#351 |
Re: How about some pics of Static dropped 60-66
It kind of belong over here. I am still work in progress on building my truck with static drop and would like to see how it will turn out to give me some motivation along the way... As I measured frame mounts and transfer it to cab I have 8" clearance from lowest part of side cab outer rocker bottom lip. Any of you have side pic of truck with this side clearance? 64 fleatside SWB. Might go down some more, now was only frame with drivetrain.
#352 | |
#353 |
#354 |
![]() Join Date: Nov 2010
63's
LIFE IS SHORT HAVE FUN |
#355 |
Not completely done, still checking for leaks. Still need to put the c-notch in. Not sure what caps I'm running yet either. 5in drop springs out back with 2in blocks. 3 in drop coil and drop spindle in the front. HUGE, braking difference with the discs and booster, serious it unreal!
Posted via Mobile Device Posted via Mobile Device |
#356 |
Another pic
#357 |
nice looking truck 62
#358 |
gettin there...
Converted to power steering and hooked up the steering linkage. Gran-kids approved! rg |
#359 |
Nice work, wish mine was that clean
#360 |
Thank you Steve - "Runoleum" works wonders.
Sway bar is next then I think I'm pulling the front shock mounts to figure out the new placement like in Mark's post. rg |
#361 |
#362 |
#363 |
15x8, 235/75/15, I almost went with a bigger wheel. The rear is a non issue, my front may be an issue. Haven't been able to drive it around enough to tell yet but it's pretty close o the fender.
#364 |
Anyone else have driveshaft/pinion angle issues after adding 2 inch lowering blocks? The PO had already cut the springs, but it rode fine. Added the blocks over the weekend and the thing vibrates like hell now.
There's barely any old skools on the freeway |
#365 |
At high speeds?
#366 |
Kind of all around. Most noticeably in 3rd. I have a 4 speed with granny low, so i start in second, which is a bit rougher feeling, but 3rd is awful. 4th isnt too bad, but still not like it use to be. When I let off in 4th going around 35 or so, it sounds like something is rubbing. Been under and checked, no ssigns of either driveshaft rubbing on anything.....
#367 |
wishy they were bagged!it comin very soon
triple d |
#368 |
At the body shop.
![]() Unsure of the drop... but looked and sounded awesome Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#369 |
It looks like on of those exaggerated drawings with the big wheels that you see on t-shirts. Not Ed Roth but the newer style.
#370 | |
![]() Join Date: Mar 2012
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#371 |
nice truck greg.like the big window.im debating whether i should convert my small window to big.i like both.
#372 |
Re: How about some pics of Static dropped 59-60-66
Here's my project, before and after...getting her layed out in 2 weeks...
Front: dual-flex posie drop springs with a 3" drop axle Rear: Flipped axle with 3 leaf springs removed from the leaf pack Aim: 5" drop for the front and 7" drop to the rear Before: After: |
#373 |
Looks great! what size and brand wheels and tires are you running?
#374 |
I confused is that second photo with the 5/7 drop already done or is that photoshoped? If that is a 5/7 drop I hope you do not have any pot holes or speed bumps in your town. It must be photoshop because you have no frame rail behind your back tire only grass. That looks lower than 5/7.
#375 |
I've got a stock set of front springs and a set of jeep tj springs for the rear. How many coils do I need to cut off the stock fronts to make my truck sit level with jeep springs in the rear?
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air. |
