Old 01-14-2012, 06:27 PM   #351
_Ogre
_Ogre's Avatar
Re: My Project 56Chevy1300
56chevy1300 hasn't log on this site in a yr, but this is a sweet truck.
1300 is the canadian version of the 3100 1/2 ton trucks.
what i find interesting is the fender mounted spare is located on the 1300 passenger side vs the drivers side on the 3100.
must be a cunuck thing...
i modified my fender mount to hold a 5 lug 8 inch rim, which makes the stock drivers mirror totally worthless.
had i known the pass side mount was available, i'd have searched for one.
i'd have the only pass mounted spare around
shop air compressor timer
Old 01-14-2012, 06:36 PM   #352
_Ogre
_Ogre's Avatar
Old 01-14-2012, 11:41 PM   #353
watahyahknow
watahyahknow's Avatar
it does make it eazier to find a fender without the dent in it for the spare
maibe it has to do with the local law , for a minute i figured they drove on the wrong side of the road but thats in australia
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-15-2012, 05:53 PM   #354
_Ogre
_Ogre's Avatar
maybe i should put two fender mounted spares on my truk...
the fender mounted spare was a dealer option.
they ordered the fender & mount, tossed the stock fender.
the factory assembly manual shows a 3/8'' shim for the rear axle to level the ride.
Old 01-15-2012, 11:33 PM   #355
oldcouple
oldcouple's Avatar
My former brother in law had a NAPCO that had the mounts on both sides. Guess the guy was a serious off roader.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 07-27-2012, 04:54 PM   #356
56chevy1300
56chevy1300's Avatar
Its been over 2 years since I've posted on this thread. Have almost 5000 kms on the truck. No mechanical issues. Handles and brakes well. Put bigger tires on (225/60 front and 255/60 rear). Have some rubbing issues in the back to fix. Painted interior dark grey metallic.
Going to Rock n Red Deer on August 4th. My first official show to be registered!
56chevy1300 is offline   Reply With Quote
Old 07-27-2012, 05:07 PM   #357
56chevy1300
Anyone know how to move this thread to the "Projects and Builds" file?
Old 07-27-2012, 05:44 PM   #358
Kabwe
Certified Car Nut
Kabwe's Avatar
Well its nice to see you are back.
Kabwe is offline   Reply With Quote
Old 07-27-2012, 06:24 PM   #359
Kim57
Kim57's Avatar
Welcome back. Truck looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-27-2012, 07:21 PM   #360
hammerdog57
hammerdog57's Avatar
Truck looks good with new tires. Did new tires with more side wall fix rough riding issues? What back space do your rear rims have? Trying to order tires for the rear of my truck and want the widest i can get with out rubbing issues.
hammerdog57 is offline   Reply With Quote
Old 07-28-2012, 05:05 AM   #361
watahyahknow
irs actually looking a little odd theres tons of space on the picture , where are the reartises rubbing ?
if its the back you prolly can mount some spacers and be done with it
Old 08-01-2012, 01:01 PM   #362
56chevy1300
The bed isnt centred, I need to move it 1/2 inch over to the left. That might solve the problem.
Old 08-01-2012, 01:01 PM   #363
56chevy1300
Ride is much better with taller tires.
Old 08-01-2012, 04:58 PM   #364
_Ogre
_Ogre's Avatar
those low profile tires can beat you kidneys to death
5000kms, isn't that equivalent to about 40 miles?
nice truck by the way...
Old 10-03-2017, 01:48 PM   #365
CFD286
I know Jebb, it gotta weigh between 25 and 30 lbs! Here are pics of the trans crossmember and spring perches being removed...probably the toughest task so far.
Great thread My Project 56Chevy! I have seen numerous threads on this topic and never see anyone address my question below.
I am preparing to install a 75 camaro sub frame in my 57 Chevy 3100. I am wondering if you adjusted your positioning of the sub frame to the original frame to have the caster be close to nominal before laying your welds? With my sub frame sitting level on jack stands, I have about -2 degrees of caster. I believe that it should be at least +3 degrees at ride height? Just trying to figure all of this out prior to committing to cutting my frame!
I hope it makes sense what i am trying to ask!?
CFD286 is offline   Reply With Quote
