Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-22-2015, 10:15 AM   #351
notchbackgta
Re: 71 4X4 Frame off Restoration
Originally Posted by DWilbur View Post
The 2nd one I turned it over to push it out with air on the bench and it was a lot safer.
I usually put a small piece of 2x4 in the pad area and turn the air pressure down to about 5psi. When they go flying they usually damage the piston
notchbackgta is offline   Reply With Quote
Old 03-23-2015, 06:54 PM   #352
DWilbur
Ryan that picture is just the base coat I clear coated it Sunday. Hay swamp rat its been a while from your last post. you busy doing other things. I have been working grave yard for the last month so I get up early and work on the truck for couple hours about 3 days a week. I get most truck stuff done on the week ends. 4 Wheel parts called me today and they don't have the spindles and can't get them for about a month. I call my friend Pat to see if he can find a couple by the end of the week. Today I installed the ARP studs in the stearing knuckles and removed the seals and races from the hubs today. Only problem the hubs don't fit in my blasting cabinet. Going to see about getting gravity blasting gun at harbor Freight tomorrow so I don't have to fire up the big blasting pot.
DWilbur is offline   Reply With Quote
Old 03-23-2015, 10:59 PM   #353
swamp rat
swamp rat's Avatar
Yea i am sick of the rain and wind to say the least but am about ready to get back at it soon.
Can you order direct from these guys?? this is the brand for my D44 replacements, i didn't research a D60 tho..
http://www.yukongear.com/Spindles.aspx
Maybe just order thru someone else that can order direct? heres some links in this thread that may help?
http://67-72chevytrucks.com/vboard/s...d.php?t=129295
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-23-2015, 11:59 PM   #354
DWilbur
I ordered the spindles from ORD this afternoon. Should have them by Thursday. I almost forgot I bought a gravity spray gun from Harbor Freight about 2 months ago and used it to spray the D60 this week end and it work good. I don't think I would use it to spray body panels as the spray pattern is a heavy top and bottom. All in all not bad for inexpensive spray gun for spraying parts.
Old 03-24-2015, 07:13 AM   #355
msgross
msgross's Avatar
I used that gun to spray my home theater screen paint and it worked very well. For $15 or so you can't beat the quality, however i'd also be hesitant on spraying panels.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-24-2015, 08:11 AM   #356
Dale_Brown
What type of rear spring hangers are you using? Do they drop lower? Is this the reason you don't need the 4" block?
PS your project looks awesome!
Dale_Brown is offline   Reply With Quote
Old 03-24-2015, 04:53 PM   #357
DWilbur
I installed an rear shackle flip kit from ORD and it eliminate the 4" block. my rear springs are new stock springs.
Old 03-24-2015, 04:56 PM   #358
DWilbur
I got a call from SRS Industrial Coating today they media blasted my cab and it is ready to pick up. Now the final body work can start on the cab. bed is in primer just need final sanding and should be ready for paint.
Old 03-24-2015, 08:43 PM   #359
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the axle, and it's nice to hear your cab is moving along fairly duickly as well.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-25-2015, 12:23 AM   #360
DWilbur
Thanks for comment on the axle. My builder Sky is starting to feel his age he is about 80 years old I think he might be retiring at the end of this year it will be the 3rd time he has retired in the last 15 years. I will be lucky if I can do half of what he does if I make to 80.
Old 03-25-2015, 01:15 AM   #361
First c10
First c10's Avatar
Hey DW, is SRS in San jose? There is no one in my area that media blasts vehicles or sheet metal for vehicles. Do you mind if I ask the cost to get it done? Your only like an 1 or so away. How is there work?
Oh and sorry to hear about the flood issue.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-25-2015, 01:34 AM   #362
DWilbur
They media blasted my quad cab $4.10.00. they also do power coating and has reasonable prices. The more part you power coat it seams the cheeper it is. they are in Santa Clara off grant street. They only take cash payments and they are about 1 to 2 weeks turn around time.
Old 03-25-2015, 01:51 AM   #363
karrlogs
I salute you, sir! Restoring trucks like this is not just skill, i think it's a passion and an art. I once had rust issues under my truck and even on my bed, i had to use phosphoric acid solution to get the corrosion and rust out. Took me almost a week (thankfully the weather was dry and i had a spacious shed, i do not have all the time in the world to do it in one day). In any case, my bed held up pretty alright.
Great to see your build coming along. Great job!
karrlogs is offline   Reply With Quote
Old 03-26-2015, 04:22 PM   #364
DWilbur
I media blasted 1 of my front hub with gravity blasting gun from Harbor Freight today it worked ok uses a lot of air and took about 23 lbs of media. My cab was media blasted and I picked it up and dropped it off at Sky's shop he will start the finish body work next week.
Old 03-26-2015, 06:38 PM   #365
ole dollor
ole dollor's Avatar
dang that's going to look great....
ole dollor is offline   Reply With Quote
Old 04-03-2015, 04:47 PM   #366
DWilbur
I finished prepping all the parts for my Dana 60 front axle today. Had to buy new rotors as they old ones were .0200 under minimum. got new U joints installed in the right and left axle shafts. Now I just have to put it all back together. I finally got my new steering gear from O.R.D. it took about 2 moths. It is set up for hydro assist steering.
Old 04-03-2015, 10:58 PM   #367
swamp rat
swamp rat's Avatar
I may be wrong but i thought Hydro assist was the early 67 version of power steering? the setup where there is a hydralic ram affixed to the tie rod.. If thats the case i'm not sure what the benifit would be over a more modern 3.5 to 1 ratio like you can get from readhead steering?
http://www.redheadsteeringgears.com/
The axles look sweet, cant wait to see that cab in paint!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-03-2015, 11:54 PM   #368
DWilbur
this is power steering with hydro assist it help with larger tires. I might step up to 38" tires if they fit in the future. for now I will not install the ram or plumbing just keep it blocked off until required.
Old 04-04-2015, 02:21 AM   #369
swamp rat
swamp rat's Avatar
Oh, they have it so you have the best of both worlds, nice to know. Thats why i hang out here so i learn stuff! thanks.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-05-2015, 01:04 AM   #370
Dieselwrencher
Nice parts there!
Ryan
Old 04-08-2015, 03:47 PM   #371
DWilbur
Some pictures of the Dana 60 going back together. it was a pita putting the high steer parts on was supper tight fit. I hope I don't have to take it apart any time soon. Just have to install the wheel bearing and install the axle in the truck this week end.
Old 04-09-2015, 12:40 AM   #372
swamp rat
swamp rat's Avatar
Nice lokin D60! Nice stand too!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-09-2015, 12:50 AM   #373
First c10
First c10's Avatar
Nice looking. When my truck grows up I hope it's like yours!!!
GO GO!!!
Old 04-09-2015, 01:26 AM   #374
DWilbur
Thanks for complements. I built the stand about a year ago the wheels are to small with both axles on it after I install the D60 I'm going to replace the wheel with 5" one's to make it easier to roll around. I still have the stock D44 and HO72. First C10 the truck your building with your son is looking dam good to
Old 04-09-2015, 09:10 AM   #375
ryanroo
ryanroo's Avatar
Looks great! i really like watching stuff go together with such focus on details.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
