"Junkyard Dog"
![]() Join Date: Jan 2008
Parting out 72 GMC K20 4x4 350-TH350
I just finished parting this one out. A 72 GMC 3/4t 4x4. Most all metal parts have been hot tanked and acid dipped. Media blasting available at no cost on most parts. All prices are plus shipping. Thanks, Tom
NP205-TH350 transfer case. 200.00 Transfer case adapter w/coupler. 125.00 TH350 trans been rebuilt at some time. Nice fuild and clean pan. 250.00 Pic 1 Rear crossmember 40.00 intermediate cross member 45.00 front cross member 25.00 Transmission-transfer case cross member 65.00 cab frame mounts (2 fronts, 2 rears) 20.00 each front spring/core support mounts 35.00 each LH one is ruff have a good one. front spring rear shackle mounts 25.00 each front bump stops w/brackets 10.00 each front shock brackets 5.00 each front LH spring stop 10.00 forward rear spring hangers 30.00 each rear/rear spring hangers 25.00 each (only one in pic) Front u-bolts with plates 30.00 per side rear u-bolts w/plates 25.00 each Pic 3 rear bump stops w/brackets 12.50 each box supports 6 of them 10.00 each rear shock mounts 15.00 each rear e-brake cable brackets 5.00 each front exhaust hanger bracket 10.00 rear hyd brake line bracket 10.00 P/S steering conversion complete 125.00 steering intermediate shaft 25.00 steering rag joint 22.50 nice fan shroud, minor fan rub on top. can not see when installed 85.00 very nice original flex fan 10.00 AT pedal hanger and pedal 25.00 e-brake cables, support links, bracket, coulpers and spring. 45.00 transfer case support kit 45.00 trans-tcase rubber mount kit original 27.50 speedo cable minor blem in platisc 20.00 looks very nice L71-72 RH axle (large u-joint) 75.00 nice L71-72 LH axle (large u-joint) 75.00 nice draglink tight ends 25.00 heat riser nice springs works perfect original 25.00 crank pulley 12.50 water pump pulley 2 groove 15.00 Pic 2 oil line 8.00 tail gate hardware on box 25.00 tail gate hardware in gate complete w/bolts 45.00 GMC letters good chrome needs black repainted 15.00 GMC park lamp wiring 10.00 each nice condition heat stove pipe 12.50 washer hose set 12.50 tail lamp lens 10.00 nice condition fender-core support triangles 5.00 each door stricker plates 8.00 each Pic 3 door panel seal 5.00 door latch rods 3.00 each amber marker lenses 10.00 each nice color red marker lens 10.00 nice color GMC turn lens/housing 12.00 some fade vent pull rods w/knobs 5.00 each dome light switch wiring 10.00 fuel tank wiring 8.00 dome light wiring 10.00 inside door handle 5.00 window crank handles 6.50 each tight knobs tail lamp housings 10.00 each back up housings 7.50 each LH outside door handle very nice driver quality 25.00 RH outside door handle chrome peeling 8.00 oil filter adapter 8.00 dip stick sleeve 5.00 heater controls needs center lever I will replace it 45.00 window weather strip channels 10.00 each Misc pics C/K20 71-72 power brake conversion 65.00 base black door panels very nice outside one has broken spot for one retainer the other has two melted spots from me heating the nuts to get armrest off. It would still work just fine. 60.00 steering colum black 60.00 4x4 AT tunnel cover 40.00
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
"Junkyard Dog"
Re: Parting out 72 GMC K20 4x4 350-TH350
more pics
![]() Join Date: Mar 2011
I will take the flex fan . Pm thanks. zip code 92683
![]() Join Date: Mar 2012
is this the one with the hubs i asked about? if so, in line
![]() Join Date: May 2003
Interested in the high hump A/T tunnel !
Do you have the top radiator metel pipe ? Drivers side door latch control ? The piece in the door the handle goes on . Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 01-20-2014 at 11:57 AM. |
Hello. I'm looking for a set of rear bumper brackets.donyou have a set? Shipping is to Miami, Florida 33176.
Carpe manana
![]() ![]() Join Date: Dec 2010
Tom I'll take the front exhaust hanger bracket and speedo cable. Is the rear hanger there? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: May 2013
Interested in gmc fender eyebrow trim pieces,t-case support (just need rubbers+bolts ?),and speedo cable if pete passes.shipping would be to 07719.
Thanks,Tom |
I'm interested in the top metal radiator pipe if you have one.
intrested in the trans crossmember, pm shipping to 77505 thanks JJ
Active Member
![]() Join Date: Dec 2003
How much for the rear cab mount boltts?
![]() Join Date: Nov 2010
I'll take the steering rag joint. Shipped to Sparks, NV 89441. PM sent. Thanks, Dan
#13 |
![]() Join Date: Jun 2003
Do you still have the center tie rod that connected left knuckle and right knuckle? About 56" long with a tiee rod on each end.
Thanks, 72 |
#14 |
In pic#3, I'll take the 2 window weather strip channels @ $10 each. PM me so I can pay and get shipping to 43357. Thanks, Jim
#15 |
Also, would you have the 2 channels that the window glass in resting in? I need those also. Thanks, Jim
#16 |
"Junkyard Dog"
Hang tight guys I'm at work till 5:00 and I'll catch up then. Thanks, Tom
#17 |
![]() Join Date: Jan 2012
I will take e-brake cables,supports, etc for 45.00 also e-brake rear brackets and rear hyd brake line bracket let me know a total shipped to 48817 thanks Mike also would you consider seperating the bump stops from the brackets?
![]() 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
#18 |
What would be the cost of the fan shroud shipped to 98328? Thanks
#19 |
Second on the center ebrake cables. In line for top radiator pipe..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#20 |
Carpe manana
Just to clarify, being a GMC the e-brake cable is probably for a Dana 60 rear not an Eaton HO 52?
#21 |
"Junkyard Dog"
Shipping is via UPS and is actual cost. I have a daily pick up so that's what works for me. USPS on small items in flat rate boxes and or padded envelopes.
gmclonghorn, pm coming gmc 2500 4x4 Paul, No..that's the 72 Sub K20. I will have it this Friday. Don't worry your in first place on them. CUSTOM/10 Gary, nothing on the upper rad pipe. I Should have the relay 10.00 for a good one. dec010974, Nothing right now on the sport rear bumper brackets. DeadheadNM Pete, I can't recall. Let me look on the frame chunks. I'll start a pile for you. mx289,The RH is a nice driver with a screw hole at the very bottom tip, 20.00. The LH is rusty towards the top 5.00. I plan to keep the t-case support complete. 16.07 shipping if you want all of it. Some PMed me for a pair of these and I cleared out PM's and lost who it was. For who ever that was my apology. 20HDriver, Sorry nothing right now. blackbolt, JJ Shipping is 32.70 it weighs 28lbs 72swbcamo, 11.00 shipped karphan, Dan, 6.00 shipping 72longbed, Yes 85.00 plus shipping allons, Shipping for all of it 19.94 and 20.00 for the channels that attach to the glass. cst204x4,Shipping 24.61 freakshow108, Shipping is 27.40 With packing it is 32x22x11 which is oversize.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 01-20-2014 at 10:21 PM. |
#22 |
Thanks for getting back to me, but I'm gonna pass on the package.
#23 |
"Junkyard Dog"
Pete, yes it was a D60. Would it matter? Wouldn't this portion be the same? I have a couple HO72 4x4's that I could compare it. Thanks, Tom
#24 |
![]() Join Date: Jan 2007
hi,intermediate cross member. large one in front of leaf spring hangers also power steering set up as well, but may be to much to ship! pa 19320 thanks
#25 |
What about the 4x4 AT tunnel cover, what kind of shape is it in ? Any rust, or extra holes ?
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
