Old 04-13-2012, 08:36 AM   #276
JML55
JML55's Avatar
Re: My long term 57 project
Nice work, looks great
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 04-13-2012, 05:12 PM   #277
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Thanks!
ChuckDriver is offline   Reply With Quote
Old 04-15-2012, 07:54 PM   #278
shadow1967
shadow1967's Avatar
ChuckDriver, Great looking truck! Would it be possible to get a measurement from the firewall to the back bottom edge of the dash? And what air conditioning/heater unit you used?
Mike
shadow1967 is offline   Reply With Quote
Old 04-15-2012, 08:13 PM   #279
ChuckDriver
Mike, It may take me a few days to get the measurment, I'm trying hard to get my house ready to sale. I have not installed and AC unit yet, will probably go with a Vintage Air when I do
Old 04-30-2012, 09:34 PM   #280
hammerdog57
hammerdog57's Avatar
I just reread your build thread and had some questions. Do you have any more pics of your battery box? Looks stationary. How easy is it to access battery? And last how well does trans cooler work?
hammerdog57 is offline   Reply With Quote
Old 05-03-2012, 09:14 PM   #281
ChuckDriver
Mike
Mike, Sorry for taking so long to get back to you. I measured it today from below the glove box door right under the middle srew at the back edge its 11 1/2 in to the firewall pad. The pad is close to 1/2in thick, so I would have to say that the total measurement would be just shy of 12 in.
I also measured from the top of the speedo to the windshield and it was 10in exactly, but this probably want help as you will more than likely have the glass out when you do it.
Hope this helps and I'll gladly answer any other questions you have, but much sooner next time!
Old 05-03-2012, 09:20 PM   #282
ChuckDriver
I built the battery box after seeing the one in the attached photos. It was real simple to make out of angle iron and some flat stock. The battery will slide out the back when I remove the aluminum top bar thats secured with two lengths of all thread.
Trans cooler seems to work fine, but I'm considering installing one with the built in fan and thermostat from B&M
Old 05-03-2012, 10:47 PM   #283
shadow1967
shadow1967's Avatar
ChuckDriver, No problem. I know moving is B***H. My parents sold there house in only 1 week. Then 30 days to escrow.
Old 05-03-2012, 11:55 PM   #284
Kim57
Kim57's Avatar
Good idea on the box.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-04-2012, 12:22 PM   #285
_Ogre
_Ogre's Avatar
nice fab work
put a jump point on the inner fender or frame (like i don't have, yet)
shop air compressor timer
Old 05-04-2012, 09:11 PM   #286
ChuckDriver
No jump point, but the battery has both top and side posts. So I use a set of the screw in type posts in the ones on the side to contact a battery charger if I need to.
Old 05-20-2012, 10:05 PM   #287
shadow1967
shadow1967's Avatar
How many days to fab the 1959 dash install? I'm hoping to do it in 3 day weekend. Do you think its possible?
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
Old 05-21-2012, 05:18 PM   #288
ChuckDriver
Wink Re: My long term 57 project
It can be done if you have all the tools in place and have a good game plan. And if you happen to have, say a play by play writeup with pic'c, that'll help!! I say go for it, and please post your progress!
Old 05-21-2012, 07:15 PM   #289
ScottRussell
Great truck!!!!
Last post 2009.... Is it done yet?
More pics...
Break
You make any trips to Afghanistan in 2009?
I rode a C-17 with an SC flag in her at some point that year.
And I live up in Fort Mill, SC now... I'm down in Charleston all the time.
Scott
Navy EOD guy
ScottRussell is offline   Reply With Quote
Old 05-21-2012, 08:46 PM   #290
ChuckDriver
Originally Posted by ScottRussell View Post
Great truck!!!!
More pics...
Break
Scott
Navy EOD guy
Scott,
It's still a work in progress. The last thing I've done was install the tubs and wood in the bed earlier this year, other than that I drive it!
I made several trips into Afganistan in 2009, you might have been onboard one of those! Next time you're in Chucktown I'd be glad to show you my 57!
Old 05-22-2012, 08:38 AM   #291
ScottRussell
JJ,
Good deal, i'll let you know next time i am heading that way...
Scott
Old 05-26-2012, 08:17 PM   #292
shadow1967
shadow1967's Avatar
Chuck driver could I get the measurement of your column drop?
Old 05-26-2012, 08:23 PM   #293
ChuckDriver
It will have to be late tomorrow or Monday. I don't keep mine at the house and I'll be out of town most of the day tomorrow, sorry.
But I believe it's a 2 1/2in drop.
Old 05-26-2012, 09:10 PM   #294
shadow1967
shadow1967's Avatar
Where's your emergency lever?
Old 05-26-2012, 10:08 PM   #295
ChuckDriver
I removed it and have not installed another one yet.
Old 05-28-2012, 09:02 AM   #296
ChuckDriver
It's actually a 3 in drop, measuring from the center of the column tube to the swivel point of the mount. And measured vertically from the bottom of the dash down the the same center of the column tube it's 3.5 in. Hope this helps!
Old 05-28-2012, 09:52 AM   #297
ChuckDriver
Here's a shot showing the drop mounted up with a 1/4in spacer.
Old 05-28-2012, 09:55 AM   #298
ChuckDriver
Then I welded in this piece of flat stock to stiffen it up.
Old 05-28-2012, 09:58 AM   #299
ChuckDriver
Then this short piece to tie the dash and coulmn brace together.
Old 05-28-2012, 10:00 AM   #300
ChuckDriver
Here's a finished shot with the 1/4in spacer painted to match the dash and the 3in drop!
I did have a slight gap between the lower edge of the dash and the factory column brace that I filled in with sheet metal.
Hope these help!
