Old 08-04-2011, 05:32 PM   #351
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Well I got a little more done on the hood.
I'm using 3/8" steel rod for the runners.
I made a jig to bend the runners that the hood will ride on.
It's basically a bolt the same size as the roller with another to hold it in place. I heated it cherry red with a map gas torch and just bent it around the bolt.
I also set up a jig for the other bends and did the same with them.
Kim
Kim57 is offline   Reply With Quote
Old 08-04-2011, 05:33 PM   #352
Kim57
Kim57's Avatar
A few more pics of the runners.
Kim
Old 08-04-2011, 05:39 PM   #353
Kim57
Kim57's Avatar
I've decided to use spherical rod ends for my tilt on the hood.
The first thing I had to do was come up with a way to attach them to the hood.
Here's what I came up with.
I used some 3/4x1/2 DOM and cut it to fit around my support rods.
A couple of threaded inserts welded in and a home made gusset and it should work just fine.
Kim
Old 08-04-2011, 05:40 PM   #354
Kim57
Kim57's Avatar
Here's a few more pics of them tacked in.
I just have to finish welding them and they'll be good to go.
Kim
Old 08-04-2011, 05:51 PM   #355
xpickup
xpickup's Avatar
Kim57, Very nice job. I want to make one for my 48 panel when I get back to working on it. Thank you for great how to's.
Shannon
xpickup is offline   Reply With Quote
Old 08-04-2011, 05:54 PM   #356
ambryatim
ambryatim's Avatar
You....are awesome my man!!!!
Great work!!! I love looking at what you are going to be doing next....as always top notch work.
ambryatim is offline   Reply With Quote
Old 08-04-2011, 05:59 PM   #357
Daze57
Daze57's Avatar
always excellent work sir !
Daze57 is offline   Reply With Quote
Old 08-04-2011, 06:13 PM   #358
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good as always Kim. Great job.
Kabwe is offline   Reply With Quote
Old 08-04-2011, 06:17 PM   #359
oldman3
oldman3's Avatar
Kim, looks real good....Jim
oldman3 is offline   Reply With Quote
Old 08-04-2011, 09:12 PM   #360
Kim57
Kim57's Avatar
Thanks for the kind words guys. I do appreciate them.
Kim
Old 08-04-2011, 10:05 PM   #361
candyx
candyx's Avatar
Nice fab work,liked your rod bending jig.
candyx is offline   Reply With Quote
Old 08-05-2011, 01:11 AM   #362
65Pickup
65Pickup's Avatar
Incredible...can I ask what your background is? Engineer, fabricator, welder, all the above. Very gifted.
65Pickup is offline   Reply With Quote
Old 08-05-2011, 04:11 AM   #363
BC Toy chest
BC Toy chest's Avatar
Awesome work, keep it coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 08-05-2011, 08:58 AM   #364
jjjmm56
jjjmm56's Avatar
Again, a great mind at work. One thing to to look at, when bringing the hood foward from the closed position ,my rails did not have enough lift causing the corners of the hood to scrape the top of the fender. Also make sure you have enough roller depth on the rail and the rail straight because it can come off when rolling the hood back. When making this stuff it all trial and error, I can't wait to see it finished, then I'll have to redo mine.
jjjmm56 is offline   Reply With Quote
Old 08-05-2011, 09:08 AM   #365
jimig1
jimig1's Avatar
Kim you do some sweet work can't wait to see it finished.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 08-05-2011, 02:56 PM   #366
Kim57
Kim57's Avatar
Thanks.
None of the above.
I'm basically self taught at home. I've always liked tinkering with stuff since I was a little kid and been a hot rodder since before I could drive.
I do wish I had the finances to get all the tools to make it easier but I get by jury rigging what I need.
I know what you mean by trial and error. I made the angle at the back of the rails rather steep so I can start to get some lift as soon as the hood starts to move forward.
If I have to redesign the rails it won't bother me that much as I don't have that much time or money in them. I was thinking I may need a rail on top of the roller but won't know until I get the hood mounted and give it a try.
Thanks.
I want to see it finished also but all things in time.
Kim
Old 08-05-2011, 05:13 PM   #367
jimig1
jimig1's Avatar
Originally Posted by Kim57 View Post
Thanks.
Thanks.
Kim
I know how that is. I want to have my truck driveable by June next year not sure if it will happen. I don't want to rush through and cause more of a headache
MSRA Member
-George Carlin
Old 08-07-2011, 11:34 AM   #368
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Great work as always!!
ChuckDriver is offline   Reply With Quote
Old 08-07-2011, 11:39 AM   #369
chevyrestoguy
chevyrestoguy's Avatar
You are one crafty guy. I always look forward to updates on this thread.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-07-2011, 10:46 PM   #370
Rods57
Rods57's Avatar
This is awesome fab work on your truck, I would rather make stuff that works than buy stuff that I have to re-work.
Rods57 is offline   Reply With Quote
Old 08-15-2011, 09:04 PM   #371
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Wink Re: My 57 Pro Street
Well I don't have a lot to report.
I've been helping my brother on his 54 furd that's in my garage.
I was able to borrow a set of tires for the front and get an idea of where my stance will be.
These are 215/60-15s.
At this height my cross member is 4" above the ground. It looks like I have enough clearance to run a larger tire so I may do that and see if I can get the front fenders a little lower.
Kim
I got to stop looking at your truck.
Been looking at the bed........
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-16-2011, 07:02 PM   #372
Kim57
Kim57's Avatar
These are the front brackets for connecting it to the cab.
Kinda boring and tedious work but I had to get them done.
I started with some 4" square tube and just went from there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Old 08-16-2011, 07:04 PM   #373
Kim57
Kim57's Avatar
Here's the rest of the pics on them.
I still need to clean up my welds but they seem like they should work OK.
Kim
My build thread
Old 08-16-2011, 07:48 PM   #374
kustombrad
kustombrad's Avatar
Dude, you are a fabricating fool! Awesome!!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 08-16-2011, 11:25 PM   #375
oldman3
oldman3's Avatar
Looking good.....Jim
