Old 09-18-2011, 08:14 PM   #351
Intimidator
Re: Project "49 No Buck$"
Ooops.... You asked for time.
They took me about an hour and a half to do.
Total cost was the lights plus $2 in LED's
Most of the time was in separating the lens from the housing. Using an exacto knife (They're glued with a flexible adhesive) and being careful not to break the glass.
Intimidator is offline   Reply With Quote
Old 09-18-2011, 08:29 PM   #352
Rude Dude
Rude Dude's Avatar
Here is a good link for LED's and even has candle power
http://www.superbrightleds.com/cgi-b...specs%2F67.htm
Rude Dude is offline   Reply With Quote
Old 09-19-2011, 04:11 PM   #353
kustombrad
kustombrad's Avatar
Yo Rude, thanks for the link! If I ever see something I like with the taillights, I'll post it! Had a good weekend with the truck. Saturday was the maiden voyage of "No Bucks"! Alex and myself took it for a little 2 mile cruise just to see how it finally came together. Was pretty uneventful and almost surreal cruising it around the neighborhood! Spent the rest of the weekend working on the interior and stereo stuff. It's slowly coming together!
It's all about the stance, baby!
http://67-72chevytrucks.com/vboard/s...d.php?t=320546
kustombrad is offline   Reply With Quote
Old 09-19-2011, 04:15 PM   #354
Intimidator
Awesome! Love the truck man! Great job!
Always good to hear of a Maiden Voyage with no issues!!!!!!!!!!!!!!!!!!!
Old 09-19-2011, 11:05 PM   #355
69CST-V
69CST-V's Avatar
You make cheap look priceless. Nice work just read the whole thread. Very cool.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 09-20-2011, 01:08 AM   #356
OrrieG
OrrieG's Avatar
Good to hear its on the road. I'm firing my engine next weekend. Did you get the photos of the trim??
OrrieG is offline   Reply With Quote
Old 09-27-2011, 02:36 PM   #357
Elder Rogue
Elder Rogue's Avatar
Originally Posted by kustombrad View Post
I didn't take any pics of how I put this all together, but thought I should show the finished version. I wanted a stereo in the truck, but wasn't putting it under the seat or cutting a hole in the dash. So this was my idea... I'll build a panel behind it when I'm at that point, but you can see where it's going. I used a 12" hinge I picked up at OSH, took the ashtray back off, glued the front on where it was even with the front of the cover. Ashtray handle opens it. I even used some washers to kick out the bottom of the glovebox, so it was even with the other door. Here you go...
I love this ideal!
Now that you have the truck on the road how has this worked out?
Thanks,
Elder Rogue is offline   Reply With Quote
Old 09-27-2011, 03:05 PM   #358
Purec4
Purec4's Avatar
Just too cool, great idea; may have to borrow it myself when the time comes.
Purec4 is offline   Reply With Quote
Old 09-27-2011, 04:31 PM   #359
kustombrad
kustombrad's Avatar
Its not on the road yet but its getting closer! Lots of detail stuff now! Trying to finish up all the interior stuff and then I'm driving it!
Old 10-03-2011, 12:29 PM   #360
kustombrad
kustombrad's Avatar
Wow, what a great weekend! Fixed a couple more little issues and got to put another 5 miles or so on the truck and helped Alex get a bunch of stuff done on his truck! It's too fun cruising this thing around! I'm still working on the interior and stereo stuff, so it's not a driver just yet. I was trying to figure out how to run my speaker wire without it pinching the wires as the door closes. I saw a friends truck and the kit they used but me being the cheap-ass did the same thing with very little money. Went to the hardware store and picked up a (1) Screendoor spring 16"x9/16" (2) 7/8" plastic hole plugs and a couple of rubber grommets. You'll notice I took my die grinder and made a hole in the plastic plug, this is where the spring will slide through. I cut the spring in half so I have an 8" chunk for each side. I should have taken more pics, so I'll have to explain. I drilled a hole in the door jamb about 3" up from the lower hinge hole 3/4" from the inside edge of the door. After taking the die grinder to open the hole up to fit the plastic plug, I got inside the truck, closed the door and reached through the access hole to use my sharpie and trace the hole I drilled onto the door jamb. Now the holes line up. I took my plastic plug that I'd drilled out so the spring slides smoothly through it and glued it to the door hole. I then finished opening up the door jamp hole to fit the rubber grommet that has a 9/16" ID (same size as the spring diameter) and installed the grommet. I wrapped a couple turns of electrical tape around the first 2" of spring so it would fit snug into the the grommet and put the other end of the spring into the door. When you close the door the spring stays tight in the jamb, but glides smoothly into the door so the wires don't pinch! Less than $10 in the whole deal and it works great. I actually trimmed the tape so you couldn't see it and put a little dab of weatherstrip adhesive on the grommet and spring so it wont go anywhere. Here's how it works and I'm sorry about the compressor noise!
Old 10-03-2011, 07:55 PM   #361
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
To COOL!
ChuckDriver is offline   Reply With Quote
Old 10-04-2011, 09:18 AM   #362
65Pickup
65Pickup's Avatar
Yup wicked ingenuity.
65Pickup is offline   Reply With Quote
Old 10-04-2011, 11:12 AM   #363
Kim57
Kim57's Avatar
Very slick mod.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-04-2011, 11:27 AM   #364
Purec4
Purec4's Avatar
Originally Posted by Elder Rogue View Post
I love this ideal!
Thanks,
Love the idea,,,,,, but cant steal the idea for my 54 bummerrrrrrrr
Old 10-05-2011, 01:45 PM   #365
chevyrestoguy
chevyrestoguy's Avatar
If you like that mod, just wait until you see what he's done lately to the rest of the interior. You guys are going to flip.
That's all I'm going to say for now................
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-05-2011, 10:58 PM   #366
Dan in Pasadena
Dan in Pasadena's Avatar
Okay, then let's SEE it!
Dan in Pasadena is offline   Reply With Quote
Old 10-06-2011, 12:56 AM   #367
OrrieG
OrrieG's Avatar
OK, I got the mini trampoline ready, lets go Brad......
Old 10-13-2011, 11:09 AM   #368
kustombrad
kustombrad's Avatar
Here's another little no money deal I just finished. I installed my new/old distributor and coil after yanking out the HEI. I couldn't find the plug wire looms I was looking for, so I whipped up something to get me by until I find what I want. I took some 1/4" washers, welded them together and then flattened the weld with a sledge hammer . After painting them black I installed them on the bottom 2 bolts of the valve covers. I routed my wiring before cutting the wires to fit and seperated them with black zip-ties. I cut a couple small chunks of 3/8" fuel line, split it and put the wires inside before zipping them to the washers bolted to the covers It's very simple and pretty much free!
Old 10-13-2011, 12:25 PM   #369
Purec4
Purec4's Avatar
Very clean look, me I'd leave them. Simple. old school look and NO BLING!
We lust for what we want, weep for what we need...
Old 10-13-2011, 12:25 PM   #370
Purec4
Purec4's Avatar
Very clean look, me I'd leave them. Simple. old school look (if we'd had zip ties back then) and NO BLING!
Old 10-24-2011, 01:44 PM   #371
kustombrad
kustombrad's Avatar
More little tricks! Here's how I setup the heater control; I used a choke cable and a water control valve from a motorhome that I scored at Pick and Plunder! When the knob is pushed in, the water flow is shut off (no heat) and it's opened when pulled out Notice I avoided the normal and used tophat style guitar knobs for the dash stuff! Here's the valve on the heater hose
Old 10-24-2011, 01:55 PM   #372
kustombrad
kustombrad's Avatar
Here's my throttle pedal idea that works really well. The truck had a linkage from an early-mid 60's Chevy truck, so I decided to go with it. By design the rod rubs on the back of the pedal, it works but could be way smoother. I took a flat chunk of 16 gauge sheetmetal and fastened in to the back of my Cal Custom "Foot" pedal for both the "hinge" and pressure point of the pedal. I then proceded to weld a bolt at a 90 degree angle from the rod in order to use a skateboard wheel bearing, so it would roll easily on the flat piece of sheet and not drag I works awesome and is smooth as butter!!
Old 10-24-2011, 02:03 PM   #373
Dan in Pasadena
You ARE the Master of Mickey Mouse - but I mean it in the most complimentary and an EXCELLENT way! The more I see of your truck, the more I like it.
Old 10-24-2011, 02:37 PM   #374
Kim57
Kim57's Avatar
Very cool stuff.
Kim
My build thread
Old 10-24-2011, 03:21 PM   #375
Purec4
Purec4's Avatar
Dude, you are too much! great work
