Old 09-29-2014, 08:44 PM   #251
Kim57
Kim57's Avatar
Re: Project "Schrum" 1959 Gmc 100
Nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-30-2014, 09:20 AM   #252
Custom 68
Custom 68's Avatar
The whitewall looks good on there.
Keep up the good work.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-30-2014, 01:03 PM   #253
SCHRUMGMC
SCHRUMGMC's Avatar
Installed the Petronix ignition kit in the truck the points were a little burnt , and set the timing and made sure everything else was right. Current problems is the truck won't run without the choke. I'm going to go ahead and buy a gas tank soon to install so it'll get better gas flow to the engine.
Awaiting on the hood emblem that I ordered from Ebay, not sure when that will arrive
I am having another rim painted and I will put a new tire on it when I get a chance
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 10-01-2014, 09:12 AM   #254
Nordic
Nordic's Avatar
What happen to the gas tank you bought?
4-10-2014
Today
I Put new fuses in
New Coil
New Thermostat (Learned a valuable lesson, the hard way)
Grounded Brakes lights
Checked out the Gas Tank I bought last week, and am going to get it cleaned and put it back into the truck
Nordic is offline   Reply With Quote
Old 10-01-2014, 11:07 AM   #255
michaelt55
are you buying a stock tank?
michaelt55 is offline   Reply With Quote
Old 10-01-2014, 03:20 PM   #256
SCHRUMGMC
SCHRUMGMC's Avatar
4-10-2014
Today
I Put new fuses in
New Coil
Gave it to DaveCarney it wasn't in savable condition
Yes, I am ordering a gas tank, filler kit and a Fuel sending unit wiring
1971 GMC Sierra
1959 GMC 100
Old 10-01-2014, 08:24 PM   #257
Denee007
Denee007's Avatar
Hey, how about an updated picture of your truck?
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 10-01-2014, 09:33 PM   #258
SCHRUMGMC
SCHRUMGMC's Avatar
No body work has been done, I still have a long way to go
1971 GMC Sierra
1959 GMC 100
Old 10-01-2014, 10:23 PM   #259
lowrodderchev
lowrodderchev's Avatar
gotta love those big back windows
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 10-01-2014, 11:23 PM   #260
Denee007
Denee007's Avatar
That's a nice looking truck! and yes, the big back window
Ok, now for a front view?
Old 10-02-2014, 08:33 AM   #261
SCHRUMGMC
SCHRUMGMC's Avatar
My emblem hasn't came in the mail yet. Excited to get it so it'll look more like a GMC then
Does anyone know where to get those screws that emblems call for? I've lost some of them and I don't think the emblem that I am getting is coming with some
1971 GMC Sierra
1959 GMC 100
Old 10-02-2014, 09:02 AM   #262
Denee007
Denee007's Avatar
That is a good looking truck! Love the larger than life grille!
Having any luck on front a rear windshields? It has side windows, yes?
Old 10-02-2014, 09:15 AM   #263
SCHRUMGMC
SCHRUMGMC's Avatar
Well it has side windows, missing one vent window that I broke on accident WHOOPS!!
I have a back glass for it and will eventually get a windshield
1971 GMC Sierra
1959 GMC 100
Old 10-02-2014, 09:59 AM   #264
Denee007
Denee007's Avatar
Do you plan to paint the truck, or leave it in its present condition, which btw looks awesome, unless there are things about the body unseen by the viewers that you want to fix? Something about seeing a classic in its natural weathered state vs. a pretty truck like mine! You can still use your truck as a truck! Show trucks are somewhat useless for work
I've still been thinking about your idling problem and having to have the choke on or partially on to keep it running? Unless you've remedied that issue. I had kind of the same problem on the original engine in my truck, it was a 230 or 250, but wouldn't idle unless I put my hand over the opening to act as a choke, then it would run. In my case it would up being the carburetor, but I had to eliminate the possibility of vacuum leaks around the intake manifold(it was loose somewhat). Using a can of carb cleaner and spraying to where the intake mating surface to the head can help identify leaks when the engine is running, as it will speed up in idle when carb cleaner is drawn in. However, spray carb cleaner can make its way to the inlet of the carb and give a "false positive", so you have to shield the spray from the carb. I had three extra carburetors, but each of them had issues. Of course that engine was pulled out and an sbc installed.
Another thought and just curious, have you performed a compression test on the engine? It's an easy test.
Old 10-02-2014, 02:39 PM   #265
SCHRUMGMC
SCHRUMGMC's Avatar
I sorta found out why it never wanted to idle, the screw on the vacuum advance was loose causing the distributor to move a little knocking it in and out of time and so on, so when I tightened the screw it was a lot easier to having it running. Only problem I see now is the lack of a gas tank on it causing the gas to swish around and the fuel line not to pick up the right amount of pressure to the fuel pump I assume so. I am currently working on getting the other rim down and with a tire then put them on the truck to give it more of a green look to it than all black YUCK.. I have almost all of the patch panels all I really need now is door bottoms and a front bed panel then I'll have the welding work done to it. I have someone for $200 doing the steps, cab corners and front bottom of the fenders and then will send it to a local body shop to have the rest done on it. Have it sent back home till I get the money to have it primered and painted. This truck means a lot to me so it will be near perfect, no where near a show truck but close.It was originally green as you see in this photo and I hate black, absolutely despise it to the maximum.I plan on painting it original colors, It won't be used like a truck as much
1971 GMC Sierra
1959 GMC 100
Old 10-02-2014, 04:56 PM   #266
Denee007
Denee007's Avatar
That will be a really nice color!
Now as for what you said up above, the fuel pump actually sucks the gas from the gas tank, there is no pressure in the tank itself, no matter how much is sloshes to push it, that being said you could attach a vacuum gauge to the suction side of the fuel pump to see if it's pulling a vacuum, if there is no vacuum, there will be no gas, from there on the other side of the pump is the pressure side. Does this make sense?
dne'
Old 10-02-2014, 05:42 PM   #267
_Ogre
_Ogre's Avatar
i think i still have my vent window glass from when i converted to one piece, i'll check to see
they won't be new, but it will be free
shop air compressor timer
Old 10-02-2014, 07:00 PM   #268
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks Ogre lol !!!
The vent window broke off from the spinning thing
1971 GMC Sierra
1959 GMC 100
Old 10-06-2014, 03:45 PM   #269
SCHRUMGMC
SCHRUMGMC's Avatar
Truck cranked up but the timing is still out of wack.. explains why it chokes down and dies at times
1971 GMC Sierra
1959 GMC 100
Old 10-06-2014, 07:05 PM   #270
BlackedOut67shorty
BlackedOut67shorty's Avatar
Do you have a timing light yet?
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 10-07-2014, 01:26 PM   #271
SCHRUMGMC
SCHRUMGMC's Avatar
Yes. I can't see the timing marks on the flywheel, I've taken a break on the truck to focus on my mg
1971 GMC Sierra
1959 GMC 100
Old 10-17-2014, 03:35 PM   #272
SCHRUMGMC
SCHRUMGMC's Avatar
Changed out one of the tires for the restored original rim
Found a snake as well
1971 GMC Sierra
1959 GMC 100
Old 10-17-2014, 04:01 PM   #273
Kim57
Kim57's Avatar
Rim looks good, not so much the snake.
Kim
My build thread
Old 10-17-2014, 11:06 PM   #274
Daze57
Daze57's Avatar
snake has good taste !!! likin; dem old trucks !
Daze57 is offline   Reply With Quote
Old 10-19-2014, 09:32 AM   #275
SCHRUMGMC
SCHRUMGMC's Avatar
I believe I've finally found the issue with the truck it's not getting the right amount of fuel pressure and it's pulling vacuum from the tank I am using which is a plastic boat tank
1971 GMC Sierra
1959 GMC 100
