Old 10-13-2012, 03:46 PM   #276
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: My '67 Fleetside C10 renew
Nice Dude ! glad you went first, hahaha !
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-13-2012, 11:48 PM   #277
jlsanborn
jlsanborn's Avatar
These are gonna suck dude, I can tell ya. There's a bunch of rivets to stake down and none of them are gonna be easy to back up with anything solid. I'm hoping that the jiffy tool is at least half-a$$ decent. That wrap around rubber goes into a "channel" but its keyed (for the lack of a better term). I tried to stuff the old crap back in for a better photo of the tear down and gave up. I can't imagine how fun its going to be to cram the new tight stuff in there! I got those parts cleaned, sanded and primered but not painted. I still don't have the repair kit but I'm hoping I'll see Big Brown early next week! Goal is still to get that cab in epoxy tomorrow! Stay tuned....
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-14-2012, 07:01 AM   #278
XxCHEVYMANxX
Lots of soapy water is the only thing I remember, about getting those in the channel. Hope everything else is goin good ! I'm tuned.lol
you can never have to much info on these vent windows.
John
Facebook LoL
Old 10-14-2012, 07:22 AM   #279
XxCHEVYMANxX
Trying to post a video.
http://youtu.be/mZrnWOJfP5c
John
Facebook LoL
Old 10-14-2012, 11:15 AM   #280
jlsanborn
jlsanborn's Avatar
Yikes! That guy didn't seem all that happy with his results! My rubber is made by Precision. I'm going to browse their sight and see if they have any infor. I wish he said in there what brand he was using. Maybe there is a difference???? The two spots he recommending using regular old pop rivets are the two I didn't take out, but I think we may be able to do that up at the top. I dont think they'd work well in the channel tho.
Old 10-15-2012, 01:26 AM   #281
jlsanborn
jlsanborn's Avatar
Weekend goal accomplished!! The expoxy shows a little more body work I'll need to do though. that front corner on the cab roof is like the end of an egg! There was some old damage there that somebody used a slide hammer to pull out and pucky. I tore all that old crap out and welded up the million little holes and re-puckied. My block did not make that very "egg shape" looking. Otherwise it looks KILLER! I thought the cab was all ready to go, but I spent at least thee hours detailing before I shot the spray glue. Shooting the whole thing inside and out in one shot was a PITA too. Glad I'll finish it in stages.
Old 10-15-2012, 07:14 AM   #282
XxCHEVYMANxX
Yeah, the main thing I liked was the thick metal used as a backer that fit in the channel.
Nice Job on the primer man ! looks good !
John
Facebook LoL
Old 10-15-2012, 08:34 AM   #283
Low Elco
Ha, how 'bout that sticky stuff! Nasty to put on, but it is soo worth it when you get done! Wait till today, when you can handle it! All the work looks pretty good, it'll surprise you when you get the primer on it! "I thought it was straight!" Scrub that dude down with 150 and blast it with 2 good coats of slick sand. Block with 150, and you'll be shocked at the lumps and bumps that show up. I'd also recommend the 3M Rub on guide coat. Kind of a powder that goes on with a pad, and doesnt clog your paper and really shows stuff well. A little expensive but worth it!
Low Elco is offline   Reply With Quote
Old 10-15-2012, 10:55 AM   #284
jlsanborn
jlsanborn's Avatar
Thanks John! Same here on the flat-bar anvil. That looked way easier than putting a punch in a vise and trying to balance that all.
Thanks for the tips Elco! That corner is sooo flat I'll need another bit of filler first! Can't believe I couldn't see that before the primer. So you think 150 is fine enough to lay basecoat on? May also need a little advice on polishing. I shot my vent window frames with that same black and got the same orange-peel results I'm going to pick up some reducer today, sand them flat again and see what happens. If I can't get it to lay flat out of the gun, how would I go about sanding them flat and bringing them back? It's a reduced gloss, or satin finish.
Old 10-15-2012, 11:06 AM   #285
VA72C10
VA72C10
VA72C10's Avatar
Looking very good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-15-2012, 12:17 PM   #286
Low Elco
No no no! Slick Sand is a filler primer. Mud/metal always looks great in primer after 80 block in epoxy. Scuff the epoxy well and completely, edge to edge, with 150. Then lay 2 coats slick sand on. Then block that with 150. You'll be shocked at what the guide coat shows you. Use a long dura block with a nice straight 2x4 taped to the back of it on the doors and bedsides, face of tailgate and hood. Repair as necessary. Recoat with SS and reguide. Block again With 240. If no breakout, wet sand with 400, always on a block. If lots a breakthrus, tap tap and shoot SS AGAIN. Then wet with 400 and shoot 2 coats bc 3 coats clear. Enjoy the adulation of all the ladies in the tri county area. If orange is a problem, a little more reducer and a little more air and a bit further away.
Old 10-15-2012, 12:41 PM   #287
FrankieD
FrankieD's Avatar
Now the fun begins and the race with the weather is on!!
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 10-15-2012, 12:58 PM   #288
Low Elco
Also, I don't think you can polish satin , but I dunno.
Old 10-15-2012, 02:22 PM   #289
jlsanborn
jlsanborn's Avatar
Thanks again! I may be too chicken $hit for the guide coat! I thought I was about DONE with the body work. Will I need to touch it between BC and the CC? Please say no....
Old 10-15-2012, 03:42 PM   #290
XxCHEVYMANxX
No more body work between base and clear.
John
Facebook LoL
Old 10-15-2012, 04:32 PM   #291
jlsanborn
jlsanborn's Avatar
But do I have to scuff it?
Old 10-15-2012, 06:32 PM   #292
Low Elco
Noop, I'll make a bigger post later. Keep shooting.
Old 10-15-2012, 07:18 PM   #293
jlsanborn
jlsanborn's Avatar
That'd be awesome! No shootin tonight tho. Monday Night Football ya know. My goal for tomorrow will be seam sealer on the cab. Any tips there? I'll tape the roof top along the drip rail. On places like the rockers can I just smoosh it with the finger and clean up? Lacquer thinner? Can I sand that stuff off?
Old 10-15-2012, 09:35 PM   #294
butternut1972
butternut1972's Avatar
Looking good!
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 10-15-2012, 09:50 PM   #295
Bomp
Bomp's Avatar
Looking good. What flavor of seam sealer you going to use?
Bomp is offline   Reply With Quote
Old 10-15-2012, 10:52 PM   #296
Low Elco
Here's a pic for you to keep in mind-
Here's how I shoot base/clear. Lay your stuff out/hang it up, leaving plenty of room to walk around, this ain't primer, we don't want any dings here. Blow it all off, and wet the floor. Open a tack rag and spread it open and hang it up to dry out a bit. Crack a beer. Seriously. Put on your gloves.(you got some surgical gloves at the parts house, right? You WANT gloves.) Sip it while you wipe down with a brand compatible wax and grease remover. Strain your materials into the gun. (Ask for Sticks and strainers at the paint store, they're usually complimentary.) Wax and grease again, then tack down. Half the beer should be gone. Shoot your first coat of base. WALK AWAY (completely out of the shop) AND DRINK THE REST OF THE BEER, at the normal redneck rate, about 5-10 min. Come back in and look over your stuff. You should have a fairly good covering medium coat on. Check your edges, look for runs and dirt. If you have runs or big dirt, wet sand them out now with 600 and wipe down just the affected area lightly (lightly!) with wax and grease and tack off. Then tack the whole thing. Most small dirt and dust will go with the tack rag. Ok, if all is well, shoot your second coat, being real careful to get good coverage, and get your edges covered. Mind your edges and be sure to go all the way, ALL the way to the bottom of the body. Walk away and drink another half beer. Re-inspect. If all is well, Mix clear. If not, wet sand it out, clean up and re-base that part. When you're finally good, Load up clear gun. Tack off whole job and shoot. Now, on the first round, you just want a light to medium coat, a tack or scratch coat if you will. Very liberally get your edges. Walk away and drink half a beer. Come back and inspect. Bugs and big dirt can be snagged out with the sticky side of some masking tape, just barely touch the thing you want without touching the part. Runs can be handled the same way. Lay some 1/2 inch tape directly over the center of the run and set it lightly down on it (kiss it) and pop it right back off. Note:This only works when the clear is very wet and freshly shot. No touchie otherwise! If all is well, shoot coat two. Go for a nice, uniform coat this time. Mind your edges and be sure to go all the way, ALL the way to the bottom of the body. Walk away and drink half a beer, slowly. Come back and inspect. No touchie from here on in. Shoot coat # 3. Drink the rest of the sixer while cleaning guns and toasting you success. Enjoy your shiny paint job!
Old 10-15-2012, 11:04 PM   #297
Low Elco
Seam sealer-use the good stuff from the paint store. I used LORD Fusor 800 EZ, and it is. Tape off the roof, and put a good bead in the groove, just like a bathroom. Put on your glove and dip into some lacquer thinner and smooth 'er out. Looks great when done.
Old 10-15-2012, 11:23 PM   #298
Low Elco
Oh, don't forget to have Frampton's "Do you feel like I do?" and some ZZ top Blasting on the shop stereo while painting. This is crucial.
Old 10-16-2012, 12:40 PM   #299
jlsanborn
jlsanborn's Avatar
I really appreciate you taking the time to write that up!
I'll have to check and see what seam sealer I got??? At Napa I just asked for some seam sealer that'll go in my standard caulking gun. It's tan in color I know.
Can I scuff that epoxy with the red scotch brite or should I use the P150?
Why do you use a different gun for clear? Is it a different style of gun or are you just concerned with contamination?
I did pick up a Pioneer tuner last week and it ROCKS!
Old 10-16-2012, 01:01 PM   #300
Low Elco
You should-I'm a shi##y typist! Ha! My seam stuff is tan, goes on buttery, kinda like really smooth brownie batter. Regular caulk gun. If you're gonna prime again, go 150, give it some tooth. If not, red scotchbrite. I use the same gun, base and clear, a Sharpe Finex. The tip is A little big for base, a little small for clear. Pros will have multiples for speed. I've seen six guns loaded at a time, swappin' 'em out. A pro clear gun will also have all the air and fluid passages hogged out in it, running like a 2.0 tip. It's like welding Aluminum, you better be movin' when you pull that trigger, and haul azz once you're flowin'! I'm a cheap azz, I just clean mine good and blast away. I shot 90% of Boppa's with it. Tony let me use his old Iwata LPH 400, and it was niiiice. It's hard to paint with a chubby, but I persevered! BTW, if Momma ain't out in the shop gripin' about the noise, you need a bigger stereo, Hoss. Just some MO redneck guidelines.
295/50-15, 327, butternut yellow, dog dish, muncie m20
