#351 |
![]() Join Date: Aug 2012
Re: Rustbuket 67 build "Georgia"
I can see the up grade on the spring holders. Mine did not have the nuts only a hole. I did not thing of welding nuts like you did . I used a long bolt and lock washer and nut.
#352 |
Loving what you did on the rearend. Looks great. Also good idea on the spring holders.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#353 |
![]() Join Date: Mar 2011
Nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#354 |
Lots of hard work on this one, great job so far!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
#355 |
I wish I was as meticulous as you are with your build. I get to impatient.
I'm going to assemble my engine Christmas weekend, I'll swing by sometime within the week to borrow those tools.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#356 |
Man of Mini-Talents
Ok Dan, what's the secret to posting a pic with the iPhone?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#357 | ||||
Thanks MJ!
Thanks Jim! Thanks, I love your project. All the fancy race car parts and the 4ott setup still blows my mind. You definitely think outside the mail order catalog. Quote:
![]() ![]() Quote:
Update with pics coming right up!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#358 |
Okay I re-re-did my patch job welding on the frame and cut some box plates with our plasma at work, welded them in.
#359 |
Frame boxing and smoothed, primer...
#360 |
I painted all the overlapping surfaces with flat black and torqued the front suspension crossmember and trans crossmember to the frame. I used the assembly manual and it says 55-75 lbs ft so Itorqued them to 70 lb ft. I could not find anything for the trans crossmember and the bolts included by GMC Pauls are grade 5 so I left them at 40 lb ft untill I find some other specs.
#361 |
First coat of paint. I am going to repaint the front crossmember gloss like the rest but I did not paint in front of it or the rear past the shock crossmember because I have more welding to do....
#362 |
Second coat. This is Tractor Supply farm and implement paint, alkyd enamel. Thick, hard, and shiny! Had my frame been in better shape and if I had fixed all the little problems before I would have much rather had it powdercoated, live and learn. It was getting dark so the pics are pretty poor as far as the lighting goes.
#363 |
I also cut the rivets for the pan hard (or track bar, what ever you want to call it), the shock mounts, and the front cross member so I can mount my sway bar brackets and I managed to fubar that job so the crossmember will be coming out so I can remove whats left of the rivets. I will be opening boxes of NEW parts very soon and ordering some more, next order will be a tracking bar from Porterbuilt
#364 |
Glad to see it moving forward. Looks like some fine work there!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
#365 | |
Mmmmm Both, Originally I started with rolling and brushing with matte black then decided I liked the gloss better. I was going to use my spray gun but researched the paints msds and could not find any chemical difference in spray can vs quarts so I did the gloss in spray cans (convenience issue ![]() http://tsc.tractorsupply.com/search#...&sliredirect=1
#366 |
Looks good Dan. I think i will try that paint on mine. Does it come in any other colors than black?
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#367 | |
#368 |
I worked on mine a little today. Maybe soon I can get a few parts on the frame to the paint stage.
#369 |
Frame is looking great, nice job...Jim
#370 | |
Man of Mini-Talents
![]() ![]() Posted via Mental Telepathy
#371 | |
#372 |
Still Learning
Looking good Dan! Keep the pics coming
Posted via Mobile Device |
#373 |
Frame looks good.
#374 |
Laid Back
![]() Join Date: Apr 2010
Looking good!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#375 |
Looks good! I made the mistake of painting a frame yellow one time........ Ended up sandblasting that amarillo crap off and painting black later hahaha
