward which created huge gap that wouldn't allow us to seat the grille surround,
no matter what. There was no modifying this.
So... off it went and off we go to the body shop.
I was just going to get reimbursed and get the **** out of there, but... it
turned out they had a 1/2 way decent (OEM) passenger side fender. Those
that know, know OEM passenger side fenders (in IA at least) are somewhat hard to
come by since they are notorious for rusting out at the bottom due to battery acid
and/or water damage. This one wasn't too bad, so The Fixer and I nabbed it.
That damn body shop () is lucky I didn't call the The Pit Boss.
Here are some shots of OEM fenders and their perfect (to us) alignment!
I've got OEM grille surround, OEM fenders, OEM doors, OEM hood and OEM tailgate! Sweeet!
(read Made in 1970's USA!)
Does anybody know how long it takes to clean/sand and shine an aluminum grille surround!
Old 11-23-2011, 04:30 AM   #275
VA72C10
VA72C10
VA72C10's Avatar
did you remove the anodizing or just sand? If just sanding I imagine it took hours...
Fender looks good. Hard to beat original sheetmetal.
