11-17-2008, 04:05 PM | #301 |
Re: Crewcab build
CHEVY ONLY |
11-18-2008, 06:36 AM | #302 |
Re: Crewcab build
thats lookin awesome!!!! dont worry, my cat ate my mem card!! i know how it feels... lol
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
12-04-2008, 11:57 PM | #303 |
Re: Crewcab build
Been slowly making progress, just spent the better part of last week taking alot of measurements and cutting all my pieces. 3x3x1/4 wall box tube is not fast to cut on the chop saw, especially when you make bonus cuts the wrong way.
Anyway, here is my new frame clip that should drop inside the exterior frame rails this saturday: Last edited by PrerunnerRob; 12-04-2008 at 11:58 PM. |
12-05-2008, 12:17 AM | #304 |
Re: Crewcab build
hooray!
pics.....well, um.... PIC anyway
CHEVY ONLY |
12-05-2008, 12:23 AM | #305 |
Resistance is Futile
Re: Crewcab build
Anybody notice Joe's post count is going up as fast as the national debt clock?
Sorry Prerunrob.....kick butt job....maybe joe could send you a camera for X-mas!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-05-2008, 12:31 AM | #306 |
Re: Crewcab build
CHEVY ONLY |
12-05-2008, 12:31 AM | #307 |
Re: Crewcab build
I know I'm bad about using the camera, I just hate to stop when I'm on a roll. I am charging my camera now, am bringing it on Satuday, and WILL actually take pictures. Promise! |
12-05-2008, 10:23 AM | #308 |
Hollister, CA.
Re: Crewcab build
Uh huh...FAMOUS LAST WORDS !!!! 1/4 wall huh...you must be towing with that thing too.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
12-05-2008, 11:00 AM | #309 | |
Re: Crewcab build
I actually thought I grabbed 3/16" at Sims, but I looked later and found the side I measured had gotten smashed at the end where I measured it. 8 places to check wall thickness, and I pick the one that is undersize! I may not be towing with this, but it will still serve duty hauling my dirtbike and quad. |
12-07-2008, 12:02 PM | #310 |
Re: Crewcab build
As promised, here are pictures from yesterday.
Here is how it started My friend George showing me how to blow off rivets heads with a torch, without melting the frame around it Frame clip anyone? After cutting, you can see my marks of where the frame clip should go. Prepping the frame for initial fitment of the clip, I squared everything up, and then slid the clip into place. |
12-07-2008, 12:04 PM | #311 |
Re: Crewcab build
Oooh, thats nice! Level, square, and no trimming required! The plumb bob shows axle centerline to a mark on the floor I made from the stock frame.
Close up of the fitment After checking fitment, I marked all of my cut lines for the remainder of the frame from the clip. I cut off all of the remianing pieces I needed to, and throughly cleaned off all of the metal that would be welded. I had my shop-mate Mike weld the sections together, his welds are much prettier then mine, and he welds ever day for a living. I clamped the sections together, checked everything again for level and square(it's within 1/32 on the diagonals), and let Mike rip on the welding! |
12-07-2008, 12:04 PM | #312 |
Re: Crewcab build
Done! Actually, I have to weld the lottle window in the side of the frame, grind down some of my welds on the notch, and I'm going to grind the underside corners flush. Here are some after pictures. So, I actually came through with pictures this time. Amazing! I need to now mount my 4 link, figure out my crossmembers, and get this thing back to rolling! |
12-07-2008, 12:09 PM | #313 |
Re: Crewcab build
Nice!
your pics are worth the wait!
CHEVY ONLY |
12-07-2008, 12:15 PM | #314 |
One day...
Re: Crewcab build
Awesome work on the balkhalf man!
12-07-2008, 12:31 PM | #315 |
Re: Crewcab build
Nice welds. Thats a quality job your doing
12-07-2008, 12:33 PM | #316 |
One day...
Re: Crewcab build
Ill be counting now
if this forum didnt have pics it would be like a "some certain magazine" without pics! Worthless!! Ill support ya dude Last edited by scotts62; 12-07-2008 at 01:19 PM. Reason: typo |
12-07-2008, 12:42 PM | #317 |
Re: Crewcab build
Thanks for the compliments guys, I'll keep posting pictures as I make progress.
12-08-2008, 01:00 AM | #318 |
60-66 Nut
Re: Crewcab build
That turned out real nice.....and the welds are nice as well. Did you make up the link bars? I am curious as to why threaded ends on both ends.
12-08-2008, 01:07 AM | #319 |
Re: Crewcab build
Bought the 4 link from FBI(local truck vendor at shows), and thats how it came. Both ends are RH thread too, which I thought strange, but it was $180 with all the brackets. I assume it's to get a little more adjustment length out of it, but I'm not totally sure.
12-08-2008, 04:10 AM | #320 |
Re: Crewcab build
Very nice!
12-08-2008, 09:46 AM | #321 |
Hollister, CA.
Re: Crewcab build
Looking good man.....How are the cabs coming...rrrr...I mean the cab coming ?
12-08-2008, 11:01 AM | #322 |
Re: Crewcab build
Good, I started runing into allignment issues with the bodies on a stand. I figured the best way to make sure they will be straight would be to place then in their final position on the frame. I need to pick up some body mounts, and bolt them back down to the frame.
12-08-2008, 12:10 PM | #323 |
Custom Truck Lover!
Re: Crewcab build
very very nice welds. you are a PROFESSIONAL. I wish my welds looked that nice. What do you do for a living?
Are you going to box the rest of the frame? Last edited by YOLO; 12-08-2008 at 12:12 PM. |
12-08-2008, 12:33 PM | #324 |
Re: Crewcab build
PrerunnerRob:
I would say Mike should do the welding...those welds look like TIG welds. Pretty sweet, considering they are MIG. Very nice work you guys are doing. I can't wait for the next round of pictures. |
12-08-2008, 12:36 PM | #325 |
64-66 CHEVY JUNKIE
Re: Crewcab build
Them welds are killa man i love that back half, looking good rob..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
