Old 08-02-2010, 10:15 AM   #301
Tow Me
Glen
Tow Me's Avatar
Re: How about some pics of '73-'91 Crew Cab Short beds?
Sounds nice!
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 08-05-2010, 05:04 PM   #302
puppy
puppy's Avatar
This thread should be made a sticky with all the others!!!
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
Old 08-05-2010, 05:34 PM   #303
joe231
joe231's Avatar
I've tried.
there isn't enough traffic for it to become a sticky
CHEVY ONLY
Old 08-06-2010, 02:08 PM   #304
JohnC
JohnC's Avatar
Not for a lack of trying though.
JohnC is offline   Reply With Quote
Old 08-06-2010, 05:57 PM   #305
joe231
joe231's Avatar
Name:  crew lowering 012.jpg
Name:  crew lowering 004.jpg
Name:  crew lowering 013.jpg
CHEVY ONLY
Old 08-06-2010, 06:09 PM   #306
BGRAFX
Showoff
BGRAFX is offline   Reply With Quote
Old 08-06-2010, 06:12 PM   #307
joe231
joe231's Avatar
CHEVY ONLY
Old 08-06-2010, 06:27 PM   #308
b454rat
I posted pics somewhere, but dunno where they went???
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 08-06-2010, 06:36 PM   #309
joe231
joe231's Avatar
Very COOL!!
CHEVY ONLY
Old 08-07-2010, 04:53 PM   #310
(541)COLD_beer
(541)COLD_beer's Avatar
heres mine
(541)COLD_beer is offline   Reply With Quote
Old 08-09-2010, 10:33 AM   #311
scotts62
One day...
scotts62's Avatar
Wow thats cool!
Scott
93 crew cab build
Project 62
Old 08-10-2010, 10:20 AM   #312
CHEESE
The Cheesiest
CHEESE's Avatar
Originally Posted by joe231 View Post
looks like its ready to roll down to the open house/shindig!!
Lookin good!!
CHEESE is offline   Reply With Quote
Old 08-10-2010, 12:22 PM   #313
joe231
joe231's Avatar
Thanks CHEESE!
when is the open house?
All these badass 4x4 CCSB's are giving me an itch....don't think the wife would be too happy if I scratched it though
CHEVY ONLY
Old 08-10-2010, 01:39 PM   #314
CHEESE
The Cheesiest
CHEESE's Avatar
Sept. 11th! Ill post the flyer when i get it! Bring that beast!!
Old 08-11-2010, 06:59 PM   #315
kevinr1970
Do you know appx. how much drop you ended up with?
Also, what size tires are those? I read the last few pages of your thread and it mentioned 255/70-15; wondering if those in the picture are that size. They fill the wells nicely.
Truck has a good stance!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-11-2010, 07:33 PM   #316
joe231
joe231's Avatar
Cool!
I'll have to see what's going on then
Thanks man!
I don't know for sure how much drop I got.
It has 3" spindles on the front and one coil plus cut off the springs.
I swapped to 56" springs in the rear with 5 leaves at the same time I did the flip. The 88-98 diff has slightly taller spring perches.
The frame was only 1-1 1/2" above the axle tubes so I flipped the rear spring hanger upside down and raised the reab back up @ 2 inches to get it where it is now. I still need to cut the front bump stops down and put some notches in the rear so it won't bottom out so easily. Down the road I'm either going to bag it or convert to 4x4....I haven't decided yet
Maybe I'll run across a 4x4 crew for cheap before that though, fingers crossed
CHEVY ONLY
Old 08-11-2010, 10:35 PM   #317
str8axle55
That truck is bad azz, perfect lift and stance....I want one.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 08-11-2010, 11:53 PM   #318
kevinr1970
Thanks man!
Tire size?
With the 3" spindles, how much did you have to trim off the LCA's to get the 8" rally's to clear? I have removed more material than I am comfortable with on one side already and as I was finished with that side (so I thought), I relized when I put weight on the front wheels the LCA will probably make contact again.
So I need to put the jacks under the the LCA's to simulate it being on the ground and see if I need to remove more material.
I have chrome rally's and was hoping to run the weights on the inside but I don't think that is possible now.
Mine is flipped in the back also and without the bed on the truck and no shocks, I can bounce up and down on the frame and get it to hit the axle.
So a notch is going to be put on before I install the bed.
2000 Tahoe Limited
Old 08-12-2010, 07:13 AM   #319
joe231
joe231's Avatar
Tire size?
Oh, sorry
255/70/15 all around
As for the lower arms, I'm not sure. The spindles were on the truck already. I can take some pics of the lower arms if that might be helpful.
CHEVY ONLY
Old 08-12-2010, 01:23 PM   #320
kevinr1970
Oh, sorry
If you happen to be doing something already and can get a picture that would be great, otherwise don't go to any trouble.
I knew I would have to remove material with the 3" spindles when I started, but it still makes me nervous!
2000 Tahoe Limited
Old 08-12-2010, 08:18 PM   #321
grayharville
^^who I am^^ what I say>
grayharville's Avatar
seeing all these, really makes me want a crewcab!
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 08-16-2010, 09:02 PM   #322
joe231
joe231's Avatar
Cleaned her up a bit
CHEVY ONLY
Old 08-16-2010, 10:00 PM   #323
texasfunk
texasfunk's Avatar
if you come down here, bring it to the shop and LETS SPRAY IT!!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 08-16-2010, 10:01 PM   #324
bjcaldwe
bjcaldwe's Avatar
Nice Joe. When is the open house out in west Texas?
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 08-17-2010, 10:10 AM   #325
CHEESE
The Cheesiest
CHEESE's Avatar
Sept. 11th i should have a flyer today!
ccsb crew cab short
