Old 09-04-2013, 07:39 PM   #276
Xeen
Xeen's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
That toxic orange pearl is radical man.
coughoverachievercough
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-04-2013, 07:50 PM   #277
bguild
bguild's Avatar
Yes the color looks great- good choice. It is going to look great all painted that color.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 09-05-2013, 08:50 PM   #278
Vic1947
Vic1947's Avatar
I'm a bit behind my self imposed schedule for the Nats, but I should be able to make it with a few minutes to spare. The rest of the engine is pretty much done. I say "pretty much" because there are several things I need to revisit after the show. Two main issues are the poor quality rocker arms and the intake gasket / bolts for the Vortec heads. I'll have to fixture up the rocker arms and run a ball end mill into the pushrod dimples to clean out the casting flash they left in some of them. Pretty sloppy manufacturing there. Also found out that the fiber gaskets with the silicone print-o-seal are junk. GM quit using them because they're affected by oil and antifreeze and develop leaks. They replaced them with a plastic and rubber sandwich design that is far superior. Got a set on the way and will have to remove the intake after the show and replace what I have on there now.
The Speedway center bolt adapters worked perfectly and blend in with the polished aluminum valve covers such that you barely notice them. Engine is ready to drop in first thing tomorrow morning, so I should have time later to tidy up a few things before the show. Gonna be hot!!
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 09-05-2013, 08:58 PM   #279
sduckworth13
sduckworth13's Avatar
Looks classy Vic.
Scott
sduckworth13 is offline   Reply With Quote
Old 09-05-2013, 10:49 PM   #280
Low Elco
Better hustle- picked up the trailer and cleaned the grill tonight!
Low Elco is offline   Reply With Quote
Old 09-06-2013, 07:05 AM   #281
Xeen
Xeen's Avatar
Wow very nice Vic, the engine looks badass! Major points for artistic on this one.
The aresenal of fasteners on the stainless table made me chuckle, you could have your own retail store Vics Fastenal.
Yeah those rocker arms are pretty terrible, that's gotta be hard on pushrods, imagine all the thousands out there installed left that way and people have no idea.
Crap like that is the reason we need to bring manufacturing jobs back to the USA.
Old 09-06-2013, 08:47 AM   #282
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice job on the engine, looking great!
--Josh
Old 09-06-2013, 08:47 PM   #283
Vic1947
Vic1947's Avatar
OK, I've done all I can do for the Nats, so the plan is to load up early tomorrow and hang out with the similarly afflicted till I'm sunburned and full to the top with BBQ. As always, there was a contest of wills between man and machine, with both scoring points. Driver side header wouldn't fit and it took two hours to repair motor mount threads that I should have chased when I bolted them on. But I keep reminding myself, the amount done is not relevant. Being there is the goal. See you all tomorrow.
Victor
Old 09-06-2013, 09:25 PM   #284
Xeen
Xeen's Avatar
It looks great Vic, you can have lots of fun telling people it's going to be your beater and see their reactions
Old 09-10-2013, 02:55 PM   #285
Vic1947
Vic1947's Avatar
Since the block hugger header wouldn't fit on the driver side, I was forced to modify either the header or the pedestal (or buy new sheetmetal ones from CPP). Decided the pedestal mod was the most attractive option, so after marking the outline of the header tube where it was resting on the perch, I windowed the area and made a reinforcing saddle to weld in the hole. Now have plenty of room for the header and you don't really notice it from above.
Still waiting on the GM Vortec intake gaskets. Once they arrive I'll be able to button up the engine. Meanwhile, I have some machining to do on the rocker arms. Will post up when they're done.
Victor
Old 09-10-2013, 03:40 PM   #286
bguild
bguild's Avatar
Very nice Vic.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 09-10-2013, 05:08 PM   #287
69CST-V
69CST-V's Avatar
Just saw this build and quickly scanned all the pictures. Looks like I found tonight's reading. Nice build.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 09-11-2013, 06:20 PM   #288
gdavis
gdavis's Avatar
I like the way you did the motor perch. You do good work man. I see now why Brian xeen is alway braging on you. Good luck man.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 09-11-2013, 07:18 PM   #289
Vic1947
Vic1947's Avatar
Originally Posted by bguild View Post
Very nice Vic.
Thanks everyone! With the truck show in the rearview mirror, I'm in cleanup mode. The rocker arms proved to be even worse than I remembered. Ran a 5/16" ball end mill into the pushrod dimples and then polished them with a Cratex abrasive on the Dremel. The worst one (shown, before and after) still has some porosity in the pocket. There was also another one that had a serious casting flaw near the roller tip. Contacted the eBay seller and one of their service reps said to call their tech line to see if I could get them replaced or maybe exchange the set. Probably not since I modified them, but, what the heck, I'll call tomorrow and see.
Received the GM gaskets for the Vortec heads and they were very nice. They're already installed, so I should be able to set the distributor in tomorrow and install the senders, plugs and etc. At that point, I'll be out of reasons for avoiding bodywork.
Victor
Old 09-16-2013, 04:44 PM   #290
Vic1947
Vic1947's Avatar
Found a useful way to avoid bodywork by sorting out the brackets needed to mount the accessories. The Vintage Air setup came with it's own bracket whose placement was non-negotiable, so I started with it. First thing I ran into was the mounting tab meant for the front intake bolt. Since I'm using Vortec heads, the tab was at the wrong angle and position. The solution was to relocate the tab to the upper inner hole on the front of the cylinder head. Out came the bandsaw and welder and presto-change-o, I now have a tab at 90 degrees to the original. The Vortec intake bolts have a max torque of 15 ft. lbs. so using that boss was a non-starter.
Next up was the alternator. Since the AC compressor now occupies the space where Sparky originally sat, the most convenient fix was to rotate the alternator 180 degrees so the adjuster bracket was on the bottom instead of the top. This meant I had to fabricate an adjuster, which I did by slicing off the curved slotted portion of the top bracket and scabbing on some material so it would mount on two bosses protruding from the water pump. I haven't decided if I will keep it as is or machine one from some billet stock I have laying around. We'll see.
Lastly, the power steering pump needed some fine tuning. I remembered from when I took it off there was a funky spacer involved and a bracket that didn't seem quite right. Sure enough, the bracket was for the stock AC compressor and its only purpose was as a 1/4" spacer for the top hole of the PS pump bracket. When assembled like the PO had done, there was no provision for the third hole used to triangulate and steady the pump. So I removed the bracket, sliced off what I needed, put a slot in it for adjustment and made two spacers to properly line up the pulley groove with the drive groove on the harmonic balancer. It's now solid as a rock.
All that remains to be done is remove all the brackets, detail the edges, etc. and take them to Detray Plating to be chromed. While they're out, I'll paint the alternator and PS pulleys the body color and the PS pump the engine color. Will post up pics when it all goes back together.
Victor
Old 09-16-2013, 05:16 PM   #291
Xeen
Xeen's Avatar
A little Vicineering and you were back in business, great job.
Old 09-16-2013, 06:13 PM   #292
El Campo
El Campo's Avatar
Like Frizzle Fry says "Its just metal"! Looks like you came up with a good solution.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-17-2013, 05:23 PM   #293
Vic1947
Vic1947's Avatar
Today was one of those "good news, bad news" days. The good news is that KMJ Performance let me return the Procomp rocker arms that were riddled with casting flaws and gave me a store credit. They also discounted the 4340 chromoly set I'm getting as the replacement. Those guys rock!!
Bad news was the sway bar doesn't fit very well. It may require a trip to Sedalia where I have a buddy with a massively powerful hydraulic press to tweak the bends. Hopefully we can bend it to fit without killing ourselves. As you can see from the photos, when the bar is in place, the ends that attach to the a-arms are too far apart. Another possible solution is to move the whole bar forward a couple of inches which would allow an acceptable fit at the a-arms, but then the frame horn mounts will be way off. I may just do that and call it good. Decisions... decisions...
Victor
Old 09-17-2013, 06:07 PM   #294
sduckworth13
That's what I did when I did a 4 1/2 front drop on my 67 GMC. I moved the sway bar forward and removed the frame mounts for the sway bar and just used the brackets that came with the bushings to mount the sway bar to the frame. But I like your idea about bending it to the correct angle to fit.
Scott
Old 09-17-2013, 06:42 PM   #295
Vic1947
Vic1947's Avatar
I mocked up the forward position for the bar and it actually looks pretty decent. When I ran into this problem on the silver truck, the fix was much easier. I only needed to move the ends inward about 3/4". These would need to move a full 2" inward to allow the frame brackets to use the holes already in the frame.
Were there any side effects from moving the bar forward, Scott?
Victor
Old 09-17-2013, 07:43 PM   #296
Xeen
Xeen's Avatar
If the company that manufactured the sway bar claims it will fit in the factory mounting locations on a 1968-72 c10 then it's the mounting location on the tubular control arms that are wrong, reguardless it puts you in an akward situation.
Old 09-17-2013, 07:48 PM   #297
sduckworth13
Vic, It tighten things up considerably, the steering and handling was amazing.
Scott
Old 09-17-2013, 09:36 PM   #298
Low Elco
I hope so, that's the plan for LBT! Work looks great, as always.
Old 09-19-2013, 04:15 PM   #299
Vic1947
Vic1947's Avatar
Sway bar is ahead 2-0. After relocating the front brackets, the angle where the ends of the bar mount to the a-arms is way off. With the hardware pulled up tight, the driver side poly bushing is steadily pushing itself out of its bracket. At this point, either the front brackets have to be seriously lowered via spacer blocks or the ends have to be bent upward to match the angle of the a-arm pads. I am retiring to the living room to watch TV and drink beer.
Victor
Old 09-19-2013, 04:21 PM   #300
Vic1947
Vic1947's Avatar
Actually, a guy with a mill could build a pair of 15 degree wedges to fit under the U-brackets to correct the angle of the dangle. Stay tuned...
Victor
