Old 04-09-2011, 11:31 PM   #376
my4by2
my4by2's Avatar
Re: My 86 build
It's a steering shaft isn't it?
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-10-2011, 02:29 AM   #377
Pop's C-10
Pop's C-10's Avatar
Re: My 86 build
That is what it is..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-10-2011, 08:39 AM   #378
73gmc454
73gmc454's Avatar
Re: My 86 build
All the fab work looks good !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 04-10-2011, 04:26 PM   #379
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
thanks!
mooseknuckles is offline   Reply With Quote
Old 04-10-2011, 07:40 PM   #380
mooseknuckles
Re: My 86 build
notch & crossmember done....ended up going with my original crossmember, alot stronger and already made...now on to link bars and mounting tabs!
Old 04-10-2011, 08:03 PM   #381
mooseknuckles
Re: My 86 build
Old 04-10-2011, 09:21 PM   #382
87 chevy silverado
Re: My 86 build
nice
87 chevy silverado is offline   Reply With Quote
Old 04-10-2011, 09:43 PM   #383
mooseknuckles
Re: My 86 build
Originally Posted by 87 chevy silverado View Post
nice
thanks.
Old 04-12-2011, 09:49 PM   #384
mooseknuckles
Re: My 86 build
may switch up my upper bars and go with a wishbone style instead of triangulated uppers...not sure if I can get them mounted the way I want them and still get enough triangulation.
Old 04-13-2011, 09:40 PM   #385
mooseknuckles
Re: My 86 build
after a coulple hours of grinding!....12, 4" link tabs, just need to drill them now!
Old 04-13-2011, 09:45 PM   #386
bharrison1
bharrison1's Avatar
Re: My 86 build
Nice work!!!!
bharrison1 is offline   Reply With Quote
Old 04-14-2011, 07:31 PM   #387
mooseknuckles
Re: My 86 build
Originally Posted by bharrison1 View Post
Nice work!!!!
thanks!
Old 04-14-2011, 08:26 PM   #388
mooseknuckles
Re: My 86 build
hopefully get off work early tomorrow and get some shyte done!
Old 04-14-2011, 10:26 PM   #389
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
looks really good ...supposed to be sunny tommorrow but 5C
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-15-2011, 06:52 PM   #390
mooseknuckles
Re: My 86 build
got some of my tabs drilled today, mocked up upper link bars and going to go with a wishbone set up now. with any luck I should have the rear bagged tomorrow aft.
Old 04-16-2011, 06:56 PM   #391
mooseknuckles
Re: My 86 build
wishbone mock up
Old 04-16-2011, 06:57 PM   #392
mooseknuckles
Re: My 86 build
one more...
Old 04-16-2011, 07:01 PM   #393
mooseknuckles
Re: My 86 build
crappy day today ....so I cut the tubes down to make the wishbone, and welded it up, welded the tabs to the axle. still have to weld in the front wishbone mount, but I want to wait till I'm done with the lowers first.....so close now
Old 04-16-2011, 09:49 PM   #394
Pop's C-10
Pop's C-10's Avatar
Re: My 86 build
I like tha look of a wishbone better than upper links..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 04-16-2011, 11:19 PM   #395
mooseknuckles
Re: My 86 build
thanks pops!.......the triangulated bars just weren't going to work out the way I would've like them to...
Old 04-17-2011, 05:07 PM   #396
mooseknuckles
Re: My 86 build
....got a little bit done today...I'll post pics later.
Old 04-17-2011, 06:08 PM   #397
mooseknuckles
Re: My 86 build
today I started to raise the fenders in the bed to make some room in the wheelwells, I cant drop it any lower without the tires wanting to hit the fenders, so I thought I'd get this out of the way before I finish the 4-link bars. I only got the drivers side finished today, I hope to do the passengers side this week. forgot to take pics during the cutting and welding, but have some after....
Old 04-18-2011, 08:54 PM   #398
mooseknuckles
Re: My 86 build
I managed to get the pass side rear fender raised tonight after work....took some more pics....
Old 04-18-2011, 08:56 PM   #399
mooseknuckles
Re: My 86 build
and....
Old 04-18-2011, 10:29 PM   #400
mooseknuckles
Re: My 86 build
I also found out today that my battery box is in...need to go pick it up!
