Old 09-16-2012, 01:50 PM   #276
El Campo
El Campo's Avatar
Re: Br3w City's Project omgwtfbbq
Great tip on the welding helmet! I hate that crap with the shields. I just bought one when I was 90 percent done with the boxing of the frame and it already looks terrible and your welds certainly do suffer when you can't see I found out. Interesting concept with the bed floor, I like it.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-16-2012, 03:33 PM   #277
McMurphy
McMurphy's Avatar
I like your innovative bed design !!
I have an idea for mine that will be 45 degrees from normal too
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 09-16-2012, 06:31 PM   #278
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Ill have to see if polishin my lense helps.. I seem to always want my face as close to the fire as possible... Thanks for the tip..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-16-2012, 07:02 PM   #279
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Added my splash guard/gas cap "bezel"
Cut out the old exhaust hanger to make space for the battery box when it goes in.
Mounted the locating studs/locking pins in the battery compartment cover
And finally I started making some of the cheapest bed rails on the planet. I used some sheetmetal connections, I *think* they are called cletes. Its just a 5 ft long flat folded peice of metal. It has 2 metal folds on the back creating a channel. When combined with some flat headed screws, it creates a "slip on" blind trim. No hardware visible. I have a few test fit here to show proof of concept. I will be doing the others, and they will all get ppainted black or body color, after the rest all gets rhino lined. Although they are fairly thin, at under $4 for a 5ft section, they are easily replaceable.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-16-2012, 07:06 PM   #280
FRENCHBLUE72
PROJECT 7DEUCE
I like those cleets???????? Got any more info or bottom mounting pics of them?
MEMBER #6377
Project "7DEUCE"
Old 09-16-2012, 08:10 PM   #281
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
you never cease to amaze me with the cool solutions you come up with.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-17-2012, 12:50 AM   #282
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you look at the 4th or 5th pick, you can see one of the pieces flipped over. Its got a little channel. I installed the flat top screws in the gaps between boards, then slide the trim on from the edge.
I'll take some pics of how its mounted as i lay out the other trim pieces this week.
Old 09-18-2012, 11:39 PM   #283
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Here is some more close pics on the cletes im using for bed trim. The rear has the split, and there are a couple pics of the screws and how the seat.
I started the long trim pieces. A little tougher to slip on because of having to align the piece over 6 or so screws, and it gets tough to slip the trim piece on as it gets further on.
I've got a couple of pics of it going on. And a little progress pic of where I'm at. I should have the others installed in a day or so, then the whole deal gets rhinolined.
Old 09-19-2012, 12:05 AM   #284
McMurphy
McMurphy's Avatar
dude that is awesome LoL !!
Rock on
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 09-22-2012, 02:14 AM   #285
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I decided to spend a few minutes and paint the backing area of the nostrils on the hood. It was blue from the paint job, but the light color made it easy to see in and notice the ugly latch and bolts etc...took 3 minutes but the contrast was nice.
I finished laying out and bolting in the boards for the final time, as well as laying down and securing all the final trim pieces. This is the final layout, and although it looks decent there are a few obvious imperfections. These will soon disappear once the whole thing gets bedlined, bringing the bed together as one visual piece and securing the gaps between the paint work and the bed work.
Old 10-01-2012, 12:34 AM   #286
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not much progress. I've been waiting on some new tires before I can mount the black wheels up, and waiting on a quote from line-x or rhino on doing my bed and rails.
I did have a few extra summit bucks, and since I'm gearing up to do the rest of the hydroboost, I decided to pick up a line lock, since I'll have to mess with the brake lines anyway.
Old 10-09-2012, 01:14 AM   #287
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Actually got something accomplished today! Put in some hard work and finished the center console, aside from the hinges and upholstery/covering. Starting from a crappy cardobaord template, we used 1/2" mdf and table saw to do a good deal of work. We managed to squeeze a pair of 6.5" components with tweeters, their respective crossovers, a 4 channel amp, and a nice little tray so it still functions as a center console.
Old 10-10-2012, 01:38 AM   #288
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Did the finish work on the the center console. Used the same vinyl from everything else to cover the top (along with some 1/2 furniture foam) to create the padded top. Then covered the front and edges with said vinyl. followed by a padded carpet sides. It fits in great, allows access to everything, and still has room in front to slide a cupholder if desired for longer trips. With the new components and amp, the sound is a HUGE change from what it was a year ago.
Old 10-15-2012, 02:14 AM   #289
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
First the SCARY news....on the way home from my 9 hr drive back from Kentucky, the return line on my fuel rail POPPED OFF and pumped fuel onto my warm headers. I was lucky that we had just started to pull off from a gas station, and the engine had been off for a fuel minutes and not at full temp. We shut it down and got the line held back in place, making the remainder of the drive just fine. They need to give me a set of the new design for free, as their product is defective.
Anyway, I did get my powdercoated wheels on in the front (dirty already in the pic). Took a number of pics when I stopped out at Glasgow Ky. I have a number of more HD pics coming from my brothers DSLR when he gets them uploaded.
Old 10-15-2012, 09:01 AM   #290
whitels1
whitels1's Avatar
I dig the console idea, and glad that fuel leak wasn't more of an issue.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 10-25-2012, 03:31 PM   #291
BlackedOut67shorty
BlackedOut67shorty's Avatar
Your truck is bada@#
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 10-25-2012, 05:17 PM   #292
66C06
66C06's Avatar
Brew,
What do your rear tires measure to (height and width)? I'm doing a pro-touring restomod and trying to run and 18x12 on the rear. Just trying to get an idea in my head of how large of a tub I need to put in. Tire I'm looking at is a 315/40-18...
Darryl
66C06 is offline   Reply With Quote
Old 10-25-2012, 05:45 PM   #293
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks guys.
Darryl, my tubs are a bit oversized, but I wanted to go bigger in case i decide to narrow the rear in the future. My rears are 325/50/15 Below is a comparison of our tires, mine is on the left, your 18 on the right.
Old 10-25-2012, 05:58 PM   #294
66C06
66C06's Avatar
Originally Posted by BR3W CITY View Post
Thanks guys.
Thanks for the info!!! A couple more questions...
How wide is your tub?
How much clearance do you have between the outer sidewall and your inner fender AND how much clearance between the inner sidewall and tub?
Lastly how much clearance from the tire to the top of the fender (closest point that would contact if bottomed out)? Thanks for your patience!!!
D
Old 10-25-2012, 07:48 PM   #295
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man, your truck is looking awesome! Great work on it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-27-2012, 01:07 PM   #296
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks diesel.
Darryl,
from the outside of the tire to the inside of the fender, there is about 1.5 finger widths, so about 1". One side has a little more room becaue the PO trimmed the lip at one point.
The inside of the tire has almost 6-8" to the tub if I guessed, tub itself is a foot wide.
There is pretty much no chance of it bottoming out, the old bedside hangs about 1-1.5" into the tub where they overlapped and it was welded, even at that low point there is at least 5-7" room.
For reference, my tub is so tall that it hits the TOP bolt where the fenders bolt onto the bedside. Fully loaded with my brother in the back, there is at least 5" before you'd even come close to touching anything.
Old 10-27-2012, 02:01 PM   #297
66C06
66C06's Avatar
Thanks diesel.
Darryl,
Thanks for the info!!!!
Old 10-28-2012, 12:51 AM   #298
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Got the replacement fittings in. I still can't believe that they didn't recall the fittings that had the issue. Tho for the mostpart they hve worked fine, all it takes is one failure. You can see the zip tie supports as backup as a "just in case". The new ones have a screw in retention so they cant come off.
Old 11-08-2012, 08:19 PM   #299
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not much of an update, just a little outerwear for the truck. I picked up a uv protected single layer car cover to keep her happy over winter this year. Since they don't make a low-cost one for our cars, I hit fleabay and poked around. I found a semi-universal cover for the Infinity/Nissan Midsize SUV's. It is the perfect length, a good height and width and fits over a shortbed stepside very well. It "tents" over the bed, so I can keep spare parts, wheels etc that I want covered in there.
Old 11-08-2012, 09:20 PM   #300
FetchMeAPepsi
FetchMeAPepsi's Avatar
Nice looking cover! Got a link to the seller so I can grab one? (you can PM me if you would rather)
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
