Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-20-2018, 11:42 AM   #376
regan wilson
regan wilson's Avatar
Re: Ok Boys and Girls it's Storytime
[IMG][/IMG]
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 11-20-2018, 11:44 AM   #377
regan wilson
[IMG][/IMG]
Old 11-20-2018, 11:45 AM   #378
regan wilson
[IMG][/IMG]
Old 11-20-2018, 11:50 AM   #379
regan wilson
[IMG][/IMG]
Average hp and tq from 6300 to 7800 1270hp and 950tq.
This was on Sunoco Maximal fuel. Had we tried the Q16 again it would have been worth 3 percent more power or better.
Old 11-20-2018, 10:56 PM   #380
hotrod 80
mini truck racer
hotrod 80's Avatar
POWA house right there . BA #s man . Lots of hard work to get to that point .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-22-2018, 08:56 AM   #381
regan wilson
Thanks Hotrod. Over 2 years to get the motor together. Once we get my header situation figured out I can start putting it back together.
Old 11-25-2018, 10:29 AM   #382
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
I’ll be happy with a little more than half that. Thx for the Thanksgiving update!
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 12-12-2018, 10:50 AM   #383
71Dragtruck
71Dragtruck's Avatar
Hey Regan, pretty sure I recall you were running a Turbo 400 with a 2.48 1st gear correct? If so are you still running that ratio? I know you are on a throttle stop, but when you have done a full launch how was the 1st to 2nd shift?
I'm running a 4.56 rear gear now with a 32.6" tire (next tire will be a 33), I'm building a new 400 for it and thinking that the 2.48 might be a bit too violent behind a 615ci BBC off the line, motor should be in that 1200hp 900trq give or take range, est shift point 7800, but until its on the dyno these are all just numbers off of past builds the shop has done.
Anyway wondering if I should do a 2.10 1st gear instead.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-12-2018, 01:16 PM   #384
regan wilson
I have been running a 2.10 low with a 1.31 second gear for years now. It can still be a little violent. The stock ratio is definitely a no go.
Old 12-12-2018, 01:40 PM   #385
71Dragtruck
Thanks, thinking I'll have to do the same as 2.48 will be brutal.
Sponsored by:
Hard Candy Customs
Old 12-13-2018, 03:25 PM   #386
nxtruck
nxtruck's Avatar
Regan or 71Dragtruck,
Have either one of you guys tried a glide? I've been toying with that idea myself, but am making nowhere near the power that either of you two are making. I know there are a few different low gear choices available for the glide. My main reason for considering a glide is traction on a less than ideal track surface. Just curious if anyone has went that route.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 12-13-2018, 04:01 PM   #387
71Dragtruck
I've been talking to Hutch about building me a trans, he said if my truck 3700# was a couple hundred lighter he would suggest a glide, but then I'd be back to a 2 piece drive shaft for sure.
Sponsored by:
Hard Candy Customs
Old 12-13-2018, 05:09 PM   #388
nxtruck
nxtruck's Avatar
Well,
I'd say Hutch ought to know, then. I just figured that, with that kind of power, maybe a 2-speed might calm things down enough to be of benefit. Sounds like you have things covered, traction-wise, with the 4-link and being more able to compensate for the hit of a 3-speed.
Chris
Old 12-13-2018, 06:50 PM   #389
71Dragtruck
Some guys with 400’s that have the valve body to run the trans brake in 2nd have launched that way too I guess, if your trans is set up for it. I’ve never seen it, just read over on the yellow bullet guys talking about it.
Sorry for taking your thread off topic Regan, guess I should have started a new one.
Sponsored by:
Hard Candy Customs
Old 12-13-2018, 08:53 PM   #390
regan wilson
No problem 71. I honestly just like my 3 speed. Powerglides kinda bore me. I have driven quite a few racecars with them. My ratios work good for me on the throttle stop because I come off the stop with a 5.97 ratio (in 2nd gear).
Old 12-14-2018, 06:27 PM   #391
nxtruck
nxtruck's Avatar
Yep, sorry about the thread hi-jack, too. You guys kinda reminded me about one of my off-season projects. I do appreciate the info from you both.
Chris
Old 12-15-2018, 09:27 AM   #392
RICKSRAT
RICKSRAT's Avatar
[IMG][/IMG]
Hey Regan good to see Motor done and really good #'s. Would like to see Truck run at the track next time you go.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 12-15-2018, 09:46 AM   #393
RICKSRAT
RICKSRAT's Avatar
71 Dragtruck Just had TransKing freshen my 400 and added 300M input & main shafts ; clutch hub and a 2.22 1st gear from Coan. If you have any questions let me know maybe can help out.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 12-16-2018, 11:14 AM   #394
regan wilson
Rick thanks for the compliments. I see you found the extra power you were looking for. You been keeping that a secret huh? My plans right now are to have the truck back together by the end of January (fingers crossed). Then go test in February, maybe at Extreme Raceway or Ennis. I plan on my first race being the Houston Divisional March 22nd.
Old 12-16-2018, 04:02 PM   #395
RICKSRAT
RICKSRAT's Avatar
Yes we did find a few more hp. Motor didn’t like the Sniper Jr so had some more work done to the Super Victor and a few other small tweaks. I Passed by The new track towards Dallas last month and Looks like a nice track. Good luck and if you need any pit crew help let me know. I could help you out in Houston as I’m only an Hour from the track
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 12-16-2018, 07:50 PM   #396
regan wilson
Originally Posted by RICKSRAT View Post
Yes we did find a few more hp. Motor didn’t like the Sniper Jr so had some more work done to the Super Victor and a few other small tweaks. I Passed by The new track towards Dallas last month and Looks any like a nice track. Good luck and if you need any pit crew help let me know. I could help you out in Houston as I’m only an Hour from the track
We'll see how everything goes. You are always welcome to come hang out. I asked for some tire checkers in Oklahoma a few years ago! Didn't get any takers.Your numbers on that Pump Gas deal are way more impressive than my deal. That's Awesome.
Old 12-22-2018, 10:21 AM   #397
regan wilson
I just brought the truck back home from the chassis shop. My old friend Tony Smith that built the cage,rear end and headers. Tony cut the 2 1/4 step out of the headers and rebuilt them with 2 3/8 all the way to the 5' collectors. He also made me a neat little alternator bracket and a T-Stop solenoid bracket that will double as a spring bracket for the throttle.[IMG][/IMG]
Old 12-22-2018, 10:24 AM   #398
regan wilson
While we were at it we took the #7 and #8 tubes outside the frame[IMG][/IMG] rails.
Old 12-22-2018, 10:27 AM   #399
regan wilson
[IMG][/IMG]
Old 12-22-2018, 10:30 AM   #400
regan wilson
Solenoid Bracket[IMG][/IMG]
