11-02-2015, 05:47 PM | #376 |
Re: Project 68 k10 LWB..aka "The Hulk"
Here a few pictures of the work we started this past weekend.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
11-02-2015, 05:53 PM | #377 |
This picture is from the driver side cab corner. You can see the replacement cab piece.Not sure about it but the outside has a bunch of bondo. Too be continued!!
11-02-2015, 06:07 PM | #378 |
Ok here are a few more.
check out the concave on the cab corner it had 3/8" of bondo on it...
11-03-2015, 10:11 AM | #379 |
Looking good, I bet the rotisserie is helping a lot.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
11-07-2015, 12:39 AM | #380 |
Fantastic project. I could only dream my drivetrain would look so clean and sharp. Keep up the great work.
11-07-2015, 12:41 PM | #381 |
Yes it is. Only thing is I am not sure if I can cut out the cab corner while on the rotisserie. What do you think? Should I support the cab on a cart, off the rotisserie? I don't what any sagging problems.
11-07-2015, 12:59 PM | #382 |
IMO you can get away with it if all the rest of the structure is there and your just replacing the outer sheet metal. I'd check the door gap prior to cutting it out and after you get the new tacked in place prior to final.
11-07-2015, 06:05 PM | #383 |
If the rest of the floor is in place then you should be able to do cab corners while it sits on the frame (or suitable replacement). People do that all of the time.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-08-2015, 09:55 PM | #384 |
Truck is looking really good man
11-09-2015, 05:49 PM | #385 | ||
11-09-2015, 06:08 PM | #386 |
If you guys have not gutted the doors yet you might consider it. Makes them much lighter for this kind of work. Let the doors be your guide if your happy how they fit the opening your good! Most of the patch panels we have played with require some work to fit properly especially inner & outer rockers as well as the cab corners.
11-09-2015, 06:16 PM | #387 | |
I have gutted the doors so they are light.... I was planning on hanging 1 at a time and checking fitment as I replace the cab corner.... then move on to the outer rocker. I do plan to repair the floor and "A" pillar first. I have a few welds to clean up from the PO's repair after that is repaired and cleaned up I will start the cab corner... Thanks for the help guys!!! Scott
11-29-2015, 09:06 PM | #388 |
Hello everyone. Was able to get a few things started since we are done with football. We went 7-5 lost in semifinals 42-44. Anyways.
I was able to get the floor repay welded in and started on the rocke s and cab corners. Driver side first
11-29-2015, 09:07 PM | #389 |
Driver floor welded in. I didn't get a chance to take a lot of pictures. As I was on a roll.
11-29-2015, 09:10 PM | #390 |
Cab corner removed. The PO had repair work done but it was all lap welded on. So I had to cut everything out and butt weld back.
11-29-2015, 09:22 PM | #391 |
Here it is mocked up.
11-29-2015, 09:26 PM | #392 |
Lower driver door. I think I have to move the door back.
11-29-2015, 09:28 PM | #393 |
Need to move door back right? If so I think I have to enlarge hinge bolt holes.
11-29-2015, 09:29 PM | #394 |
Side shot
12-02-2015, 03:10 AM | #395 |
Looking good!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-02-2015, 11:10 AM | #396 |
12-02-2015, 11:58 AM | #397 |
Thanks guys!
This body stuff is not my cup of tea..... but I have to get it right.
12-02-2015, 01:00 PM | #398 |
Looking good on the body work. My 71 is the first time I have done sheet metal work. Watching Sky do some of the back cab work on my truck learned me a couple tricks that would have made it easer for me. You will be done before you know it.
12-03-2015, 01:34 AM | #399 |
I'm no body expert, in fact you have done more than me at this point, but i keep reading about bracing inside the cab before cutting out rusty metal, and don't see any in your pic's, in regards to your gap at the rear of the door, is it possible that the cab door jamb might have shifted to the rear a little when the rocker and cab corner were cut? I ask because i think i see a gap between the rear corner and the outer rocker.. and your saying you may need to slot the hinge holes.
If you have not cut the other side yet try taking some measurements at different places on both sides of the door jamb and see if you can find a descrepancy. But another idea would be to add shims between too the hinge and the door to move it back. Love your truck, keep up the good work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 12-03-2015 at 01:43 AM. |
12-03-2015, 01:39 AM | #400 |
So tonight I had a body guy I know stop by and look at the cab corners and rocker. He said that,
"that it how the aftermarket stuff fits...even the GM rockers need to be messaged. But you did a great job". I felt pretty good and can't wait to get some time to work on it. Updates soon.
