#351 |
Re: No Limit '72 C-10
Loved the video. I figured it would get crowded in the back with all the modifications and it looks like it does but still very doable and not as bad as some late model cars. Did you use 2 1/2" exhaust? Are there any plans for further development on the C10 chassis?
Thanks again for all the info,
Jack Byrd '70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4 '76 Airstream Argosy MH(want a longer one), 454CID, TH400 |
#352 |
![]() Join Date: Jul 2010
Yes, the exhaust is 2 1/2". The air-ride swap was a big win. smoother ride, and now it won't be dragging the plate when we load it up with parts. Using the 9000 style slider bag makes it a softer ride that the 2500 boudle bellows bags have, BUT, the ride height of the bag is taller. 9.25" vs. 6.5", so, if your trying to drop it without the frame work, these won't go as low. 4.25" vs. 3.25" colapsed. This project has been a big learning tool for us at No Limit, and will be responsible for some great new products and developments very soon. I'll keep you posted.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#353 |
Did you ever get the opportunity to run the numbers to see what would happen if you sectioned the entire front cross member to lower the front and increase the camber gain?
Thanks,
#354 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#355 |
![]() Join Date: May 2011
This build and the “make it handle” thread have been the most influential information on the board for me and I want to say thank you! Just so I have this clear, and I am sure others are curious as well, with the 4" of kick to the frame and the 2" blocks this truck sits 6" lower in the rear than stock, or do the 9000 bags lower the truck even more?
#356 |
The 9000 bag on Ridetech bolt in mounts sits 2" lower than stock at ride height. That is the same as the spring we had. The JT sits appx 8" lower in the rear. 4" from frame mod, 2" block, 2" from bag/spring.
We did some basic plotting og camber gain/steering geometry on the lines of just sectioning the lower crossmember 2". This puts the upper arm at a pretty steep angle at RH. First problem was bumpsteer, this is fixable by bending the idler and pitman arms to adjust the inner pivit points. Next, the rear problem, this moves the Instant Center inboard a good ways, and raises the Roll Center causing more 'push'. But the real problem is that the IC moves all over the place during suspension travel, and the RC shifts left/right in a corner - thats bad. So, didn't pursue this to far, at this point the drive quality is heading down a rocky trail, and only going to get worse. if you section a crossmember, you should move all the mounting points.
#357 |
.....I'm sure you will figure it out....can't wait to see whats next!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#358 | |
Thanks,
#359 |
The reason for going 2" on the section is that the first thought of doing this is usually to drop the truck. so, a 3/4" section isn't done too much - it's a lot of work for a 3/4" drop. I was trying to see what would happen if the common mod was done just a bit different. As I am writing this, I am thinking I need to re-visit this. If your doing the section, perhaps 2" on the lower side, and 1 1/4" on the upper side. This would close up the hieght between the upper and lower arm mounts by appx 3/4" - hmm...
#360 | |
#361 |
Still plays with trucks
Thanks for the great build and for all the new parts you developed for our trucks because of it. Keep it up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#362 |
Updates
#363 |
67cheby
![]() Join Date: Sep 2008
Sweet
Posted via Mobile Device |
#364 |
More updates
#365 |
needs more $$$
^ Fender rolling?...
1970 2wd Blazer |
#366 |
Yep, the old way. We put the spacers on to check clearance for wider wheels. Also, we wanted to check the handling with the wider track. So, next week we're going back to the track for some testing. I'm not a big fan of spacers, these are billit, well made, so we'll see. I do like the look.
#367 | |
I don't see how the 2" + 1 1/4" will give you 3/4". Posted via Mobile Device
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#368 |
Rob might correct me, but I think he meant sectioning the crossmember 2" and moving the upper arm pivot up 1.25" which makes it to where the upper and lower pivots only move 3/4" closer to one another and you gain the full 2" of ground clearance plus an increase in camber gain
Pro Touring 1964 C10-Under Construction ![]() Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
#369 |
Well that makes much more sense, thanks.
And if you were to section the whole crossmember 2" wouldn't that also lower the coils upper mount the same, eliminating any drop you were trying to achieve? So it would still be best to section inbetween the uca mounts, correct? And then you could just lower the uca mounting points the 3/4"? Posted via Mobile Device
#370 |
Depending on how you section the cross member.....yeah. In my opinion, I would just notch the frame rails 2" to allow the crossmember to be moved up and just lower the uca mounts 3/4"......probably have to notch the crossmember for oil pan (and possibly balancer) clearance so that you can keep the engine as low as possible.......
#371 | |
#372 | |
Thanks,
#373 |
Got another one......
Once you drop the uca mount X" and if you decide to narrow the track width by removing X amount from the lca or a custom lca, will that have a negative effect? Posted via Mobile Device
#374 |
We may be going a bit far here. I'm not a big fan of narrowing arms. If this is just for wheel/tire clearance, get a wheel with more backspace. Narrowing the track to get this done tends to have negative effects on everything else, so, i'd stay away from that if I could.
#375 |
Thought so, thanks Rob
Tags |
1972 chevy, c-10, no limit engineering |
