Old 10-24-2018, 05:54 PM   #376
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Here you can see ( first 2 pics) the 2 pipes that were close/touching the shock mount and the control arm mount on the pass side. Instead of banging in the pipes i just cut the pipe along the head flange and took out about 1/4" of pipe and re-welded them. (sorry no pics of that) but the last pic is it finished with clearance.
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 10-24-2018, 06:03 PM   #377
6t9camaro
6t9camaro's Avatar
Since I need the front control arms and rear bars in place for mock up I decided to send them out for powder coating. A little early but That way I can install all the bushings and balljoints without having to remove them later. So off they go!
Build
67 Green Gobblin
Old 10-24-2018, 09:48 PM   #378
nlped
nlped's Avatar
Looks great! I’m dealing with motor height issues on my PB setup. My motor sits so low in the chassis that no header nor manifold will fit. Im hoping Nate is going to help out. I’m BBC too, so I’ll be keeping an eye on this one for sure.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-25-2018, 10:01 AM   #379
6t9camaro
6t9camaro's Avatar
It’s tough to find info on these setups with big blocks! Every where I look is LS motors. I’m happy with the room so far, I’ve got about 1 1/2” from crossmember to pan and I’m tempted to make new motor mounts to drop it but I would have header clearance issues if I did that.
Build
67 Green Gobblin
Old 11-04-2018, 03:32 PM   #380
6t9camaro
6t9camaro's Avatar
While I was held up with some parts at the powder coater I decided to mock up the air tank and build a set of compressor mounts. (With the help of my daughter) I will end up running the compressors with the heads facing each other since that will route the hoses/lines the way I want them.
Build
67 Green Gobblin
Old 11-04-2018, 03:39 PM   #381
6t9camaro
6t9camaro's Avatar
Also decided to tackle a job I've been putting off! Pulled out the old original blown rear end and stripped it down and cut off all the mounts. Got it into the garage for mock up so I can weld on the choppin block link mounts.
Build
67 Green Gobblin
Old 11-04-2018, 03:44 PM   #382
6t9camaro
6t9camaro's Avatar
I picked up the powder coated rear bars so I can finally get the mounts set and welded!
Build
67 Green Gobblin
Old 11-04-2018, 03:47 PM   #383
6t9camaro
6t9camaro's Avatar
Welded and back in!
Build
67 Green Gobblin
Old 11-04-2018, 08:04 PM   #384
Advanced Design
Advanced Design's Avatar
Nice work...and a cute helper!
Is that snow on your trailer?
Advanced Design is offline   Reply With Quote
Old 11-04-2018, 09:00 PM   #385
slowcpe
slowcpe's Avatar
Killer build
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-04-2018, 10:17 PM   #386
6t9camaro
6t9camaro's Avatar
Yup unfortunately that’s snow!
Originally Posted by slowcpe View Post
Killer build
Thanks!
Build
67 Green Gobblin
Old 11-16-2018, 08:34 PM   #387
6t9camaro
6t9camaro's Avatar
Ok I got the front control arms back so I managed to get quite a lot of the front end mocked up. Ball joints in Spindles, brakes and rack all fit up nice!
Build
67 Green Gobblin
Old 11-16-2018, 08:40 PM   #388
6t9camaro
6t9camaro's Avatar
A few more with the transits on so I could get an idea of the turning radius and check some clearance issues.
Build
67 Green Gobblin
Old 11-16-2018, 08:56 PM   #389
6t9camaro
6t9camaro's Avatar
Once the rear end was fit up and engine had all the clearance issues resolved I decided to take the motor out to clean it up. I also needed the motor out to finish some motor mount work and drilling holes for brake line, air line and fuel line clips/Mounting.
Build
67 Green Gobblin
Old 11-16-2018, 08:57 PM   #390
rincones
rincones's Avatar
Nice.
Loving that front crossmember ... keep the pics coming
Rincon
rincones is offline   Reply With Quote
Old 11-16-2018, 09:14 PM   #391
6t9camaro
6t9camaro's Avatar
More pics finishing up the small stuff before teardown!
Build
67 Green Gobblin
Old 11-20-2018, 10:41 PM   #392
6t9camaro
6t9camaro's Avatar
Finally got everything torn down and ready for powder coat!
Build
67 Green Gobblin
Old 11-20-2018, 10:51 PM   #393
6t9camaro
6t9camaro's Avatar
Forgot to mention earlier in the week I dropped off the frame rails, diff housing and a box of misc pieces to the sand blaster. I wouldn't recommend hauling frame rails in a Mazda 3 as you just might hit a bump and put a rail into the windshield!
Build
67 Green Gobblin
Old 11-20-2018, 10:54 PM   #394
6t9camaro
6t9camaro's Avatar
Blasting turned out nice! I snuck the parts into the wives SUV this time for a little more room! Now there off to powder coat.
Build
67 Green Gobblin
Old 11-21-2018, 12:51 AM   #395
cornerstone
cornerstone's Avatar
I know that must feel great making so much progress in the past month! What color powder coat do you plan to get? Cant wait to see it.
cornerstone is offline   Reply With Quote
Old 11-21-2018, 09:04 PM   #396
Sparky dave
Awesome just read the thread all in one go from the start. It’s made a turn at the end to being a type of restomod. Your fab skills are impressive to watch. Also was so glad to see the 454 go in there I don’t know why but I’m always disappointed when I see ls engines going in
Sparky dave is offline   Reply With Quote
Old 11-21-2018, 09:11 PM   #397
Sparky dave
Ps pro charger? ��
Old 11-21-2018, 09:23 PM   #398
Kronald_70GMC
Kronald_70GMC's Avatar
Great looking project! Really digging the old school big block. I'm gonna go the same route.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 11-22-2018, 07:51 PM   #399
6t9camaro
6t9camaro's Avatar
Powder coat is just going to be mostly semi gloss and flat black.
Thanks!
Ps pro charger? ��
LOL No power adders for this project!
Yup old school big block! going to try and recreate the 70s Ls6
Build
67 Green Gobblin
Old 11-22-2018, 08:17 PM   #400
6t9camaro
6t9camaro's Avatar
Since most of the parts are out for coating I figured it would be a good time to clean up the motor! I loaded it up and took it over to the pressure washer and steam cleaner! It cleaned up pretty good and removed off a ton of grease so now you can actually see all the original old orange paint.
Build
67 Green Gobblin
