Old 02-24-2016, 11:08 AM   #251
NastyBuzzard
NastyBuzzard's Avatar
Re: 68 c10 6.5 turbo diesel
Originally Posted by marvgarr68 View Post
Nice! If your go electronic that would be the one to get.
Good to know. Fingers crossed. Supposed to get it for a sweet deal as well.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 03-13-2016, 10:11 PM   #252
marvgarr68
marvgarr68's Avatar
Well got the cab painted finally! I still need to paint bed. Body did not come out perfect but I like it for a daily.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 03-13-2016, 10:13 PM   #253
marvgarr68
marvgarr68's Avatar
More pics.
Old 03-14-2016, 07:16 AM   #254
NastyBuzzard
It looks good in the pictures! Great Job!
Old 03-14-2016, 10:37 AM   #255
marvgarr68
marvgarr68's Avatar
Thanks.
Old 03-15-2016, 07:35 PM   #256
ryanroo
ryanroo's Avatar
looks pretty classy to me!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-15-2016, 09:43 PM   #257
marvgarr68
marvgarr68's Avatar
Old 03-16-2016, 10:33 AM   #258
NastyBuzzard
I finally picked up an engine. It is a 96 VIN F 6.5 TD from a 1 Ton Dump Truck. It turned over fine but wouldn't start on its own. Guy said it was parked due to fuel issues.
I got complete engine, wiring, computer, radiator and couple more goodies for $300. I have pictures on my build thread.
I guess one of my first steps is finding wiring diagrams and information which you seem to have found or worked out considering you rewired the entire thing it seems.
I still plan to pick up another spare 95 engine w/ all wiring and accessories but I would like to run the 96 setup. It has serpentine setup and dual alternators.
Old 03-16-2016, 01:58 PM   #259
marvgarr68
marvgarr68's Avatar
96 is different. That's obd2. I only do obd1.
Old 03-16-2016, 02:20 PM   #260
NastyBuzzard
I didn't even notice. How do I know for sure if it was obdII? I didn't take the plug, I didn't even consider taking it. I don't even remember seeing the OBDII plug. I took all under hood wiring, wiring for the computer that was in the glove box and the wiring for the pedal. I think 96 was kind of interim year for OBDII, right?
So looks like you must be right. All vehicles made after 1/1/96 had OBDII. I wonder does that make it more complicated or less?
Old 03-16-2016, 03:51 PM   #261
marvgarr68
marvgarr68's Avatar
If the ECM was behind the glove box then it is not a 96.
Old 03-16-2016, 04:00 PM   #262
NastyBuzzard
It definitely was there. I have been trying to look up the VIN. Owner stated 96, does it matter it was a 1 ton dump truck?
1GBKC34F3TJ109734 is the vin. I just did a vin lookup and it says 96.
Old 05-26-2016, 11:33 PM   #263
marvgarr68
marvgarr68's Avatar
Update. Truck ran great tell it got 150 miles on it and boom! I was showing off and speed shift while still boosting and stripped out third gear. Scared the crap out of the kid I had with me. It was my mistake as I had tore trans apart once before and didn't reshim it. I got new gears from Tremec that are a little stronger. I shimmed it tight tight this time. Truck now has about 1000 miles on it. Not easy miles ether! First tank got 18mpg second 20mpg I am still on third tank. Truck is pretty quick but will be building a full manual 4l80 for it. Will also be building a new tune for it with every thing we can through at it.
Old 05-27-2016, 03:03 PM   #264
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sorry to hear of the trans issue, but quick fix! I'll tell you, the truck looks awesome! Great work on it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-27-2016, 03:23 PM   #265
marvgarr68
marvgarr68's Avatar
Yea its real easy pulling the trans. I had it out and tore down in an hour. Thanks it has come a long way.
Old 05-28-2016, 04:44 PM   #266
ryanroo
ryanroo's Avatar
Sweet! Already time for upgrades!
72 K20 12v build
Old 05-28-2016, 05:46 PM   #267
marvgarr68
marvgarr68's Avatar
Yep time to see what it will do.
Old 07-10-2016, 08:56 PM   #268
jbclassix
Junk Yartist
jbclassix's Avatar
finally got the 6.5 thread started..... http://67-72chevytrucks.com/vboard/s...d.php?t=708719
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-19-2016, 09:46 PM   #269
deejaaa1
i'm running a full manual 4L80 in mine. gonna get this shifter:
http://www.tciauto.com/tc/fast-gatetm-shifterhtml
looked at a lot of them and seems like the best.
chasing fuel leaks and changing filter faster, relocate the FFM to fender.
for a better connection, do the battery bolt mod.
was really surprised you decided to go electronic.
love the 2 piece crossover. would make it easier to mess with.
truck looks great and runs even better.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 11-20-2016, 03:40 AM   #270
marvgarr68
marvgarr68's Avatar
Thanks. Yea I put stronger gears in it and has held up fine. 4l80 takes a lot of power to drive. I didn't want too lose that's much power. I went electronic because at the time I could get the most power. Now their building pumps that run like garden hoses. It's nice though with cruise and high idle.
Old 12-06-2016, 01:38 PM   #271
quadstar87
I'm just following thru this build that Marv sent me and wanted to clarify a few things since i'm the 6.5L nut.
The oddball injection pump was in 1994 and has DS4-5068 on the label. It's an easy fix in the PROM chip to swap that pump onto any year 6.5. Easy is a term relative to me since I can do the tuning.
Don't let any years of the 6.5 electronics scare you away. I can help out, just let me know and we'll continue these sweet builds!
quadstar87 is offline   Reply With Quote
Old 12-06-2016, 01:41 PM   #272
quadstar87
The 4L80E does take a bit of power to drive but on the 6.5L's it's also a slug due to heavy torque manage settings in the PCM. Slap a 2200 stall converter in and remove the torque manage with an Intercooled Holset, and you are pushing the limit on the torque rating of a stock 80E.
Old 12-06-2016, 03:11 PM   #273
marvgarr68
marvgarr68's Avatar
If the tune you build blows this trans then good! I have a fully build 4l80 full manual I want to swap in. I was originally going 4l80 with manual valve body but could not locate one. I now have tons of them.
Old 12-06-2016, 03:23 PM   #274
marvgarr68
marvgarr68's Avatar
He wasn't understanding me I guess. He want reliability and didn't even now how to tune it.
He had limited knowledge of the 6.5 and the electronics portion. I figured best would be mechanical injection. The 6.5 is a different animal most tuning software will not mess with it. Tuners that know what they are doing are hard to find.
Old 01-30-2017, 11:55 PM   #275
Jeffle93
Could I see how you got your oil cooler lines are ran from the engine? Just put a 6.2 diesel in my 72 c30 4speed winch truck.
Jeffle93 is offline   Reply With Quote
