Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-24-2013, 02:41 AM   #251
djrickygaz
Re: 66 suburban build
hey Nobby, what are the make and model of those 20'' rims please I really like em! Good job on the build so far!
djrickygaz is offline   Reply With Quote
Old 01-24-2013, 09:04 AM   #252
jmedero
jmedero's Avatar
Nevermind I was wrong.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-24-2013, 10:35 PM   #253
Nobby
Nobby's Avatar
Hey man, There Boss 338 20x8.5...400 bucks shipped to my door- e-bay..
Thanks,
Nobby is offline   Reply With Quote
Old 01-27-2013, 08:12 PM   #254
69 chevy 1
69 chevy 1's Avatar
hey nobby the wheels are sweet,I have the coys on my 69 20x10 and 20x8.5 was wandering if you knew since i dont have my truck on my new frame will a 10 fit under the back of the burbs or maybe even a 22x9 under the rear
69 chevy 1 is offline   Reply With Quote
Old 01-27-2013, 09:50 PM   #255
Nobby
Nobby's Avatar
Well I haven't tried 20x10 yet but I borrowed a 22x9 and it fit like a glove..I aired it out and no rubs anywhere...I just can't remember the back space..
Old 01-27-2013, 10:12 PM   #256
BigCountryx
BigCountryx's Avatar
Wow, u need dat
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 02-01-2013, 04:25 PM   #257
Dinos63
chevy only
Dinos63's Avatar
LOOKS GREAT!! if its a coy it maybe 22x9.5 4" back space i have had a few sets of them, not 100% sure , but 100% sure that you sub is bad a$$
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-01-2013, 06:14 PM   #258
Nobby
Nobby's Avatar
WOW thanks Dino...Anytime you say my stuff looks bad a$$ it makes my chest poke out a little more
Old 02-08-2013, 10:17 PM   #259
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Love it and the colors rock!
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-21-2013, 05:30 PM   #260
Nobby
Nobby's Avatar
Made me a pattern out of 3/16'' plywood for my glass guy to cut me some glass for the rear 1/4..If anyone ever wondered if the forward 1/4 and rear 1/4 glass are the same...Well there NOT..I think the window rubber/gasket is the same but not the glass..
Old 03-31-2013, 09:35 PM   #261
69 chevy 1
69 chevy 1's Avatar
tanks for the window repay nobby you answered my questions on the windows keep up the work im still plugging along
Old 03-31-2013, 10:54 PM   #262
Corts60
Just here to tinker
Corts60's Avatar
Man that burb is one sweet machine.
Feel lucky you are going with solid windows because re-building the sliders are such a pita.
Old 04-01-2013, 08:54 AM   #263
Nobby
Nobby's Avatar
Thanks Cort...I rebuilt my front sliders...My frames were rusted out so I welded in some new channel.Got the rubber kit from Steele..I took on one at a time so I could go back and look at the other..I haven't spayed water on it yet,it might leak like a basket
Old 04-01-2013, 09:43 AM   #264
LT1 Burb
LT1 Burb's Avatar
Originally Posted by Nobby View Post
Got a couple wheels for the front so I can roll this thing back to the shop..Put them on one side just to see..I know I know these wheels are everywhere but its the only set in my driveway
Looks killer so far
LT1 Burb is offline   Reply With Quote
Old 04-14-2013, 11:02 AM   #265
Dinos63
chevy only
Dinos63's Avatar
your sub makes me want to find another sub such nice work
Old 04-16-2013, 08:51 PM   #266
Nobby
Nobby's Avatar
Originally Posted by LT1 Burb View Post
Looks killer so far
Thanks man...It means alot..
Thanks Dino...Come get this one
Old 05-02-2013, 08:51 PM   #267
Dewey Clines
Got the high hump in and all the bad spots in floor fixed today. We also started on the hood.Tomorrow we shooting to finish skinning the pass door,hang it and work on door gaps again. If theres time we'll work on the hood..
Later,
Nobby
Beautiful workmanship! I'm doing a 65 Suburban that I'm doing the Porterbuilt drop and suspension on. I'm at the tear apart stage right now and following your posts with great interest. I'm going to put a BBC 454 with a Turbo 400 and was wondering if the high hump set up is necessary or will the stock hump work. If I need the set up what/where should I look to get one?
Keep the posts coming it keeps me going when the doldrums set in and I wonder why I started all this.
Dewey
Dewey Clines is offline   Reply With Quote
Old 05-04-2013, 11:48 AM   #268
78f1hundo
Hey, can you tell us a bit about your brake setup please?
Thanks!
65' Chevy C-10 Shortbox
78f1hundo is offline   Reply With Quote
Old 05-04-2013, 01:49 PM   #269
Dewey Clines
I didn't want to go through the brake horror stories from my last build using a big cam engine (no brakes at idle), so I went to Tallon Hydraulics Inc. and had them build me a hydraboost system (call Butch and he will help you through the selection of the right unit for your application). He uses a new Wildwood master cylinder hooked up to the booster that is driven off the power steering pump rather than the vacuum set ups. I'm using a NASCAR style power steering pump that I had to make custom mounting brackets for but it gives me the insurance of higher PSI needed to run the power steering and brake units. With this type of set up you also get to use a remote reservior for the power steering which is nice when your running out of space on the motor to mount things. As for the brakes - CPP big brake disk set up front and rear. I also used their modular drop spindles. Porterbuilt is suppling the rest of the drop with their "A" arm coil spring front and mild air bag drop rear. Hope to have all the running gear installed this month then on to the body.
Old 05-04-2013, 01:55 PM   #270
Dewey Clines
Got carried away with the description of what I'm doing and forgot to thank Nobby for the great pics and comments on his build. It has given me some great ideas and got me motivated to finish mine.
Dewey
Old 05-14-2013, 07:32 PM   #271
Nobby
Nobby's Avatar
Thanks guys...We are cranking back up on the burbStarted blocking the liftgate and tailgate..I know it's not much but we gotta start back somewhere..
Old 05-14-2013, 08:08 PM   #272
lolife99
67-72 parts collector,…
lolife99's Avatar
This burb is going to be so nice!
Keith
Convert to disc brakes.
Old 05-14-2013, 09:58 PM   #273
hemifalcon
Yeeeeeeaahhhhh...Getting it purdy Nobby!!!
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 05-14-2013, 10:44 PM   #274
Nobby
Nobby's Avatar
Thanks Guys..I need them 4 access plates for the tailgate..If anyone has an old gate laying around there not gonna use let me know.. Thanks
Old 05-15-2013, 05:55 AM   #275
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
worst case just cut some flat sheet metal to fit them that is all the factory ones are the sub is looking great! keep up the good work maybe it will get me back on mine soon!
gostranger is offline   Reply With Quote
