Old 01-11-2017, 05:31 PM   #251
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Nice work on the scoop! That metal sure has a mind of it's own once you start placing tacks. It can be a real aggravation. But, you are doing nice work of it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-13-2017, 01:15 PM   #252
daddyjeep
daddyjeep's Avatar
I filled in the corners last night. It took a little finesse, but it wasn't too bad. I am pretty happy with how this is coming out.
[IMG][/IMG]
[IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-13-2017, 01:37 PM   #253
MTCK
MTCK's Avatar
That looks mean! You have some fab skills. I vote tunnel ram for the big block haha.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-13-2017, 02:01 PM   #254
daddyjeep
daddyjeep's Avatar
Thanks, I learn new skills just about every time I walk into the shop. The most important part is that I am not scared to go for it. When I was younger there were a lot of projects that I didn't take on because I didn't know how. Now, I just dive in and see what happens.
Tunnel ram huh???
04 1500 crew cab
Old 01-13-2017, 05:19 PM   #255
87max
87max's Avatar
tunnel ram, got to have hilborn injection!
87max is offline   Reply With Quote
Old 01-13-2017, 07:43 PM   #256
Dieselwrencher
That looks awesome! Is the expanded metal staying there?
Ryan
Old 01-13-2017, 10:17 PM   #257
daddyjeep
daddyjeep's Avatar
I will have some kind of mesh. It will be finer than the piece in the pic and recessed about an inch into the opening.
04 1500 crew cab
Old 01-16-2017, 03:28 PM   #258
whitels1
whitels1's Avatar
Awesome job on the hood!!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-17-2017, 01:32 PM   #259
daddyjeep
daddyjeep's Avatar
Since I didn't do too well at a pool tournament this weekend I ended up getting a little time in the shop. I started the other side of the hood.
[IMG][/IMG]
[IMG][/IMG]
I should get the other side panel in and hopefully the corners tonight.
04 1500 crew cab
Old 01-17-2017, 03:04 PM   #260
tinydb84
tinydb84's Avatar
Hood looks intense! Very cool.
David
Instagram: myfabguy
Old 01-17-2017, 03:42 PM   #261
Dieselwrencher
That is looking very nice! I really like it!
Ryan
Old 01-18-2017, 01:48 PM   #262
daddyjeep
daddyjeep's Avatar
Thanks Guys.
Almost done with the basic shape of things then I just need to place a couple thousand tacks.
[IMG][/IMG]
I need to swing by my steel supplier and see what I can find for expanded metal. I will be using that for the front intake, the rear side cowl vents and probably the grill.
04 1500 crew cab
Old 01-18-2017, 06:10 PM   #263
Jaysonb
Jaysonb's Avatar
That hood is going to be awesome!
Jaysonb is offline   Reply With Quote
Old 01-19-2017, 11:40 AM   #264
Hewfil1
Hewfil1's Avatar
Got kind of a Mad Max vibe to it along with an old WW2 era plane look. That's without paint, regardless, looks awesome!
Hewfil1 is offline   Reply With Quote
Old 01-19-2017, 12:34 PM   #265
Flatline454
I love this build and the concept behind it. Keep up the good work! When you decide to ditch that front bumper, I would be interested in buying it off you.
Flatline454 is offline   Reply With Quote
Old 01-19-2017, 02:07 PM   #266
daddyjeep
daddyjeep's Avatar
I'll trade you the bumper for those pretty green fenders you have.
I am building a bumper, so we can work something out.
04 1500 crew cab
Old 01-21-2017, 09:26 PM   #267
daddyjeep
daddyjeep's Avatar
I got all of the main structure done. Next is building the frames for the screens in the front inlet and the rear vents. I need to go over to a buddies and use his break for that. Of course I just found out my buddy had a hatchet incident at a scouting event today. Hopefully he is up to me coming over tomorrow.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I started cleaning up the back edge. I used some pieces from the donor hood and some generic body repair panels to get the folded edge.
[IMG][/IMG]
04 1500 crew cab
Old 01-21-2017, 11:18 PM   #268
MTCK
MTCK's Avatar
Looks real good. Is the gmt400 in the background another project?
-Marcus
Project Plow Truck
Old 01-21-2017, 11:30 PM   #269
daddyjeep
daddyjeep's Avatar
That belongs to a buddy of mine. Not really a project, just doing some repairs.
04 1500 crew cab
Old 01-23-2017, 03:46 PM   #270
Dieselwrencher
Nice work on the hood. It's looking great!
Ryan
Old 01-23-2017, 08:31 PM   #271
tinydb84
tinydb84's Avatar
I couldn't image grinding all of those tacks...
David
Instagram: myfabguy
Old 01-23-2017, 09:05 PM   #272
daddyjeep
daddyjeep's Avatar
I hear you there. I'm dreading placing those tacks more than grinding them. i did finish welding and grinding one little section tonight. I welded the mounting points for the intake grill.
[IMG][/IMG]
I need to get the inside with a dremel or die grinder.
04 1500 crew cab
Old 02-15-2017, 01:57 PM   #273
daddyjeep
daddyjeep's Avatar
I actually started working on my truck again. Nothing too exciting is getting done, but things are getting done. I finished spraying the floor with undercoating and got back to work on the bodywork on the rockers and corners. This area doesn't have to be perfect as I will be coating the bottom six or so inches of the truck with bed liner. Since I had to patch a couple areas on the side cowl area (whatever that is called) I shot some flat white paint I had laying around on it. I really like how the flat white shows the bends and shadows.
[IMG][/IMG]
04 1500 crew cab
Old 02-15-2017, 08:06 PM   #274
Dieselwrencher
Looking good. Little by little they always tell me.
Ryan
Old 02-17-2017, 11:27 PM   #275
daddyjeep
daddyjeep's Avatar
I found some smaller expanded metal and threw together a screen for the intake. I'm not sure if I like the expanded metal or not, but it will work.
[IMG][/IMG]
04 1500 crew cab
