Old 09-14-2011, 10:36 PM   #351
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1966 SBBW pro street
I think you can get a better look at it from this picture too.....you can see the seat mounts and all of the bars they hang off of...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 09-14-2011, 10:46 PM   #352
wutnxt
Originally Posted by chad64chevy View Post
LMAO ***...ya but it's been a long wrench pulling nuckle busting summer dude...I pulled more wrench in this summer then I did all of last year....funny bit of info is we drank more beer this summer then we did all of last year too....intresting huh ...
now thats funny!! so any idea on a color or still thinking about it?? and i got a question about the brace by the door opening? you said it took forever to get into, would it be track safe to do like an s bar? instead of a slated straight piece that you have in there now! that way it would be a lil easier to get into!! jmo!!
Thinking that original color that was on the cab in the begining....high gloss...some flake......and a white side strip with a pearl in it.....but haven't done any samples yet..
When i said it took forever dude....i ment that it's been a long time since my butt was in the truck not that it was difficult to get into.
You can't really do a S bar if you want to pass tech at the track because the drivers side bar has to fit to each driver..( passanger bar isn't even required just wanted it to match )....so if you taller that side bar would have to be higher...plus it also helps that when I get into the truck it would be bagged down and about a 1" off the ground so your stepping down into the seats....
plus....I will be running the " Quick " steering wheel kit...the kind that just pop off and snap back on.
Old 09-14-2011, 11:04 PM   #353
hotrod1
56 - autocross
hotrod1's Avatar
Yeah, can see some of it. Thanks for the clarification. Would always like to see more pictures. I am doing a cage as well and am at the same spot of figuring out how to mount the seats. Also working on outrigger (to the frame) designs. What did you do for the outriggers?
hotrod1 is offline   Reply With Quote
Old 09-14-2011, 11:17 PM   #354
wutnxt
If i get a chance tomorrow i will see if i can take some more cage pictures for you.....The outriggers come right off of the boxed chassis and are 2"x3" steel on edge that come up from the frame and right to the pads that the cage bolt too....I think if i were to do it again if your cab mount brackets have any rust at all...You really don't need them because those outriggers actually carry the entire cab anyhow if ya follow what i am saying. Basically if you use the cab mounts and the outriggers ( thats what i did ) you end up with 8 cab to chassis mounts instead of the four....not that it's bad to have extra
Old 09-14-2011, 11:42 PM   #355
Dinos63
chevy only
Dinos63's Avatar
Originally Posted by wutnxt View Post
Ya know your a redneck when......
I cut the grass in the "field of dreams " and found 4 more 64 to 66's.....and a 1972 longhorn ....lol....shakes my head
shhh i am good at cut-n grass but never find any c10s
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 09-15-2011, 12:00 AM   #356
wutnxt
Well i was in hopes of finding a mint big back window cab and a extra fleetside short box....but that was a bust.....I have a sweet short box chassis ready to go and could have used a cab and box...but I guess thats going to have to wait for a while....this prostreet project has killed the money tree's i had planted last year...lol
Old 09-15-2011, 12:18 AM   #357
chad64chevy
chad64chevy's Avatar
ok i wasnt for sure how they do things at the track but i have seen some like that! and i was just wondering!
chad64chevy is offline   Reply With Quote
Old 09-15-2011, 12:54 AM   #358
65Pickup
65Pickup's Avatar
Hey Wutnxt great roll cage work, I love this truck. Have you put any thought to how much horsepower it will take to run a given E.T and checked the NHRA Regs? Your fabricator looks like he knows plenty, so I'll continue hoping not to be talking to Austin Coil or something, 565 hp will put a 3700 lb truck @ about a 12sec e.t. An 11.5 only requires a roll bar. Here's a link to play with, not sure which horsepower it uses but I use both, dyno hp and -20% for drive train loss.
NHRA rules change at 10.5 and 9.5 etc, each second milestone = more bars on your cage. Getting in the 10's let alone the 9's takes serious power.
How much horsepower are you hoping for???
http://www.wallaceracing.com/accel-calc.php
65Pickup is offline   Reply With Quote
Old 09-15-2011, 07:29 AM   #359
shortbed70
shortbed70's Avatar
Dude the trucks looking nice! Question though, how do you get the bed off with the cage there? What color you plan on painting that thing?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-15-2011, 11:05 AM   #360
Dinos63
chevy only
Dinos63's Avatar
Old 09-15-2011, 12:03 PM   #361
wutnxt
The chassis and the cage are both NHRA approved.....there is no problem with any of that...
HP is another thing altogether.....I have alot of options there, so I started with a big bottom end to allow for lots of add on. So depending on how we drive the blower they figure if they underdriver the blower....detune it...It would start out around 600HP ish to the rear...Which is probaly where i will start it at to do a break in and get used to it. What it's able to do on the top side is alot more but i think we will wait until I get to the dyno stage before I start tossing those numbers around. But the plan is after it's broke in and running, to up the drives on the blower and hit it with a nitrous set up.
But we will see....I have already ran all the numbers and had them checked at the engine shop and by my chassis buddy......but at this point they are all numbers....I might never take it to the track and be totally happy with where we start out at....it's a play be ear kind of thing at this point
Old 09-15-2011, 12:07 PM   #362
wutnxt
Well the front panel of the box comes off from the inside box side.....then the box is unbolted from it's mounts.....there is a rolled pan between the cage in the box and the front box panel that comes out....and after the batteries and fuel cell are delt with it sides off to the back of the truck.....Ya it's a bit of a pain but after it's all done and painted i shouldn't have to take it off for a long.....long time....crosses my fingers
Not sure yet what color but i am working on it....lol
Old 09-16-2011, 07:25 PM   #363
wutnxt
This what it looks like looking from drivers door to the other door......along the floor and the seats mount to the bar you can see
Old 09-16-2011, 07:34 PM   #364
wutnxt
front bar pad mounting to the bottom of the cab....and then to the pad underneath the cab...
Old 09-16-2011, 07:38 PM   #365
wutnxt
The clip massaged to fit the lowered and pushed back BBC and blower drive..
" Sexy up front "
Old 09-16-2011, 07:39 PM   #366
hotrod1
56 - autocross
hotrod1's Avatar
this is nice! Keep um coming.
There just are not many pictures of cage installs that are done nicely. It is great to see this to get ideas.
Thanks!
Old 09-16-2011, 07:41 PM   #367
wutnxt
" Business in the back "
Old 09-16-2011, 07:43 PM   #368
hotrod1
56 - autocross
hotrod1's Avatar
what did you do for the outriggers? Any pictures?
Old 09-16-2011, 07:44 PM   #369
wutnxt
front panel
Old 09-16-2011, 07:45 PM   #370
wutnxt
2x3 tube....no pictures....maybe when i move it the body shop early next week
Old 09-16-2011, 07:48 PM   #371
Dinos63
chevy only
Dinos63's Avatar
wow .... wow holy shhhhhh , game over very cool
Old 09-16-2011, 07:48 PM   #372
chad64chevy
so are you going to do the rest of the bed the same as the middle between the wheel tubs??
Old 09-16-2011, 07:52 PM   #373
wutnxt
Dude I wish the game was over....lol....feels like I am only half done
Old 09-16-2011, 07:54 PM   #374
wutnxt
Well I made all of the oak kits for my other trucks....so I was thinking of doing oak in the very front and oak if the very back.....and uhm....Well I am considering having the center section air brushed to match the oak floor I put in......but still not sure on that one yet
Old 09-16-2011, 07:59 PM   #375
wutnxt
Getting ready to do the rough exhaust work....
Thinking of going with 2"tube short fender headers that run to a 4" collector
and then dumping the 4" right out throught the side of the box infront of the tires.....still thinking flamer throwers in'em.....cause secretly I think I am still a kid....lol
