Old 01-03-2015, 10:43 AM   #326
67cheby
67cheby
67cheby's Avatar
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
next step figuring out where to cut and fitting the lower front door brace with the LMC Truck patch panels
67cheby is offline   Reply With Quote
Old 01-03-2015, 10:45 AM   #327
67cheby
67cheby
67cheby's Avatar
Next step cleaning off the inner rocker panel brace from the cab mount and fitting the inner rocker / floor patch panel also from LMC Truck
Old 01-03-2015, 10:49 AM   #328
67cheby
67cheby
67cheby's Avatar
I chose to leave the rear 10 inches or so of my factory rocker since it was in excellent shape and I like to save all the original metal I can ! I also like to cut a panel where it leaves my weld on a bend to keep it cleaner (in my opinion) after trimming your patch panel lay it over the original panel and mark it off to give you an exact pattern to cut out.
Those clamps are the $8 ones from Harbor Freight and I must say I cant believe I haven't had a set until now, they are Awesome !
Old 01-03-2015, 10:53 AM   #329
67cheby
67cheby
67cheby's Avatar
Next panel the lower side kick panel. I did have to modify this panel slightly to get it to line up like I liked, and once i get it welded in solid i will be using a step bit to align all the bolt holes exactly.
Old 01-03-2015, 10:56 AM   #330
67cheby
67cheby
67cheby's Avatar
That is all at the moment, more to come. I did the drivers side New Years Day and it took me 6 1/2 hours , this side has gone much faster once you figure out what your doing it goes pretty quick. The Harbor Freight clamps give you the perfect welding gap and once it is ground down you have a nice flat butt panel connection, i will post some finished pictures on Monday.
Once again thank you LMC Truck for your support !
Old 01-03-2015, 11:32 AM   #331
jlsanborn
jlsanborn's Avatar
Nice work Mike. Making it look easy!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-03-2015, 11:51 AM   #332
67cheby
67cheby
67cheby's Avatar
Thanks man, its really not that bad. I have actually been really enjoying it !
Old 01-03-2015, 12:46 PM   #333
oldman3
oldman3's Avatar
Nice repairs Mike...Jim
oldman3 is offline   Reply With Quote
Old 01-03-2015, 01:25 PM   #334
jtp67-72
jtp67-72's Avatar
Liken' this.....that kind of work is like meditation for me...."frustration" for some....and a good example of why you dont "HAVE TO" use entire patch just because it came that way ....it's not so much original metal as it is the original "FIT"....... and your right .....a little planning ahead and you can minimize the weld pattern that is seen........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 01-03-2015, 01:34 PM   #335
67cheby
67cheby
67cheby's Avatar
Thank you !
Exactly !
Old 01-03-2015, 03:10 PM   #336
watahyahknow
watahyahknow's Avatar
there spotweld drill bits available for when you want to save the metal behind the rusted piece
it only cuts the top metal leaving enough fles on the bottom one to weld the new piece on
it takes a little practice to know how deep to drill but other than that there nice tools to have
talking bout tools but not related to sheetmetal ......
i seen this today :
https://www.youtube.com/watch?v=MyZEaPQinO0
its expensive but so is a gas rig and its a lot safer too you could basicly do this near a gasleak and nothing would happen unlike when using an open flame , as long as you dont damage the coil it will keep going too ans not run out of gas
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-03-2015, 06:18 PM   #337
duallyjams
duallyjams's Avatar
Huh you made it look like a 15 min episode the slosh tubz channel.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-03-2015, 06:55 PM   #338
clemdaddy
clemdaddy's Avatar
nice work man... you got it going on.
got a few pass-side fenders to look at. and the wing to return... lets hook up this week, if not tomorrow.
clemdaddy is offline   Reply With Quote
Old 01-03-2015, 07:28 PM   #339
jkeating1
jkeating1's Avatar
In post #327--how did you know where the factory spot welds were? I doesn't look like they were still visible on the surface.
JK
jkeating1 is offline   Reply With Quote
Old 01-03-2015, 11:30 PM   #340
sduckworth13
sduckworth13's Avatar
Metal work is looking great Mike.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-04-2015, 05:01 AM   #341
watahyahknow
you can make a quick pass over the surface with the grinder or a piece of sandaper and see te dimples the spotwelds leave behind on non mediablasted steel
when the material is blasted you just see them
it might be the lighting doesnt make the dimples show up
or they whent a little thick on the primer
usually there pretty clear te see
Old 01-04-2015, 11:39 AM   #342
BigDaddyV
BigDaddyV's Avatar
Very nice progress Mike! Keep it up. I'm hopefully gonna get started on my cab soon.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 01-05-2015, 10:32 AM   #343
67cheby
67cheby
67cheby's Avatar
i seen this today :
those are sweet !
LOL...16 hours start to finish on all the floor work !
Thanks for all the help Clem !
run a grinder over the top and it will expose the low spots that are the spot welds !
thanks man !
Exactly !
Go Big Daddy !
Old 01-05-2015, 10:38 AM   #344
67cheby
67cheby
67cheby's Avatar
Ok well here is the second set of pics.
Metal finished the floor welds.
Welded in the LMC Truck side kick panel bottoms
bolted the outer bottom of the LMC Truck A pillar back on and welded it in
Old 01-05-2015, 10:39 AM   #345
MaximilianKimlin
Nice build man! I'm following you in Instagram. That sheet metal work is top notch!
MaximilianKimlin is offline   Reply With Quote
Old 01-05-2015, 10:41 AM   #346
67cheby
67cheby
67cheby's Avatar
Next up fitting the LMC TRUCK replacement rocker panels.
First since I used the rear of the stock rocker and I wanted to get an exact fit, I cut the rocker a 1/2 inch or so long.
Then Layed the rocker over the existing rocker and marked it for an exact cut
Cut the rocker and now it is ready for final weld in
Old 01-05-2015, 10:48 AM   #347
67cheby
67cheby
67cheby's Avatar
Next up the front part of the High hump sent all the way from Germany from my friend Patrick Koch , Thank you Patrick !
First step drilling holes around the edge to plug weld
Marking the holes on the cab side
Grinding off the epoxy so the weld will take
Weld it in and smooth off the welds !
Old 01-05-2015, 10:51 AM   #348
67cheby
67cheby
67cheby's Avatar
That leaves one last step on my floor repairs the hole in the high hump needs filled.
Cut out a patch panel
Weld it in and smooth it off !
Also welded up the gas neck, a little hammer and dolly work and she should be good to go !
Old 01-05-2015, 10:55 AM   #349
67cheby
67cheby
67cheby's Avatar
Here are a few shots of the whole floor after I finished with all the LMC Truck patch panels !
Old 01-05-2015, 10:56 AM   #350
Elliot949
Elliot949's Avatar
Awesome Work Mike... are you sure you don't want to do the finish work on "Class Act"???...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
