Old 10-28-2014, 09:53 PM   #276
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Project "Schrum" 1959 Gmc 100
I'm looking to get another seat cover, I want something like this
Anyone know where I can find something similar?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 10-29-2014, 06:55 AM   #277
47 Fasttoys
47 Fasttoys's Avatar
Is the center section a different color? Not sure if this was a factory option or a DIY job.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-29-2014, 08:56 AM   #278
SCHRUMGMC
SCHRUMGMC's Avatar
Years and years of where people had their back
1971 GMC Sierra
1959 GMC 100
Old 10-29-2014, 11:20 AM   #279
Daze57
Daze57's Avatar
try a good auto upolstery shop - they should be able to match it or at least come close
Daze57 is offline   Reply With Quote
Old 10-29-2014, 01:37 PM   #280
_Ogre
_Ogre's Avatar
why not get your truck running better and glass in all the openings before worrying about the upholstery?
fyi, the timing marks are on the front of the motor, not the flywheel
shop air compressor timer
Old 10-29-2014, 01:41 PM   #281
SCHRUMGMC
SCHRUMGMC's Avatar
Then why is there an opening in the bell housing? Mine is a Inline 6
I just wanted to get a clue on how to get something like that seat cover
I'm currently getting my MGB running and going so I've put the truck off for a while but I should be back on it soon !!!
1971 GMC Sierra
1959 GMC 100
Old 10-29-2014, 01:58 PM   #282
_Ogre
_Ogre's Avatar
dooh! yes it is.
rotate the motor by hand until you see the mark and paint it white
Old 10-29-2014, 03:22 PM   #283
SCHRUMGMC
SCHRUMGMC's Avatar
Its painted orange, I just can't see the timing marks. I believe mine is -5
1971 GMC Sierra
1959 GMC 100
Old 10-31-2014, 10:28 PM   #284
SCHRUMGMC
SCHRUMGMC's Avatar
What is a reasonable price for welding?
Both Steps
Both Cab Corners
Both Front Fender patch
Both Door skins, bottoms
Fabricating metal to fix the small rust holes around the speaker, cowl vent area
1971 GMC Sierra
1959 GMC 100
Old 11-05-2014, 04:56 PM   #285
OrrieG
OrrieG's Avatar
The seat cover looks like an upholstery shop made it. Aftermarket guys have replacements you can install, or a local shop could make one using that as a pattern if its what you want.
Welding cost is subjective, best to get bids locally. I ended up doing all of mine because the best price I could get locally 10 years ago was $250 per patch panel (labor only), welded in and ready for final body work. that was for cab corners, eye brows, hinge pockets. I would expect steps and floors would be more because of the work to brace the cab and more fitment, making sure the doors align right, etc. The guy was basing it on $50 per hour shop rate. Other places would not do the piece work, they wanted the whole body work job.
OrrieG is offline   Reply With Quote
Old 11-07-2014, 10:51 AM   #286
SCHRUMGMC
SCHRUMGMC's Avatar
Well I'll see what I can do with this welding thing. I bought a Lower bottom Door skin yesterday and next time I am going to buy a the right door skin and a hinge pocket
1971 GMC Sierra
1959 GMC 100
Old 11-26-2014, 10:34 AM   #287
SCHRUMGMC
SCHRUMGMC's Avatar
The tailgate has been sandblasted and is getting ready to be painted
The letters will be painted white
1971 GMC Sierra
1959 GMC 100
Old 12-02-2014, 06:05 PM   #288
SCHRUMGMC
SCHRUMGMC's Avatar
Early Christmas present for me
Stainless Steel tailgate chains
Tailgate Chain covers
Tailgate Hinges
Soon to also be the tailgate repainted and other two rims done
1971 GMC Sierra
1959 GMC 100
Old 12-02-2014, 10:22 PM   #289
Kim57
Kim57's Avatar
Nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-03-2014, 03:18 PM   #290
OrrieG
OrrieG's Avatar
Shiney! I always used old bike inner tubes for the chain covers. If they do not have it put a small hole at the bottom of the bend to drain off water and condenstation.
Old 12-14-2014, 10:25 PM   #291
RanchTruck
The center of the filler cap on the plastic boat tank should have a little knob. Loosen it and the knob unthreads from the cap, which opens the vent for the tank. That should fix your pulling a vaccum in the tank issue. I've got a lot of vehicles running on boat tanks.
Ogre, you really shouldn't keep giving ignition advise if you're not familiar with the straight six's. The whole distributor body is rotated by the vacuum advance, so the cap and wires twist with it as the vacuum advance moves it around. That's normal in this case. It's not like a distributor body held down with a clamp bolt and only the breaker plate being moved by the vacuum advance, the whole distributor is being moved to accomplish the same thing.
RanchTruck is offline   Reply With Quote
Old 12-14-2014, 10:44 PM   #292
SCHRUMGMC
SCHRUMGMC's Avatar
I've messed up the Timing on the truck by removing the spark plug wires to help set the Distributor where it needs to be according to other truck owners of the GMC 270 engine I'll figure something out sooner or later, the tail gate is still in the shop getting fixed so I hope it will be done this week sometime
1971 GMC Sierra
1959 GMC 100
Old 12-16-2014, 04:18 PM   #293
SCHRUMGMC
SCHRUMGMC's Avatar
Uncovered more rust under fiberglass
1971 GMC Sierra
1959 GMC 100
Old 12-16-2014, 04:58 PM   #294
Kim57
Kim57's Avatar
That sucks.
Kim
My build thread
Old 12-16-2014, 08:20 PM   #295
OrrieG
OrrieG's Avatar
If its there check the front eyebrow above the windshield and A pillars where there meet the top, usually ones leads to the other. Good news is the inner and outer cab pieces are repoped. Go back thru your earlier posts, I remember guys giving you the instructions on how to R&R and wire the distributor.
Old 12-16-2014, 09:27 PM   #296
SCHRUMGMC
SCHRUMGMC's Avatar
No clue how it gets to this point...mice or what...Mind boggling
I've wired the distributor, just no clue on how to set the timing and where it needs to be, it won't go there and if it does it pops and spits
1971 GMC Sierra
1959 GMC 100
Old 02-14-2015, 01:51 AM   #297
Softpatch
Softpatch's Avatar
I subscibe to this thread....Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 03-03-2015, 04:20 AM   #298
SCHRUMGMC
SCHRUMGMC's Avatar
I recently got my Grandfathers '74 Volkswagen Beetle back from a neighbor. So until I pay my Grandmother off for the bug I will continue my projec
1971 GMC Sierra
1959 GMC 100
Old 03-03-2015, 09:20 AM   #299
Kim57
Kim57's Avatar
Nice bug.
Kim
My build thread
Old 03-04-2015, 01:51 AM   #300
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks Kim
1971 GMC Sierra
1959 GMC 100
