Old 08-06-2010, 11:23 AM   #301
68 TT
Still plays with trucks
68 TT's Avatar
Re: LS1 into a 73 cheyenne
Originally Posted by smokedat View Post
I will start on the bed tubs this weekend. The inner dimension if i recall are 14" and i will extend them out 8" to 22" . 18" for the tire plus 2" clearance on each side. So i decided to go with Mickey Thompson for the wheels HR-1 One-piece rotary-forged aluminum wheels on the front 18x6 with a 26X8 R18 tire on the rear 20x16 with a 31X18 R20 tire. I will completely redo the rear end with a 4 link triangular from ridetech with stainless arms with ridetech adjustable coilovers. For the rearend I will go witha Ford 9 inch or maybe an 8.8 95+ Ford Explorer since they they come with dics brakes it comes down to wich I can get ahold of first. Front suspension will stay as is for now eventually i will hook it up with new top and bottom tubular arms with adj. coilovers.
I will make sure to photograph all this
Any input on this will be apreciated
You can narrow the 8.8 pretty easily as they have two different axle lengths. You just grab a second short axle at the wrecking yard and swap it out for the long one in the rear end you buy. Once you get it home just cut down the axle tube on the long side to match the short side and you now have a narrowed rear end on the cheap. Strong axles, great availability of good posi carriers & gears. This is really popular to do in the S-10 world as the shorter rear end fits the S-10 perfectly.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-06-2010, 05:10 PM   #302
kvn1011
Kvn1011
kvn1011's Avatar
nice wheel choice!!
kvn1011 is offline   Reply With Quote
Old 08-06-2010, 11:06 PM   #303
82chevy350
82chevy350's Avatar
This truck is looking amazing
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 08-08-2010, 02:12 PM   #304
smokedat
smokedat's Avatar
so i got ahold of a bed i had to cut it in half to load and transport it in my S10. First step of many in operation Fat Tire
smokedat is offline   Reply With Quote
Old 08-08-2010, 04:13 PM   #305
aggie91
I'm just glad to be here!
aggie91's Avatar
Very nice build! Looks like I will stay tuned in for the rest of the build.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-10-2010, 12:14 AM   #306
smokedat
smokedat's Avatar
I started cuting the tubs. A complete tub measures 11" and i added 9" plus 3" from he bed give me a total of 23" . The tire is 18" so i will have 2'' clearance in the front and 3" in the back since i want to tuck i need all the clearance i can get. i still need to seam the 2 halfs together, at that point i will cut the floor form the donor bed and transplant that extension to final bed.
Old 08-10-2010, 12:16 AM   #307
smokedat
smokedat's Avatar
full shot
Old 08-10-2010, 12:54 AM   #308
smokedat
smokedat's Avatar
Quick scetch of dimensions
Old 08-10-2010, 01:25 AM   #309
smokedat
smokedat's Avatar
Plan for the floor. Cut the curve out from main bed keep straight piece. attach piece from donor bed main objective is to keep the original curve with the bolt patterns.
Old 08-10-2010, 08:53 AM   #310
mcbassin
Still Learning
mcbassin's Avatar
Looks like you have the tubs all figured out. I will be watching this transformation for sure. That is going to be some big rubber underneath there!
mcbassin is offline   Reply With Quote
Old 08-10-2010, 12:02 PM   #311
kvn1011
Kvn1011
kvn1011's Avatar
Old 08-15-2010, 01:50 PM   #312
smokedat
smokedat's Avatar
I got the tubs almost finishd i had to add a center strip to keep the original shape. I welded the bolt hole section by placing it on the the bottom of the bed heres a few pics
Old 08-15-2010, 01:52 PM   #313
smokedat
smokedat's Avatar
floor cut outs and completed tub
Old 08-15-2010, 05:09 PM   #314
SatisTraction
damn!! that is WIIIIIIIIDDDDDDDDEEEEEEEEEEE
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 08-15-2010, 07:13 PM   #315
mcbassin
Still Learning
mcbassin's Avatar
Nice fab work! looks good!
Old 08-16-2010, 11:31 AM   #316
68 TT
68 TT's Avatar
Looks great. Keep up the good work.
Will you have to do any mods to the frame to use the new width of the tub?
Old 08-22-2010, 05:51 PM   #317
smokedat
smokedat's Avatar
update The fab work on the bed is complete -were the tubs bolt on to, some minor body work was required. The tubs are still cokin i got 1 finished and primered heres are a few pics
Old 08-22-2010, 05:56 PM   #318
smokedat
smokedat's Avatar
low res pics with my phone of the process bare metal to the muddin to primer shot with direct to metal then feather fill
Old 08-22-2010, 09:18 PM   #319
mcbassin
Still Learning
mcbassin's Avatar
Looks great! keep it up! man those tires are going to be WIDE!
Old 08-23-2010, 05:46 AM   #320
menace121978
menace121978's Avatar
nice progress!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-23-2010, 04:28 PM   #321
82chevy350
82chevy350's Avatar
Looks real good
(Hot Rod)
(Daily Driver)
(Toy)
Old 08-24-2010, 09:44 AM   #322
ERBSIX
ERBSIX's Avatar
Wow. Man, you're a pro!
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 09-02-2010, 01:18 AM   #323
smokedat
smokedat's Avatar
I ordered my MT HR 1 wheels and tires today from Summit they only make these in a 5 on 4.50 or 5 on 4.75 so i ordered the 4.75. For the rear i will ordered a 4.75 bolt pattern and for the front i might just use an adapter. i wil set the rear tires in for a moch up and get a measurement from back side of wheel to the other back side measure and order my housing and axles cut to size. For the center section i will use a track lock posi with 3.70 gears 31 spline with a 1050 yoke. not sure about the brakes yet, all i know is that they will be disc.
Old 09-02-2010, 01:21 AM   #324
smokedat
smokedat's Avatar
thanks, i put about 35+ hrs in the tubs and bed.
Old 09-02-2010, 11:27 AM   #325
68 TT
68 TT's Avatar
With 5 on 4-3/4 bolt pattern you can run Vette or Camaro brakes. 98-2002 F-body rear disc is really popular and are 12" diameter with an internal drum in hat parking brake. They even came on the 6-cylinder cars of that era so they are pretty easy to find. I got a complete set with e-brake cables and the brake hard lines for under $100 on ebay. Since you are having the housing narrowed you can just have them put on the Strange small GM housing ends while they are at it so stock Chevy car brakes will bolt right on and you still get the press-on bearings & retainer plates.
You could turn a stock rotor into a bearing hub, drill it for 5 on 4-3/4 and use Vette or Camaro slip on rotors up front. Many size options from 12x1.25" on up. You could fab up a caliper mount bracket to use the matching PBR calipers up front or run the Wilwood D52 calipers at all four corners.
73c10, c10, cheyenne, ls1, swap
