#276 |
Re: New project
Good luck!!
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#277 |
mini truck racer
Re: New project
Had to work nights friday and saturday night . Got home at 5 am and slept til 9 and went racing . I was doing ok until the hamburger at lunch , then i was done . Sunday was better truck and trailer were already their . Slept til 8:30 went out and was last car in 1st time trials . Muscle milk and water only . Got to 7 cars and at leadt paid my tech cards back . Went from 48th in points to 20th in basically one race .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#278 |
mini truck racer
Re: New project
Won the jack pot tonight .
#279 |
Re: New project
So now you need a vertor for the other hot rod you are g
o i n i n g deeper in debt LMAO ... You coming up next week for denton 275 race??
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
#280 |
mini truck racer
Re: New project
No probably not going to make it up their . need to concentrate on this cooling issue .
#281 |
mini truck racer
Re: New project
Update , Added a peice of chromemoly to the core support and cut out the top . This allowed me to cut all the way to the main supports . Got another whopping 2" of room for a 24" radiator now . Going with and electric fan and a moroso water pump drive kit . This will allow me to ut the pump and fan in manual during the run or automatic in the pits and hang a battary charger on it and walk away .
#282 |
Re: New project
HA HA sorry funny I sit in my engine bay to work.. he he
#283 |
Re: New project
When the sawsall comes out you know play time is over and it's time to get serious!
#284 |
mini truck racer
Re: New project
You see the sawzall blades and grinder are out .
#285 |
Re: New project
Oh I see you're done messing around with your overheating issue LOL.
#286 |
Registered Truck Offender
Re: New project
The Luv has a subframe correct? I wonder how mych stability the core support offered to fenders and such. I guess if it starts popping windshields we'll know right.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#287 |
mini truck racer
Re: New project
The Luv has a fully boxed frame from front to rear with 7 crossmembers in it It is stiffer than a full size imo . I did want to brace the core support before removing it . I posted this on another forum and have guy wanting to buy the piece i cut out . Thats how many of them get hacked out .
#288 |
mini truck racer
Re: New project
Here is a factory Luv frame , torsion bar front like a Mopar
#289 |
mini truck racer
Re: New project
Got a bit further today . I have to be ready for the 18th and 19th . Running IHRA in Sealy , Texas . Got the radiator mounter grill tabs welded in and valance cut and water pump installed . Going to set this up with a temp sensor and a on / off / auto set up . This way on the street it is auto matic at the track i will pull in clip the charger on it and when i get back it should be 140 with the battary cjarged . We will see . Here is wher im at , plus new generator for the charge , lights , computer ETC .
#290 |
mini truck racer
Re: New project
Just finished up the larger radiator upgrade . I think it came out good . The hood actually fits better than before . This truck was in a passengerside front wreck at one point in its life . It will idle in the garage for 15 minutes without overheating and will now cool itsself down and cycle the water pump and fan off on its own within about 10 minutes . Here are the final pics of what turned out to be a major upgrade .
#291 |
mini truck racer
Re: New project
Actually been cleaning this up . Pulled the single 14" fan and installed a single slimline 16" fan . Now it will sit and idle all day long at 165 . I am alot happier with it now . It sat in the garage in 90 air with no breeze and never got hot . Thinking i got this beat . Mostly maintaince items . Slicks were bald , paasengerside axle seal , clean up interior . Getting ready for this weekend . We will see . A buddy of mine called me a told me he had a set of slicks that "the sidewall had gone away" these have 6 passes on them . I told hime i get 200-225 out of a set and they work the best at 10% tread left . crazy crappy cell phone vid :
#292 |
mini truck racer
Re: New project
Broke #2 rod coming out of the burnout box as soon as the tires hooked . It found water and filled the oil pan . 36 passes . I beleive it was component failure , as it gave me no signs . Rev limit on the line lock 5500 . Top rev limit is set at 7300 . I was at 6100-6200 coming out of the box and BAM !
#293 |
Re: New project
Well that sucks bad.
#294 |
mini truck racer
Re: New project
The old motor is on the stand and untouched . It had 2 noisy pistons and needed valve springs . The new motor has the same pistons down to the part # . I will probably find 2 good pistons from the wreckage and use the "new" rings with a hone and do a budget freshen up . New inserts , oil pump , valve springs . Probably wont even pull the cam on the old motor . If not finished in time i will run the S-10 on the last few races. If the top end from the "new" motor is salvagable i may try and put it on a 427 dish piston short block .
#295 |
mini truck racer
Re: New project
Well i was wrong #1 exhaust valve dropped for sure . Piston is gone , head will need to be fixed and a rod broke the paasengerside of the block and the pan . Who knows , but machinist wants to tear it apart which is cool , but this is not his fault . It is mechanical failure . Machine work went 36 passes . A valve failed . Photo update :
#296 |
mini truck racer
Re: New project
Photo update. My old motor is torn down and getting refreshed . Iron man Aug 2 and Wally after that . Goals are set the past is gone . :
![]() ![]() ![]() This broke off and went through this : ![]() Causing this : ![]() and this : ![]() My old motor is getting new rings and inserts and going back together with the newer timing chain and balancer . This will be endof season motor and i will start the 2015 season with it . Almost good to have my "W-2" motor back . I call the newer motor paycheck theif , although i won with it .
#297 |
Re: New project
Sorry for your loss!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#298 |
mini truck racer
Re: New project
Thanks , old motor looked good on teardown . Pistons and cylinder walls looked good . Rings and bearings getting replaced . Also upgraded to a beehive spring and retainer . These are surposed to last longer and are lighter at the retainer end to lighten up the valvetrain . Should have the old motor back tuesday . We will see .
#299 |
mini truck racer
Re: New project
#300 |
mini truck racer
Re: New project
Well the big headers leak like crazy on the small motor heads , but it is back together and i drove it enough today to clear out the driver side pipe that was pumped full of oil when it broke . Going to Sealy for the friday jackpot and pinevalley for the ironman challege saturday.
