Old 08-25-2010, 10:55 PM   #376
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: It’s Just A Pickup
wow.....guess I'll be waiting a bit longer for paint!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-26-2010, 12:53 AM   #377
BigSky71
LAIDOUT
BigSky71's Avatar
Thank you for the detailed write up on the body shop hunt and selection process. Also congratulations on finding a shop that will let you do some of the work during the process, that imo is a tall order.
I look forward to the updates!
Fwiw, in my corner of NW Montana I can think of only a few "one man body shops" that would even consider the type of arrangement you have worked out. I hope all goes smoothly and can't wait to see your truck in paint.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 09-02-2010, 06:37 PM   #378
Bruce88
Bruce88's Avatar
Not a lot of difference that I can tell
The teardown continues and building a list of parts I need to order
As I remove all the inner parts from the old 72 doors, I found that the previous owner had tried to covert the inner panel to a 67-71 metal door panel and armrest from some other vehicle. I also have some doors from a 70 that I picked up a number of years ago for parts (the inner side of the door shell was hacked up real bad and the outer skin had many holes).
I’m going to put the 4 door shells up in the parts section for free to any one in my area that wants to pick them up and wants to build their welding and metal working skills. They definitely need work to bring them back from the recycle scrap metal but it can be done and I think the price is right (free) (smile). Hears the link if your interested http://67-72chevytrucks.com/vboard/s...d.php?t=419593
The only difference that I found between the 67-71 door shells and the 72 door shell is the screw up by the vent window and how the inside panel is attached to the door. The internal parts have some differences manly relating to the inside panel that is being used.
After disassembling 4 doors I found it an advantage in having some special tools that make the job easer. An impact gun with a #3 phillips tip makes it easy to remove the tight screws, just lean into it to seat the tip, a short blast and the screws will loosen up with out stripping the head. And the infamous door handle removal tool. Not to say it can’t be done with out them it’s just less frustrating, time consuming and help prevent damaged screw heads that would need to be drilled out.
Planning on making the inside door panel a flat 67-71 stile door panel with a custom cover that will match my seats material. Some of the internal parts will have to be replaced to make it look right and others rebuilt.
My vent window frame is rusted thru in some spots and will be rebuilding the 70 door vent window. Found a good (how to) on this forum for rebuilding the vent window (Hears the link if your interested) http://67-72chevytrucks.com/vboard/s...d.php?t=351471
All the 67-72 vent window assemblies can be used in any of the doors for those years. Some differences that can be found, clear or tinted glass, painted or chromed frames, and different handles for the vent window (67 handle attached to the window frame and 68-72 handle attached thru a hole in the glass and possibly two different style handles).
Latch control differences, the 68-71 are shorter than the 72 and are interchangeable depending on what door panel you’re using. The 67 I’m not sure what the difference is (possibly the handle used). Side note, all the Latch Controls that I have, have broken return springs (another item that Ill need to order).
Window regulator differences, the 67-71 are shorter than the 72 and are interchangeable depending on what door panel you’re using.
All the rest of the door internal parts appear to be the same on the 67-72 truck models.
Generated a door panel design for the cover over the 67-71 steel panels that I have. Took the design down to the upholstery shop to be made out of the same material as the seats (the shop said no problem to make the door panels). The picture below is not a match to the fabric on the seats just a pattern design, if your interested what the material will look like see (post #25) on this build thread http://67-72chevytrucks.com/vboard/s...d.php?t=318544 . Door panels should be back in a few weeks.
I’m looking forward to the interior being installed, but probably not my cat she seams to like the seats as a perfect place for a nap (smile). Of course this will be some time down the road after body and paint.
Body and paint update, parts are expected back in the shop on 3 Sep from media blasting, it’s moving forward
Enjoy your build
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 09-02-2010, 07:20 PM   #379
VA72C10
VA72C10
VA72C10's Avatar
Great info as usual....glad the body work seems to be moving along...hope the parts come back good and progress keeps up!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-02-2010, 07:48 PM   #380
msgross
msgross's Avatar
1968 Dark Green #505... mine was repainted once though... I'm thinking of going with 1969 Fathom Green though.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-02-2010, 08:00 PM   #381
glimmertwin01
glimmertwin01's Avatar
nice job as always Bruce...
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 09-02-2010, 11:27 PM   #382
mcbassin
Still Learning
mcbassin's Avatar
Thanks for the detailed shop decision process. This is something that many of us have never been through or understand. Love all the pictures and descriptions of all the parts. Your truck will be show quality when done, thanks for being modest about it (smile)
mcbassin is offline   Reply With Quote
Old 09-16-2010, 02:33 PM   #383
Bruce88
Bruce88's Avatar
Best laid plans of mice and men
O did I mention mother natures input too (smile)
The metal is back in the body and paint shop from the media blaster, with about a week delay in finding a weather window to keep it out of the rain (it’s that time of year around hear where the weather plays it’s part in planning).
This is where most of the custom body and paint shops start with a body off project to find all the cancer and prior repairs. Then it will be going into epoxy primer to prevent flash rust and creating any additional rust problems during the time it will be worked on.
All the prior inspection and rework in cutting out and replacing all the rusted metal is paying off. All the parts look to be in good shape no unexpected rework was found by me. Yes there’s plenty of small dings/dents that will need to be addressed but all in all it looks pretty good.
In the last picture you might notice that some of my parts are hanging out with a 53 – 55 Corvette body in the shop. It’s always nice to see that the shop has a wide diversity in handling the standard rework to handling the more unusual (smile)
I haven’t been standing around just praying to the body and paint gods hoping all will work out good. OK there was a week off for a break, R & R (smile). Been working on the internal door parts, rebuilding and reconditioning and will post that progress later.
Enjoy your build
Old 09-16-2010, 03:47 PM   #384
msgross
msgross's Avatar
I love freshly blasted metal... like new again.
The Garage:
Old 09-17-2010, 02:24 AM   #385
VA72C10
VA72C10
VA72C10's Avatar
looks to all be in excellent condition....look forward to the next progress update
Old 09-23-2010, 01:22 PM   #386
dmcnga
dmcnga's Avatar
Smile Re: It’s Just A Pickup
Just finished my restoration...Aren't rocker panels fun? Your truck is going to look great - congratulations! I put my '72 C-10 back to all stock, including rebuilding the original L6 250CI engine.
Can't wait to see yours when it is done!
dmcnga is offline   Reply With Quote
Old 09-23-2010, 08:27 PM   #387
Bruce88
Bruce88's Avatar
Another step forward, it’s moving on
Quick update on the body and paint
The primer been applied and tomorrow I’m going down to do the seam sealing. Looks pretty good in the primer even with none of the body filler or dent pulling done. At least it’s all one color now (smile).
Enjoy your build
Old 09-23-2010, 08:46 PM   #388
v502
v502's Avatar
Looking good. What color are painting the truck?
v502 is offline   Reply With Quote
Old 09-23-2010, 08:53 PM   #389
VA72C10
VA72C10
VA72C10's Avatar
looks AWESOME!!!!
Old 09-23-2010, 09:24 PM   #390
Bruce88
Bruce88's Avatar
GM 505 Dark Green, A stock fleet color for this year truck
Old 09-23-2010, 10:49 PM   #391
mcbassin
Still Learning
mcbassin's Avatar
Great progress! It's gonna be so nice!
Old 09-24-2010, 07:57 AM   #392
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Bruce!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-24-2010, 09:58 AM   #393
splehigh
splehigh's Avatar
Looking good!!!
splehigh is offline   Reply With Quote
Old 09-24-2010, 10:26 PM   #394
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Looking good Bruce
Is that an epoxy primer/sealer?
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 09-24-2010, 11:38 PM   #395
travlinman
big side mirrors and cab lights... u going to keep them ?
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 09-25-2010, 12:20 AM   #396
Bruce88
Bruce88's Avatar
Originally Posted by chevytruckluver View Post
Looking good Bruce
Yes it’s a epoxy primer/sealer I don’t know what brand, it’s one the body shop uses. Probably a commercial product not available to the public. I just spent 6 hours down at the shop seam sealing and was using a two part commercial seam sealer that I did not recognize by name and said it was not for sale to the public.
You’re going to have to ask msgross it’s his truck in the picture (smile). It does have the GM 505 dark green paint color on it that I will be using on my truck.
Old 09-25-2010, 12:31 AM   #397
70LonghornCST
Moderator
70LonghornCST's Avatar
Very nice work. Very motivating.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 09-25-2010, 01:37 AM   #398
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thank you for doing this build and being so detailed about what you are doing! We all really appreciate it! I really like your ideas too!
y5mgisi is offline   Reply With Quote
Old 09-28-2010, 05:38 AM   #399
Bruce88
Bruce88's Avatar
Decided to take the challenge
Definitely time consuming and could have a less than desirable outcome from what I’ve heard.
Rebuilding the vent window with new seals and repainting
After disassembly and repainting the parts that could be time consuming in it self, I came up with some tips that might help you with rebuilding the vent window yourself if you want to take the challenge. There is a good (how too) on this forum that I recommend to read in rebuilding the vent window http://67-72chevytrucks.com/vboard/s...d.php?t=351471 (my tips are a minor addition to this how too, possibly to make it a little easer).
Installing the rivets in the frame and new seal are probably the hardest task. When the vent window was assembled in the factory it was set in a tool/jig and they used a rivet squeeze to install the rivets. Not very practical for a home shop, but it can be done manually with some simple tools.
The window frame and the new seals have to be held in place before installing the rivets (glass and its frame not installed at this time). I used some cleko’s to accomplish this. One small problem was that my cleko’s are for 1/8 DIA holes and will not hold in the 5/32 DIA holes in the frame & seal. A simple solution was to use a small washer with a 1/8 DIA hole on the end of the cleko to hold the parts together.
The rivet heads are installed in the channel from the factory with the driven/clinched end on the seal side. With the rivet installed in this manor it’s hard to drive the rivet with the manual setting tool with the frame in the way. I installed the rivet head on the seal side and used a ¼ inch DIA rod held in a vise to backup the head and drive the other end with the manual setting tool in the channel.
Not many pictures included in this post, I think the above (how too) has a good set of picture showing the steps/process for rebuilding a vent window. Plus my hands where busy holding things, it’s definitely a two man job (smile).
The new parts that I’m going to be using in the door area
Note not all parts listed are seen in the pictures, possibly on a different post (smile)
03-835 Vent Rivet Tool by Classic Parts
03-825 Vent Assembly Rivets by Classic Parts
03-831 Vent Pivot Rivets by Classic Parts
18-731 Window Regulator-Left 67-71 by Classic Parts
18-732 Window Regulator-Right 67-71 by Classic Parts
18-06 Inside Door Handle 67-72 by Classic Parts
18-16 Inside Window Handle-Black Knob 67-76 by Classic Parts
18-45 Inside Handle Escutcheon-Steel 67-71 black by Classic Parts
18-835 Door Control-Left 68-71 by Classic Parts
18-836 Door Control-Right 68-71 by Classic Parts
19-951 Door Hole Plug 60-72 by Classic Parts
18-893 Door Control Rod Retainer Clips 67-72 by Classic Parts
19-645 Arm Rest-Black 69-71 by Classic Parts
38-5621 Window Channel Kit (window felt & channel seal) by LMC
38-6522 Door Handle Outside LH by LMC
38-6523 Door Handle Outside RH by LMC
36-0690 Door Lock Set W/Keys by LMC
38-5934 Vent Window Seal Kit by LMC
After you rebuild a vent window you might find that it’s less time consuming and easer to just by a complete vent window assembly. It’s a little bit tricky but it can be rebuilt.
Enjoy your build
Old 09-28-2010, 08:38 AM   #400
VA72C10
VA72C10
VA72C10's Avatar
Man Bruce, this build gets better and better. The pictures with writeups and/or links to them make this thread all that's needed when building the truck Who needs a factory assembly manual
