Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-14-2015, 06:12 AM   #376
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I ended up going out 3rd round last weekend . Bad part is i was on . Lights were steller . I was .002 to his .056 3rd round and the truck had run 6.86 all day long . Right after the sun set the track got better bite and it 60 footed . I ended up taking .107 , trusting the truck . Should have backed up , but lost 2 races last time that way .
Anyway i just ordered a new converter to match the motor im putting back together and i'll have this converter cut open and checked out for the 396 over the winter .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-14-2015, 01:10 PM   #377
Marv D
Registered Truck Offender
Marv D's Avatar
Re: New project
Hey your our there going rounds,, making it back on the trailer under it's own power,,, it's a GOOD day!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-18-2015, 10:22 AM   #378
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Ironman classic in Lufkin today . About to head out
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-19-2015, 09:20 AM   #379
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well , change of plans . Decided to run out to Evadale , Ben Bruce memorial airpark and run out their . Ended up with the wind , but something is going away . It was slowing down every run .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-20-2015, 09:32 PM   #380
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Leak down was good , trans fluid looked good , inside the filter looks good . Tires are junk with no depth holes . I don't know how I missed that . Swapped tires already and just ordered a set of the pro bracket radials to try out . Last fuel I bought was 90% so I was a touch lean . I put 3 jet sizes into it and cut it back to 85% should be good to go for the National dragster challenge , which I am the defending champ .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-24-2015, 09:59 AM   #381
JJLT1
JJLT1's Avatar
Re: New project
the win? or too much wind??
wow, that looks like a cast roller cam? I forget what they call them.. ductile iron??
I didn't know they were fixable..
keep it up Hotrod, WTG..
x2 Marv
drive it on the trailer, and its not knockin, its a good day..
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 07-24-2015, 03:08 PM   #382
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
x2 Marv
Too late to edit it , but I won . Yes it is not the billet blank and no it is not fixable . I just ordered another one from comp to replace it . Gonna be hot this weekend like 101 and 100% humidity . I have a fresh motor trans and converter waiting , but not changing anything til we get a break .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-26-2015, 09:56 PM   #383
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got to 10 cars Saturday night and was just late I was .080 and he was .051 I was dead on 1 and he almost gave it back . Mov was .007 .
Last batch of fuel I got was 93% and it caused me to be lean . I cut 2 jugs with 1 quart of 87 pump gas and ended up with 76% . I blended the 4 jugs half and half and ended up with 2 jugs of 87 , 1 jug of 86 and 1 jug of 85% . I also went up 1 jet size to 99 square . This helped the cooling for sure .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-11-2015, 06:55 PM   #384
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Been testing on the new Pro bracket radial , but cant really give a good report as I think the sprag is broken in my converter . It will just drill it and 1.51/1.52 and im .008 or im .080 and 1.57 with what feels like it is falling on its face at the shift and 10 numbers slow . I can tell when it does it and I've been spraying it to make up for it , but it is tough to dial in like that . I went out first round Saturday , bought back in and lost third round with a 7.04 on a 6.93 dial not spraying . Sunday I went out 4th round with a slow light from the converter , but broke out cause I was on the spray hard trying to make back up . Im about to go out and start pulling the motor and trans and get it ready for this weekend .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-17-2015, 11:48 AM   #385
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Had a busy week , 48 hour work week and working until late to get this thing together . I had a 388 out of the white 79' I sold and bought back . I put the 388 with my "good" glide that I broke the planet in at divisionals . I had a 1.80 straight cut put in it and freshened up . I bought a BTE converter that is 4900 rpm stall . I stuck it all together and threw it in the truck . I got it fired up about 8:30 Friday night and Saturday by 1 pm was on the road untested headed to Lufkin for "Battle of the pines" Ironman race . Pulled it out of the trailer and took it to the shutdown area to warm the gear and found it was rich . Took the 99 square jets out and put 92s in the front with a 4.5 power valve and 95 in the rear . The air to fuel was a lot better . Small leak at the china wall in front and I smeared it with blue RTV and it sealed . Won first round with a .002 light and had the bye second round won third with a good light . Got up for 4th and made 3 mistakes ; not enough burnout , bumped in to deep and anticipated the light to be .-042 red . Best pass was 6.97 worst was 7.00 with the deep bump. Pretty consistant for sure , but slower then my old motor . Next weekend is the season final race . I slide to 11 in points due to the 2 race drop . Need a good weekend coming up for sure . I will be swapping back to the pro bracket radial to start Saturday out also .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-24-2015, 11:55 AM   #386
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Had a decent weekend for the season 11th for the season out of 93 . Local NHRA season is over and the year . I got 1 more IHRA race next weekend , then both of the bracket finals . Plans are to run IHRA in the yellow truck and run NHRA with the blue truck in no E sportsman . We will see . Been a long season and I have had a lot of parts issues for sure .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-06-2015, 09:45 PM   #387
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
IHRA bracket finals got to 23 cars Fridays gambler , first round runner up for the ironman with a ,043 pack and got to 9 sunday in the gamblers race . 2 more 7.0 index deals and I am ready for a break .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-15-2015, 10:46 AM   #388
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Been working on this thing . I ran IHRA bracket finals in this truck and the NHRA in the blue truck at NHRA . Tires are done so I swapped to the 28's off the blue truck and 24" fronts as all I have left 2 index races . Pro bracket radials don't agree with the truck very well . My rear springs are 200# and need to be 130-150# . Calvert cant make me a set , so bias plys it is . Motor seems to be breaking in nicely . ET has dropped to mid 6.80's . Been looking at Champion wheels and will be funding them through a garage cleanout . Fresh front and rear tires for 2016 .
I also still have the rotator from the 396 and I bought a brand new set of pistons for that set up . The block work should be done by Christmas . Im still unsure about camshaft choice . Hoping to start the season faster at like 6.40's that would put me in the fastest 5 cars in my field .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-07-2016, 12:07 PM   #389
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Well update time . The rotator I hurt in March 2014 is almost done . Block clearenced , bore and hone done , p to v was .080 on the intake and .100 on the exhaust . I had 1.65 Pontiac rockers , so I ended up swapping to crane gold 1.5s . Really wanted a shaft setup , but funds wont allow it right now . The rocker arm swap will give me the extra room I need p to v . Cam is 256/266@.050 and .660/.630 lift . Should work good for what I am doing . 220 AFR heads and my fogger intake . I am also running pump E85 for 2016 . Changing to fenderwell headers to lose some weight and free up some power.
Sent the converter off to Lenny @ UCC for a freshen up . Also will be having the trans pulled apart and checked out . I also broke down and bought a pump station and got a contract on a mother bottle .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-09-2016, 07:17 AM   #390
JJLT1
JJLT1's Avatar
Re: New project
more power
rock on Hotrod
JJ
Old 01-09-2016, 10:30 AM   #391
Rannos
Rannos's Avatar
Re: New project
When you get it back together I'll have to come out and watch you race. Maybe we can meet up at HMP once I get the Moser rearend in my truck and you can drag what little paint I have on mine off for me.
Rannos is offline   Reply With Quote
Old 01-10-2016, 12:06 AM   #392
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I'll be at HMP on the 16th to run 7.0 . Come on out . Heck bring that thing to Baytown and try out DOT class . Although your probably to fast .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-10-2016, 06:17 AM   #393
Rannos
Rannos's Avatar
Re: New project
Baytown won't let me run with only having lap belts. I dont think I'll have it together on the 16th but if I'm not working I'll try and come watch.
Old 02-10-2016, 09:03 AM   #394
regan wilson
regan wilson's Avatar
Re: New project
Hotrod are you coming to Baytown at the end of the month?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 02-21-2016, 11:33 AM   #395
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I will be there pit crewing on the top dragster . After last years hassle of getting through tech , im gonna pass this year . I did keep the super street number for the future . If your there ill look you up .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-21-2016, 12:51 PM   #396
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
Got the new motor in and lined out pretty good . 12.5 to 1 on pump E 85 @$1.39 a gallon . Think it has a 10.5 in it , I just got to find it .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-21-2016, 07:41 PM   #397
71Dragtruck
71Dragtruck's Avatar
Re: New project
Damn that could pass for one of my time slips.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-23-2016, 10:46 PM   #398
JJLT1
JJLT1's Avatar
Re: New project
sweet wtg HR
JJ
Old 02-25-2016, 10:47 PM   #399
ChrisDollins
ChrisDollins's Avatar
Re: New project
Little truck is moving on! Haven't checked in on the thread in a while. Was browsing through the hotwheels at Walmart for me.. um, my 4 year old, and found this cool truck that reminded me of yours. Had to share.
Chris
ChrisDollins is offline   Reply With Quote
Old 02-28-2016, 09:14 PM   #400
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: New project
I like , might have to use those graphics if I ever repaint .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
