#301 |
Re: Parting out 72 GMC K20 4x4 350-TH350
Replying to your February 17, 2015 message, if you can verify you have the rear most frame member z shaped plate and front GMC 4 X 4 bumper brackets I would like them. Thanks Br.
#302 |
![]() Join Date: Aug 2013
any chance of the transfer case bracket...
#303 |
Do you still have the water pump pulley? I can't tell from the picture, but is the crank pulley 2 groove as well? I need both pulleys with 2 grooves if you have them.
#304 | |||
"Junkyard Dog"
![]() Join Date: Jan 2008
45.00 for the complete RH transfer case support assembly. 15.00 shipping. Quote:
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
#305 | |
#306 |
Do you still have the upper and lower control arms?
#307 |
Interested in the pulleys if you have a matching set of double groove water pump and crank pulleys. The alternator is on the driver side, compressor on the passenger side. Short water pump with te 2" bolt pattern fan.
#308 | |
"Junkyard Dog"
Yes but it would be monday before I can.
Ummm...this is a 4x4 thread. Are you looking for 2wd control arms? I do have all the choices. Quote:
Thanks, Tom
#309 |
![]() Join Date: Oct 2014
Looking for a heater control unit no a/c
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) ![]() MAI Interior shop |
#310 |
[quote=tll74;7080865]Yes but it would be monday before I can.
any updates on the TC bracket? |
#311 |
![]() Join Date: Jul 2011
Any chance you still have the engine? Looking for an original 1972 350? Thanks
We Bought another truck? |
#312 |
![]() Join Date: Dec 2009
What parts do you have left?
#313 |
![]() Join Date: Apr 2015
nevermind
67 c30 Cab and Chassis (ex motorhome truck) 68 c10 LWB 70 c30 Cab and Chassis 133" converted to Longhorn 72 K10 LWB Rust Bucket Hunting Truck Last edited by Motorfist; 05-11-2015 at 11:14 AM. |
#314 |
do you have a 4x4 throttle cable ?
#315 |
Active Member
![]() Join Date: Jun 2013
Hello,
I am looking for a TH350 dipstick and tube for a 1970 C10 I believe it is approx. 34" long. My truck had a tranny swap done and the previous owner put a car dipstick in and it is low behind the engine hitting the firewall. Thanks Joe |
#316 |
Active Member
![]() Join Date: Jan 2011
Do you have a 72 Blazer rear brake fluid line bracket that attaches to the frame and one for the axle . Both lines.
#317 |
69-72 k20 rear springs, 95415 ?
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
#318 |
also good 4x4 350 fan shroud? could i get a depth measurement and fan opening measurement ? i'm thinking of using it on my 6.0l swap if it will work. the 2wd shroud i have is just shy of the 6.0l fan. thanks,rick.
#319 |
if you still have the rear leaf spring hangers i will take them both
#320 |
To whom it may concern and to all of our valued customers.
Tom has asked me to let all of you know that he is alive and well but very busy with other obligations. With that said he has asked me (Thomas) to post a message and ask all of you to contact DLTRuck1973 for any of your parts needs moving forward. As some of you know, Tom brought me on in January to handle on line parts sales under DLTRuck1973. As always, we appreciate all of the business from all of our customers. I (Thomas) will try to answer your questions, do shipping quotes and take care of any transactions as prompt as possible. For anyone local, come in and see us Mon-Fri at D&L Truck Parts 91720 HWY 99S, Junction City, OR Thank you all for your patients, Thomas |
#321 |
I would be interested in the top part of the
transfer case bracket. |
#322 |
#323 |
#324 |
I will take the far left crossmember in the very first picture and the front/rear hangers with the brackets that are located under the frame.
#325 | |
I should have everything you need. Do you have a zip code for shipping quote? It will be a couple of days before I can get to it. Super busy now. Thank you, Thomas |
