Old 07-15-2013, 05:43 PM   #326
knomadd
knomadd's Avatar
Re: Project 69SWB
I just ran across your thread. I'm impressed with how you fixed your door gap issue. And your dash looks amazing. I'll be following along now...
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-15-2013, 10:36 PM   #327
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Originally Posted by ~Whitey~ View Post
Inside the fender at the top is where the worst of mine was at, wish I could have sent them off for blasting and normally would have but the same guys who blasted my cab ($300) wanted $100 each to do the fenders. Crazy. So I had to do it here at home with a 3m paint/rust stripper wheel, screw driver and sand paper and patience! What I couldn't get to with those things I used a wire brush to loosen anything up and used the Fast Etch which converts the rust, then painted those areas with rust encapsulator... took some time but I believe they'll be good for years to come.
That is the exact same place the worse of mine is at, thanks for the tips. I'll probably be doing the same exact thing.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-16-2013, 01:10 PM   #328
Low Elco
Re: Project 69SWB
Good strippin'! Always fun.
Low Elco is offline   Reply With Quote
Old 07-16-2013, 01:20 PM   #329
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thank you! I'll try to keep you entertained.
no problem, I'm sure blasting would be better, but sometimes you gotta do what you can.
Oh yeah... SO much fun, about as fun as an all day welding & grind fest!
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 07-19-2013, 10:22 PM   #330
c20chevy1972
Re: Project 69SWB
nice work
c20chevy1972 is offline   Reply With Quote
Old 07-20-2013, 12:47 PM   #331
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by c20chevy1972 View Post
nice work
Thanks I appreciate it!
Jimmy
.69SWB Build.
Old 07-26-2013, 01:01 PM   #332
KSWes
KSWes's Avatar
Re: Project 69SWB
Been following along haven't commented in a while, Interior paint looks great, our builds are running pretty close to parallel. Nice job on the cab! Sure looks like a lot of work but I'm sure when it's done you'll be happy to have the gaps right. When we fitted my doors earlier this week we discovered a few issues the previous owner had done the rockers and they were pretty close, but perfect gaps aren't going to happen for me. And I'm too far along in the process to want to cut them off and refit/replace them. Just wanted to say nice work! and keep it up!
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 07-26-2013, 04:09 PM   #333
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I've been following your thread too and we could probably switch garages and keep on working! Lol. Thanks for the compliment! Can't wait till we both have paint on our trucks!
Jimmy
.69SWB Build.
Old 08-05-2013, 10:51 AM   #334
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Project 69SWB
Well Jimmy fouund your build thread, I think you have been doing a fantistic job, And i like your engine color. Good job. Hope that bed fender works out for ya also.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 08-05-2013, 11:32 AM   #335
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
With a little cutting here and a little welding there I'm sure it'll work out just fine... :-)
Thanks again, was great meeting you Larry. I'll look for ya at the swap meet coming up... and if you find that steering wheel please give me a shout!
Jimmy
.69SWB Build.
Old 08-12-2013, 05:44 PM   #336
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Jimmy, how the truck coming along? I've been following along, nice job on the repairs.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-16-2013, 03:38 PM   #337
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
It's coming along a little slower than usual... I work better in the Fall and Winter. It's been so muggy here in Springfield and I'm sure you can attest to that in KC as well. I still manage to get out in the garage a couple times a week.
I've just been trying to get everything but the bed in Primer so I can put it all together and do the body work. I'm just about ready to spray the doors and fenders in primer, they're all to bare metal now and the metal work is done.
I did get my core support, hood hinges and door hinges primed and painted. I was going to send the core and hood hinges to be powder coated, but didn't have the budget... well I did, but spent the money on my Harley instead. It's summer what can I say! :-/ So instead I just sprayed them all with epoxy primer and then followed straight up with paint. Turned out pretty nice. I did have them sandblasted first.
Jimmy
.69SWB Build.
Old 08-16-2013, 03:44 PM   #338
sduckworth13
Re: Project 69SWB
Those parts turned out real nice.
Scott
Old 08-16-2013, 03:47 PM   #339
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
right now I'm working on my door panels... I had them sandlblasted and then had to do a little metal repair.. they have some pitting in them but it'll be covered up with the covers I got from a board vendor, Tim at http://classictruckseats.com Great guy to work with and is a distributor for Trimparts. I got my entire interior from him.. ALL very nice quality stuff made in the USA.
Here is the cover from Truckseats.. Super nice!
Sandblasted and then sprayed them with Eastwoods Rust convertor, it's epoxy based so should keep pout any moisture.
You can see the pitting, but It'll be covered and all the rust was blasted out.
I sprayed Eastwoods Rust Convertor first on the back, then hoping some 3M undercoating would help with Road noise here I sprayed it, but after doing a "ting" test on the metal... It didn't make any difference, it tinged just as loud as without it, so I'll probably use a sheet of my Hushmat on the back of these.
PS thanks for checking on me Scott!
Jimmy
.69SWB Build.
Old 08-16-2013, 03:54 PM   #340
Bennett68C10
Re: Project 69SWB
Looks great Jimmy, nice progress
Keith
66 Suburban
IG: bennett68c10
Old 08-16-2013, 03:55 PM   #341
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks a bunch Keith... It kind slow for me in the summer time, but looking forward to cooler weather!
Jimmy
.69SWB Build.
Old 08-16-2013, 03:58 PM   #342
sduckworth13
Re: Project 69SWB
Those door panel covers look nice. Your doing a thorough job on everything.
Scott
Old 08-16-2013, 04:24 PM   #343
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Very nice work on the door panels Jimmy! I like the sound insulation idea. May have to steal that one myself. Looking forward to updates.
mcbassin is offline   Reply With Quote
Old 08-16-2013, 04:34 PM   #344
Xeen
Xeen's Avatar
Re: Project 69SWB
The truck is lookin good man, I can't wait to see the front clip go on.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-16-2013, 04:52 PM   #345
KSWes
KSWes's Avatar
Re: Project 69SWB
Nice Job on the progress! Looks great!
70 Chevy C10 LWB
Old 08-16-2013, 07:58 PM   #346
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Scott... I try. I won't say I haven't cut corners on somethings, but when I do I try to cut em clean. haha
Thanks Mike, I gotta swing by your thread and see what you've been up to!
You and me both Brian!
Thank you Wes!
A little walk down memory lane
I almost forgot to mention... My first vehicle ever was a 68 c10, it's where my love for these trucks come from... anyway, back in the day I had taken the doors and bumpers off my 68 and swapped them out with some doors from a 72 and chrome bumpers and left my 68 doors laying out in the woods in a pile of forgotten junk at my parents house... Over the years my brother and I would shoot the doors with our guns and what not... well I decided to go look at see if there was anything worth salvaging, and I don't know how one of them escaped our onslaught of lead during many different shooting sprees, but it did. I had hopes when I seen it that I could use this door on my truck.. clearly for sentimental reasons ya know! I afraid it's too far gone and is actually pretty warped though it don't look like it, but I am going to draw a logo on the door and hang it on the wall in the garage.. It'll say Whitey's Garage or something... The bumper I'll probably hang too with my very first license plate ever. Way cool!
My very first vehicle ever, a 68... Dad bought it for me for $300 back in 1987. They still have several boxes of pics I need to go through.. hope to find more pics of it.
Here's the door that escaped all the shooting, must have kept it's head (mirror) down.
and the old bumper from my 68 with the first licensed plate ever in my name.
I couldn't find the front bumper.
Jimmy
.69SWB Build.
Old 08-16-2013, 08:56 PM   #347
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Project 69SWB
Nice work!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-16-2013, 09:46 PM   #348
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by 67_C-30 View Post
Nice work!
Thank you!
Jimmy
.69SWB Build.
Old 08-17-2013, 10:04 AM   #349
jmking9
jmking9's Avatar
Re: Project 69SWB
Looking great! I thought about calling you last weekend and making a stop in Springfield driving my truck home from Branson. But it was Sunday morning and didn't want to bother you. Anyway, are you looking for doors?
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-17-2013, 10:41 AM   #350
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Come by anytime! Give me a call anytime and next time for sure.
Nah not looking for doors... I have 3 1/2 sets. Ha. Heading to swap meet, you there today?
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
