Old 03-09-2011, 09:45 AM   #326
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
Originally Posted by mooseknuckles View Post
well..the weather still sucks!!
Just wait 20 cms coming today...rain tommorrow.....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-10-2011, 09:37 PM   #327
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
hey man you still have that grill?
mooseknuckles is offline   Reply With Quote
Old 03-12-2011, 07:20 PM   #328
mooseknuckles
Re: My 86 build
picked up some parts today...bags, mounts, valves, and tanks. the bags look kinda cheap, and I dont know if I'll use the tanks, but they were part of the deal so...
Old 03-12-2011, 07:42 PM   #329
SS Delux
SS Delux's Avatar
Re: My 86 build
Did you find this deal on kijiji ? and how much did you pay if you dont mind me asking ?
SS Delux is offline   Reply With Quote
Old 03-12-2011, 07:51 PM   #330
maxxxy
maxxxy's Avatar
Re: My 86 build
Those cups look really tall! And the tanks look a little sketchy. lol but a pretty good deal.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-12-2011, 07:59 PM   #331
mooseknuckles
Re: My 86 build
I found them through a friend on facebook, he's like 20min away...$400 for it all. I thought it was worth it?
Old 03-12-2011, 08:03 PM   #332
mooseknuckles
Re: My 86 build
yeah....The tanks are a little rusty, and I think I can cut up the cups & the mounts to use then for my rear bag mounts.
Old 03-13-2011, 05:52 PM   #333
jokermrl
jokermrl's Avatar
Re: My 86 build
I went through your whole thread yesterday really like what you have been doing to the truck. I really like where you put the gas cap. I might be copying you on that one, since i have the 76 with the cap on the bed and no door. Truck is looking sharp keep it up.
jokermrl is offline   Reply With Quote
Old 03-13-2011, 07:48 PM   #334
mooseknuckles
Re: My 86 build
hey thanks man! ....you can copy that if you want. pretty easy to do. the hole should have been a couple more inches towards the back... I screwed up when I cut the hole out, and the filler isn't quite centered in the hole, plus I moved the box closer to the cab to close up the huge gap in between them. but it still works ok, and once I'm done my 4-link I'll be putting in a blazer tank in the back...
Old 03-13-2011, 08:18 PM   #335
Pop's C-10
Pop's C-10's Avatar
Re: My 86 build
Clean tha tanks up & preasure test them to see what's up.. looks like a good score..use what you need..sell what you don't.
Pop's C-10 is offline   Reply With Quote
Old 03-13-2011, 10:22 PM   #336
mooseknuckles
Re: My 86 build
I'm gonna get my bro to sandblast them, and go from there....
Old 03-14-2011, 08:05 PM   #337
mooseknuckles
Re: My 86 build
ordered in some axel/link mount tabs for my upper & lower link bars today, and shock mount tabs. that should be almost everything I need to get my 4-link welded in. also gonna order one of these in a few weeks....
Old 03-14-2011, 11:27 PM   #338
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: My 86 build
Its coming along great!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-14-2011, 11:33 PM   #339
mooseknuckles
Re: My 86 build
thanks!
Old 03-16-2011, 05:53 PM   #340
mooseknuckles
Re: My 86 build
I was planning on using some of these for my 4-link mounts, but after seeing them, they're not going to work. they're not quite long enough and should be1/4"thick. I need some for shock mounts anyway, so now I have extra...
Old 03-19-2011, 06:50 PM   #341
mooseknuckles
Re: My 86 build
I had planned on taking the box off my truck today and removing the bed floor, but since my buddy had borrowed my welder, I had no way of making a frame to hold the box sides on..so instead I removed all of the seam sealer out of the joints, and loosened most of the bolts so it'll be ready to come out next weekend...I also removed the stake pockets with a cold chisel, and I also took a few pics of this highly productive day....
Old 03-20-2011, 09:02 AM   #342
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
very productive
yup we sure are gettin some nice weather now
John
Old 03-20-2011, 10:02 AM   #343
73gmc454
73gmc454's Avatar
Re: My 86 build
Oh yea I remember doin that ! lookin good , supposed to be 55 out today ,I to get somin get done too !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 03-25-2011, 05:21 PM   #344
mooseknuckles
Re: My 86 build
weekends here, picked up my welder, time to get at 'er!
Old 03-25-2011, 05:50 PM   #345
Pop's C-10
Pop's C-10's Avatar
Re: My 86 build
Old 03-25-2011, 06:10 PM   #346
mooseknuckles
Re: My 86 build
haha..hey koolaid!
Old 03-26-2011, 08:11 PM   #347
mooseknuckles
Re: My 86 build
so today I started working on my bed trying to remove the floor, lifted the bed off with the cherry picker, set it on saw horse's and removed several hundred bolts...got it all apart and set back on and made up some temporary mounts to hold the sides on. I didn't have enough steel kickin around so I'll have to buy some more square tube to make a better frame, and it still needs a little tweakin here and there, but it's back on at least...
Old 03-26-2011, 08:15 PM   #348
mooseknuckles
Re: My 86 build
some more...
Old 03-26-2011, 08:31 PM   #349
joe231
joe231's Avatar
Re: My 86 build
nice man!!
there is a crazy-stupid amount of bolts holding these together!
did you have any of the backer nuts break loose and spin?
that is usually my problem, but since I got my welder, it ain't that big of a problem anymore
CHEVY ONLY
Old 03-26-2011, 08:54 PM   #350
mooseknuckles
Re: My 86 build
nope...some one had this thing undercoated at couple of times, plus a few oil leaks, and everything comes apart pretty easy..
