Old 08-02-2023, 09:55 PM   #276
gsinon
Re: Long Time Coming......
Originally Posted by Hey Dude View Post
No worries. It's almost impossible to insult me. I too HATE tape lines. Soft-Masking is different and I have had plenty of vehicles in the World of Wheels shows over the years. I promise you my soft edges rub right out, invisible.
It sounds like you know what you are doing when painting parts how they hang. Your method is a lot less work, as long as you don't scratch anything.
I agree the soft edge makes a huge difference. Like I said, I'm gonna give it a go my way. If when I bolt it all together I see a difference in the panels then I'll scuff and shoot. Fingers crossed I don't have to though.
Glenn
1951 3100, Area51
1955 BelAir, 4EVER17
1987 R10, Ethel
Copper Hill Rod & Custom
http://67-72chevytrucks.com/vboard/s...d.php?t=829856
gsinon is offline   Reply With Quote
Old 08-03-2023, 08:17 AM   #277
Rickysnickers
Originally Posted by gsinon View Post
However I do have some skills swinging a spray gun. It must work, I won Best Paint at the 2019 Detroit Autorama (800+) and two weeks later at the Cleveland Autorama (900+) car shows competing against the very best.
Wow!! Outstanding!!!
Old 08-03-2023, 09:30 AM   #278
gsinon
Thanks. At the end of the day those awards really mean nothing. I regret sharing that as I never want to come off as someone that brags on what they've done.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-03-2023, 08:22 PM   #279
daveshilling
daveshilling's Avatar
Yes, now that you've mentioned it a single time, we all think very poorly of you
Someone's opinion of you is their problem, and none of your business.
daveshilling is offline   Reply With Quote
Old 08-04-2023, 08:19 AM   #280
Rickysnickers
No, they actually mean, you know what you are doing and do it well!!! That's not bragging!!!
Old 08-04-2023, 11:31 AM   #281
dsraven
it does, however, mean you are now the go-to guy for ANY paint related questions. haha
good for you on the trophies. i won't tell anybody. lol.
Old 08-04-2023, 09:35 PM   #282
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Man that does look nice. Since you are tightening up all the contact point/gaps on the body, I have seen someone create a panel, well more like a winglet to close the cap between the front panel of the bed and the rear od the cab. Sort of where the bolts that attach the bed side to the front panel are. They contoured a flat panel that followed the edge of the cab, with about an 1/8-1/4 inch gap to the cab. It was subtle but got rid of that gap you can see from the side.
GreasyLikeaBurger is offline   Reply With Quote
Old 08-16-2023, 02:55 PM   #283
gsinon
I appreciate that. I am super proud of any awards, publicity or notoriety I have received in my career and or hobby. I try not to make it sound as if I am bragging about any of it.
I'm always up to give paint advice. I worked for PPG as a training instructor up until 2020 when due to Covid they closed several training centers. I loved that job.
I guess there are many ways to get this done. Below is how I went about it this week. I didn;t get super crazy closing the cab to bed gap as this will be a driver and don;t want there to be any issues ever of them coming in contact due to chassis flex. Although I would like to think that boxing the frame and the X member it will have little flex now.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-16-2023, 03:10 PM   #284
gsinon
It has been a couple weeks since my last post. I've been working on the truck here and there and also getting things done at home before going back to work next week.
In this update you will see how I installed the pop up fuel car and made a filler tube that connects to the tank.
Here are all the items used to do this. The pop up cap, a band clamp, a 2.25" mandrel bend, and some 2.25" fuel hose.
I had to cut this access for the fuel hose, and then installed the hose.
I made this little template of the contour of the cap to find the best location to weld it in the fender.
The reason for the band clamp is so I have an easy way to service the tank or remove the fender and not have that long of a tube and its weight hanging on the fender.
At first I just tacked them together.
Once I got the full tube routed as need the pieces were all tacked for a trial fit.
Happy with it I final welded the pirces together. Had to make sure everything was sealed with weld so no leaks.
Looking up you can see where things need to connect. I then tack welded the filler to the fender from the top also.
I then bolts everything together using the V band clamp prior to final welding. Once happy I finished welding the filler to the fender on the top side.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-16-2023, 03:24 PM   #285
gsinon
I spent some time working on the gap between the cab and bed. I am only closing this as much as the top is from my earlier project. While it is only an inch I think it made a significant change.
Before....
I am using the same 1/8" rod as I did previously, here I am just mocking it up to get an idea of how it will look. In doing this I decided to heat up and then bend the bottm end to meet up with the filler panel.
This is what I ended up making. It is 1" wide. I welded the round stock to the leading edge as I did on the other panels at the top of the bed.
And here it is tacked into place.
Over all I really like how it cleaned up that gap. It's not drastic, but I think it is a big improvement overall. I still have to make the other side and get it tacked in place. Everything will get final welded when the bed comes off and is on a stand for easy access.
New labor subtotal.
7.17 hrs
502.55 total
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-16-2023, 03:35 PM   #286
57FleetsideC4
It looks really nice with the fuel filler where you put it. Lots of time fitting everything up. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 08-16-2023, 07:38 PM   #287
-Dan-
-Dan-'s Avatar
You make it all look so easy!
-Dan- is offline   Reply With Quote
Old 08-18-2023, 04:11 PM   #288
gsinon
Thanks. Measure 100 times and cut once, and still not right. Lol
It's all smoke and mirrors! It really isn't that hard if you have some basic fabrication skills and the right tools.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-18-2023, 04:25 PM   #289
gsinon
Todays project was to fix the filler panel between the running board and bed. I cut a slice in it and pushed the metal where I needed it. I then put a tack weld on to hold the shape. I then took it off and final welded the gap.
This shows it with welds ground. It is a tighter gap then appears, but also not pushed as far back against the fender as it could be.
While I had it off the truck I formed a piece of metal and extended the leading edge for a better flow.
And since I was in the area I finished what I started last week, that being the stake pocket. I'm not a fan of the way they just stop. So I extended it and rolled it in towards the filler panel. The question then became what to do about the two half round reveals (body lines). Do I continue them? If so how? Or do I just stop them?
I've seen where people have done this modification before, and every time other than once, people have extended the lines. So me being me and wanting to be mildly different I measured from the top to the bottom and made a cut line. When I formed the extension pieces and welded them in I then welded closed the two hald round reveals. I then ground the welds rounding the bottom off as well. At the end of the day I like it, it's different. And for me that works.
And with the filler panel installed...
4.37 hrs today
507.17 hrs subtotal
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-22-2023, 07:37 AM   #290
gsinon
Still working away on the running board. This time the fitment to the front fender. I have always wondered why the factory didn't connect the leading edge of the running board to the fender and instead thought this huge gap looked right. Most other year body styles and manufacturers connected the dots. So me being me decided I wanted to make them connect.
As it fit before I started...
I then cut a slice on the leading edge of the board and pulled it forward until it touched the fender. I also drilled a hole and bolted them together but used a washer in between to create a slight gap. I also welded on a piece to extend the area some.
I decided this would be much easier to do if I made the filler pieces in multiple steps.
At that point ai took the running board off the truck and put it on my welding table. I made the remailning filler pieces and welded everything solid. I wish now that i took some pics at this point, but I got so wrapped up in what I was doing i forgot.
This is now bolted back in place with all the welds ground. This is just roughed in and still needs some finesse work, but you get the idea.
Time for this job, 3.6hrs
New subtotal, 510.77 hrs
At $50 per hour, that would be $25,538.33
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-22-2023, 08:00 AM   #291
6DoF
6DoF's Avatar
damn dude, the attention to detail on the fit is amazing
6DoF is offline   Reply With Quote
Old 08-22-2023, 09:24 AM   #292
dsraven
great job. you're right, those parts should have been connected at the factory for a more blended look.
Old 08-26-2023, 08:02 PM   #293
gsinon
Thanks guys. I love doing this stuff! I've been having so much fun out in the shop this summer. Play time is now over, I start back to school Monday. Now back to slower progress.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-26-2023, 08:17 PM   #294
gsinon
Every once in a while I have those days where it feels like nothing got accomplished. Today was definitely not one of those days. I got so much done, some of which I didn;t take pics of though.
I started and finished the the front left stake pocket as I had previously done on the right side. I also took the filler panel off and extended the front leading edge as also done on the other side. While at it I made the filler piece and rod that goes from the top of the bed to that filler panel to match what was done on the other side. This was to fill that unsightly gap between the bed and cab.
You've seen pics of all that already from the right side, no sense on posting more pics covering the same mods.
Once all that was done I turned my attention to the two rear stake pocket bottom ends. I measured and figured out where I wanted to end and then start the roll inwards. I made a template out of posterboard and marked front and back of both stake pockets for the radius I wanted it to be trimmed to.
I then cut across at the line I had already determined and then trimmed the bottom edges to match the radius.
At this point I got so busy doing things I didn't take pics as I was working. Here however is the pieces with all the welds ground. This still needs some finessing.
You might also notice that I plug welded the holes where all the bed parts normally bolt together. I am welding this solid into one piece.
Time today, 5.57 hrs
Subtotal, 516.33hrs
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-27-2023, 10:20 AM   #295
Rickysnickers
Very nice! One question, will there ever be a possibility of moisture getting in there? Would it be worthwhile to add a small hole for drainage purposes?
Old 08-27-2023, 04:00 PM   #296
gsinon
I definitely plan on drilling a coupole small drain holes on the bottom once I remove the bed.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-27-2023, 04:12 PM   #297
dsraven
What about if you cut a small groove on the edge that fits against the box wall. That small divot would leave a gap that would look sorta natural and also be a drain that would pass water, tree needles, etc. I would recommend shooting some weld through primer into the void to prevent rust. High zinc.
Old 08-27-2023, 04:20 PM   #298
gsinon
Before welding all the pieces together I spray weld thru primer on everything. Once I'm done painting everything I will run a long wand down the hole and spray 3m cavity wax really thoroughly. That will coat everything and protect it all from any moisture. The OEM's do this at the factory inside frame rails and such.
Glenn
1951 3100, Area51
1987 R10, Ethel
Old 08-27-2023, 09:06 PM   #299
dsraven
if you were to extend the lower flap of steel so it goes inside the edge of the lower valance, and provide enough of a hole for water to drain through into that area, the drainage would all happen behind the valance so the hole could be large enough to do the job but would be un noticed. just a thought, dunno what you have for room back there.
Old 08-28-2023, 01:32 PM   #300
Hey Dude
I hope you don't regret solidly mounting the runningboard on both ends. Same goes for the tight gaps between the cab and filler. Unless your frame is EXTREMELY stiff and rigid you could get rubs, squeaks and cracks.
Hey Dude is offline   Reply With Quote
