Old 07-04-2010, 03:11 PM   #301
greg65
greg65's Avatar
Re: Project: Recycle
If I were closer you would be welcome to use the glass as a template.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 07-04-2010, 03:35 PM   #302
greg65
greg65's Avatar
I traced both glasses out on a roll of packing paper. If you want I can ups them to you Tuesday.
1965 c-10 swb
2004 tahoe
1993 mustang gt
Old 07-07-2010, 10:48 PM   #303
SCOTI
SCOTI's Avatar
Back glass is back in..... No pinched rubber on the outside of the glass but you can see where he had to mash the piss out of it to make it fit. That being said, both bottom inner corners are still pinched/protruding out. I think I'm going to order a different brand rear window seal.
I have been working on my gauge cluster & just about have it complete. Not exactly perfect but it will work for now. I'm going to have a new lense-panel made from aluminum as I feel it will ultimately be stronger (I was trying to re-use as much of the original idiot light cluster as possible). I'll post up some pics once I get them off the camera.
Greg65....
If the offer still stands for those templates, I'm interested.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-07-2010, 10:49 PM   #304
Detroitcustoms
Originally Posted by SCOTI View Post
I'm not sure if they were trying to tell each other something in this pic or if they were trying to tell me something .... Either way, 3M panel bond adhesive was used.
No i was tellin u @ $55.00 per tube x2......
Detroitcustoms is offline   Reply With Quote
Old 07-08-2010, 05:00 PM   #305
SCOTI
SCOTI's Avatar
Ok, this is basically what I started with. A generic 'idiot light' cluster.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:04 PM   #306
SCOTI
SCOTI's Avatar
I taped up the lense & played around w/the possible placement of 2x 3 3/8" & 4x 2 1/16" gauges. Not much room so you're kind of limited when trying to make things 'look' right vs. an eye-sore....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:15 PM   #307
likaroc13
Rollin' Old Skool
yeah, of all the styles i've seen using aftermarket gauges, that layout really looks best to me
Old 07-08-2010, 05:18 PM   #308
SCOTI
SCOTI's Avatar
My plan was to re-use as much as possible from the original housing. I gutted what would no longer be needed & started tweaking from there . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:23 PM   #309
SCOTI
SCOTI's Avatar
Once everything was trial fit, it came back apart for changing the lense's appearance & more aggressive clearancing of the OE housing for the deeper speedo/tach. This is what was trimmed off of the OE cluster housing (tin) & all the discarded internals....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:31 PM   #310
SCOTI
SCOTI's Avatar
I kept the original turn signal tubes & made another to match for the high beam indicator. The turn signal indicators are in the stock location & the high beam indicator was moved between the large gauges (not drilled yet).
I did .250" holes for the indicator lights after measuring the dimensions of the OE turn signal indicator 'arrows'....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:44 PM   #311
SCOTI
SCOTI's Avatar
I sanded/DA'd the lense w/some 80 grit & wiped it down w/degreaser. I used some Rustoleum 'Stone Creations' rattle-can texture finish that I picked up @ my local Home Depot. It gives a nice texture (like trunk spray/zolatone); but the texture is a little more aggressive.
I tried the standard 'wrinkle finish' rattle-can stuff but it requires everything to be just right when applying to get the 'best' finish. With this stuff, it's spray & go. I then used VHT's rattle-can epoxy 'satin black' as the top coat (I also sprayed a couple of coats on the back side of the lense).
Overall, I was able to use the original housing parts & saved myself some cash. I can always go w/an aftermarket set-up if desired since this was just some time/effort. I included a close-up shot of the texture & one of the turn indicators.
Next will be sandblasting the outer bezel & a fresh coat of VHT epoxy....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 05:51 PM   #312
joe231
joe231's Avatar
That Looks very Cool SCOTI!
great idea!!
CHEVY ONLY
Old 07-08-2010, 06:10 PM   #313
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I agree, nice job!
Alan's Classic is offline   Reply With Quote
Old 07-08-2010, 06:21 PM   #314
VA72C10
VA72C10
VA72C10's Avatar
Nice work and I really like the SW gauges over many of the other options out there...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-08-2010, 06:40 PM   #315
TimE
Hey Y'all!!
TimE's Avatar
Nice work!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 07-08-2010, 06:57 PM   #316
SCOTI
SCOTI's Avatar
Thanks guys! I figured the idiot light cluster wasn't worth anything (to me) & I had to do some cleaning/detail painting to the bezel anyway so.....
I think the SW gauges offer the best compromise: 'new' gauge accuracy w/enough 'old school' appearance. They definitely work for this project.
I'll be painting the glove box door & door panels in a similar way to help tie things together on the interior. Tannish interior; black gauge cluster, glove box, & door panels w/a little texture for contrast; black arm rests, black steering column/wheel, & black 80/20 loop carpet. The seat frame is even PC'd satin black .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2010, 08:10 PM   #317
Detroitcustoms
You need to run that cluster over and well paint the outer bezel to match dash ?????
Old 07-08-2010, 10:48 PM   #318
bubba327
HOW long until spring??
bubba327's Avatar
love the dash idea .. I found a glove box door at the pick a part yard and wondering about kinda doing the same thing.. also maybe moving or hiding the switches-- I never thought about the rough painted surface .. I knew not to use shiny chrome or stainless due to glare/reflection issues
your truck is looking good!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 07-08-2010, 11:11 PM   #319
aggie91
I'm just glad to be here!
aggie91's Avatar
That gauge set up look fantastic! I think that the texture is great for the back ground, is the bezel just going to be the same shade of black without the texture?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-09-2010, 01:04 AM   #320
SCOTI
SCOTI's Avatar
Yes. Bezel will just be satin black.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2010, 09:36 AM   #321
N2TRUX
Happy to be here
N2TRUX's Avatar
Scoti- The texture looks great around the gauges. Very good idea. On the bezel, have you considered painting the ribbed area a contrasting color, then overlaying with satin black and lightly sanding? Like ribbed valve covers that are painted between the ribs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-10-2010, 10:45 AM   #322
Painter D
Painter D's Avatar
Nice work SCOTI, keep at it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 07-10-2010, 09:17 PM   #323
SCOTI
SCOTI's Avatar
I got a little more done today.... I had to get the truck moved from my buddies shop as he was running out of room. I picked it up this morning & it's now back in storage waiting.
After that, I got up to the shop & finished the vent window frame repairs. It went fairly easy considering the curve I had to make but they turned out decent. Here's where I started disassembly, cutting out the rot, & a shot of the new side . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-10-2010, 09:21 PM   #324
SCOTI
SCOTI's Avatar
Once it cooled, I cleaned up the edges, traced my 'cut line' so that new transitioned to old seamlessly, & did final clean-up w/a DA.
A little 'pookie', primer, & satin black; you'll never know there was a problem . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-10-2010, 09:23 PM   #325
VA72C10
VA72C10
VA72C10's Avatar
nice work!!! Looks like new!
