Old 01-27-2013, 10:53 PM   #351
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Looking better all the time! Were you after an in-bed fuel neck cover?
Old 01-28-2013, 12:23 AM   #352
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I was kind of looking for one. if i cant find one, ill make one. i was going to use the GM method of filling the auxiliary tanks for making my filler for the rear tank
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-28-2013, 09:53 AM   #353
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Ryan
I believe I have an extra.....will check
Old 01-28-2013, 08:20 PM   #354
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Looking good! Are you getting the other box?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-28-2013, 10:16 PM   #355
ryanroo
ryanroo's Avatar
Re: 72 k20 project
thanks Pete!
Ryan, i think i will buy it. it just has to little damage not to. but i think i will just end up swapping the sides onto my steel floor. i can make the wood floor work, but im not sure its work the hassle. i need to unload the scrap on my trailer and get the cab to the blaster/bodyguy. then i can have some space to load up another bed... plus where its located in the guys field, i would much rather wait till its dry or really frozen to go get it.
Ryan
72 K20 12v build
Old 01-29-2013, 12:19 AM   #356
Dieselwrencher
Re: 72 k20 project
Oh man, go give the Jeep a work out! I opted to go steel floor in mine because I knew I'd be hauling 1100lb or heavier engines. A lot.
Ryan
Old 02-03-2013, 09:41 PM   #357
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i made the cab an a/c almost completely. i dont have a good template for the center vent, and no vent to work from either.
and the other side
i also got the firewall mostly cleaned up. i think its done out here. its not a show car type deal, but with the 12v in there youll never see it
i also spent some time measuring and postulating on the rear 4 link. i have a decent idea where i am going, but i need the bags first.
Ryan
72 K20 12v build
Old 02-03-2013, 11:32 PM   #358
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Lookin' good - I can trace out the center vent on mine and send it if that helps and you're in no big rush.
Old 02-04-2013, 12:08 AM   #359
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Sure. Not really rushing, but i hope to get it loaded up and hauled to the blaster soon. Then on to the painter. One day i hope to have pretty pictures to post like you!
72 K20 12v build
Old 02-04-2013, 12:14 AM   #360
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
You will and unlike myself will be able to brag about the excellent work you put into the build....will get that traced out for you this week when I can get to the shop.
Old 02-04-2013, 12:46 AM   #361
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Here this may help: http://67-72chevytrucks.com/vboard/s...&postcount=674
Maybe he could send you a copy of that template.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-04-2013, 12:48 AM   #362
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks Pete!
72 K20 12v build
Old 02-07-2013, 09:29 PM   #363
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i wonder if that is the same as a OEM center vent? the hole is a little different.
anyhow, i have started designing the 4 link and i ordered a stick of 2" .250 wall DOM. i also got a stick of 1" .120 wall for some other stuff. now, i need to order the rod ends, but i have not fully decided what i am using. either way, thats gonna hurt. i think i decided what will work best for bags too, so ill need to order those...
Ryan
72 K20 12v build
Old 02-07-2013, 09:47 PM   #364
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Are you doing dodge coils up front?
Check out this build, he does coil over with three link I think. Its pretty badass but be warned he quits at the end. http://www.cumminsforum.com/forum/cu...ew-cab-66.html
Tony
Old 02-07-2013, 11:34 PM   #365
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Big ol' bags and link rear. i hope to do the front some time in the future. right now i dont want to attack that too.
his looks cool, but, i didnt follow all the way to the end.
trying to decided if i want full rod ends, ballistic joints, EMF joints, rod ends and poly bushings, ballistic joints and poly... so many choices and i would prefer to do it once and not worry about it for a while. EMF joints are supposed to be king **** of turd Mt. but they are not cheap. a quick grand for just the joints. i dont really need tons of "twist" so im leaning towards poly on the frame end and ballistic joints at the axle. its hard to determine the best choice from all the banter on the web as to what is good and what is crap.
72 K20 12v build
Old 02-08-2013, 12:18 AM   #366
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Are you planning on making the truck articulate like a rock lizard or something closer to stock for heavy towing?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-08-2013, 01:44 AM   #367
ryanroo
ryanroo's Avatar
Re: 72 k20 project
no real need for the super articulation. it wont even have the travel to accomplish that. i just want strong and durable. i dont care what people say about "road vibrations" it has a cummins on poly mounts, so im sure ill feel a few vibrations. biggest concern i have is the quickness of rod ends going to rattles. i run them on my steering religiously and dont have any issues, but ive never had them on a suspension. since it will be a parallel w/panhard, i dont want any binding from side to side to cause undue or early wear either. i'm sure i am worrying over nothing. i'm pretty sure i'll end up doing 1 1/4" rod ends or half and half with the ballistic poly ends on the frame. i will probably do poly on both sides of the panhard.
all this research has me convinced of one thing. when i link the rear of my jeep, i will be using the EMFs if i can afford them at the time. they are BA. plus it will be triangulated so i will only need to buy 8
72 K20 12v build
Old 02-09-2013, 04:23 PM   #368
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 72 k20 project
I just found your build, I haven't been real active on the board lately.
Looks like you are building one hell of a nice truck. There are getting to be a lot of us stuffing 12 valves in these things and I think it is a good thing.
I like what you did with your core support, I will probably be doing something similar with mine.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 02-09-2013, 04:36 PM   #369
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i am happy with the core support. i think a lot of people thought i was Krazy at first, but in the end it is exactly what i wanted and its more sturdy than the original i think
i am excited to get this link/bag set up done. the weather here isnt cooperating with my attempts to get the cab blasted and to the painter, so i have some time to twiddle my thumbs and design...
ryan
72 K20 12v build
Old 02-10-2013, 08:29 PM   #370
ryanroo
ryanroo's Avatar
Re: 72 k20 project
my eyes and fingers are bleeding. not done yet. provided my development is correct, all i have left to draw is the upper bag mount and the disks for the piston and bead plate. after all that, ill still have to do the panhard and shock mounts
72 K20 12v build
Old 02-10-2013, 09:13 PM   #371
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 72 k20 project
What version of Autocad are you using?
Old 02-10-2013, 10:24 PM   #372
ryanroo
ryanroo's Avatar
Re: 72 k20 project
really really old. one step up from pencil and paper...
its AC98lte. i cant gripe since i got it gratis. i almost bought inventor13 late last year, but decided not to. i might go ahead and do it, but i really dont want to run it on my laptop. its the only machine i have that is 64 bit.
anyhow, i got all the stuff mostly drawn. hopefully i can get some of it cut this week
Ryan
72 K20 12v build
Old 02-10-2013, 10:37 PM   #373
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: 72 k20 project
Ryan
I am running 2010 Mechanical, and it is freaking amazing. I absolutely love working with it.
What is the brand of plasma cutter you are using?
I have been eyeballing a torch mate for quite some time. As well I saw that Hypertherm is coming out with a Laser so I am going to be very interested to see how that works because it will mean being able to do engraving as well.
Old 02-11-2013, 02:20 PM   #374
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 72 k20 project
Ryan, Have you used Solidworks? I use it all the time for work projects. I love it for anything 3d. I assume the CNC equipment you work with can use one of the export options to work off of directly?
Recently I modeled some parts and send them to a CNC multiaxis mill and voila, a fully functional 3d part was made. Pretty cool stuff.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-11-2013, 09:47 PM   #375
ryanroo
ryanroo's Avatar
Re: 72 k20 project
we were on 2010 at work until last year when they stepped up to 12 and then 13 with the full inventor suite. i really wish i had a newer program but i dont want to buy a newer 2d program for home without having a 3d program too. id love to get a 5-8 year old version of inventor as that is what i learned on and loved it. like i said, i may just go for it and buy the inventor 13lte program.
i cut all my stuff at work. we have a choice between a 6'x12' messer table and control with an HD 100a hypertherm and a 200a hypertherm powersource, or a 6'x12' Flow waterjet table. i havent learned the Flow yet, so i plasma most of my stuff. its faster anyhow for parts that dont particularly need perfect edges and +/- .001 tolerances. i have the settings dialed in for 7ga and .250" on the hypertherm anyhow.
i have been shopping the torchmate website too. i dont have much room at home so id really like the 2'x2' just to make my brackets at home and to play around. i know you can piggyback a scribe/engraver on most of the torchmate stuff, but laser engraving is really nice. lasers are huge power hogs though and require you have gas for them as well. for me at home i would go with a hypertherm 45 or 65 and a torchmate and be totally happy.
i have never worked in solidworks, but i have heard its pretty good to work with. i would like to try it out sometime but all of our stuff at work is autocad based and it is nice to have the easy compatibility. there is talk of a multiaxis mill coming to play at work, and i would love that ability. draw, push print, part made of metal. a buddy of mine is an instructor for the local comm. college machining course. hes the one who taught me how to be a hack machinist. some of the stuff he can make is pretty sweet.
our waterjet is pretty much a point and shoot affair with the inventor program. the Messer is old and isnt updated to newer versions because everyone knows how this one works. best not change or we'd have a meltdown of civility. i am sure it could be set up that way now, but it still uses the OLD SDS system to convert to cutpath.
72 K20 12v build
