04-09-2023, 04:54 PM | #376 |
Re: 53 3100 - complete rebuild and upgrade . . . .
Wrapped up the weekend with a good bit of progress. Rear suspension is close to being assembled, front is moving along as well. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
04-12-2023, 09:35 AM | #377 |
nice.
I love how clen your shop looks. now, time to get it messy and have parts laid out all over the place. haha |
04-13-2023, 08:09 AM | #378 | |
More later - Dan
04-16-2023, 09:21 PM | #379 |
Still making headway. Chassis is now officially back on its own suspension for the first time since September of 2019, so I'm stoked about that. Took the time and got the alignment close to save time later, and then set it up on my "custom" jackstands. Cleaned up a little, then slapped the engine on the table to check bellhousing runout, clean everything up and do the cam swap. More later - thanks for looking-
Dan
04-17-2023, 09:13 AM | #380 |
Looks really good. Keep at it Dan.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-07-2023, 07:25 PM | #381 |
Quick update. Still making good progress; spent the last few weekends routing e-brake cables, test fitting the seat frame a few more times and sent the headers off for coating. Also cam swap is in progress, got the bellhousing dowels replaced with offset dowels and dialed in - and fooling around with a "weight distribution" idea.
More soon - Dan
05-07-2023, 08:45 PM | #382 |
looks outstanding!!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-12-2023, 09:49 PM | #383 |
This next part may be controversial, but . . . .
Every truck I've owned has been too light in the rear, so I knew I wanted some weight in the back but didn't know how much. I mocked up the bed, fiberglass fenders, running boards, etc to see how the rear suspension acted. Of course, it was a little stiff. I "added" the weight of a full tank of gas and played around with extra weight till I had a little more motion, and finally decided I needed around 80-100 pounds added out back. So how? I dug around and had a piece of stainless plate from a past job and started whittling away. 1-1/2" stainless plate, 6"×36", is 94 lbs. Perfect. I bent up some brackets and hung it under the gas tank. With the plate installed and 100 lbs of gas, the plate sits 6.5" off the ground. If it's too much, I wasted a morning, but I can drop it in 30 minutes, so we'll see what happens. Still moving along - thanks for looking- Dan
05-12-2023, 11:55 PM | #384 |
now thats thinking outside the box-so to speak. lol.
05-22-2023, 11:39 AM | #385 |
i normally don't run a spare, but added a full size 37" spare to the back of my jeep for the same reason. better ride, better balance, but it's more weight swinging wide around a corner ... not like the jeep corners anyways.
any way to run more fuel or relocate functional items back there vs just added mass? you know, cuz racecar. |
05-22-2023, 09:10 PM | #386 |
shoulda cut "BIG DAN" into it and put it on top of the notch!
looks a little low to me for steep entrances but if you drag it once in a while will it even show?
05-26-2023, 10:21 PM | #387 | ||
Thanks for looking - more later- Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 05-27-2023 at 09:04 AM. |
06-01-2023, 05:57 AM | #388 |
Minor progress- finished the cam swap and got the LS back together and cleaned it up a bit. Waiting on the clutch, then I'll go ahead and land the engine / trans in the chassis for good. More later -
Dan
06-03-2023, 08:54 PM | #389 |
More forward progress. Waiting on a longer hose for the hydraulic clutch,
so shifted directions for a day or two. I've had the Raingear wiper system patiently waiting on the shelf, so went ahead and got that installed - wow, that was fun. Finished up the front dress on the engine also - happy to say belt length was correct on the first try. Anyone that runs an ICT alternator kit #551519; belt is 79". Still moving along - thanks for looking - Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 06-03-2023 at 10:13 PM. |
06-04-2023, 02:08 PM | #390 | |
Does this bracket improve your clearance down low?
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
06-04-2023, 04:57 PM | #391 | |
Dan
06-06-2023, 09:36 PM | #392 |
A little forward momentum . . . The throw out bearing hose arrived, so got the engine and trans bolted together and installed. Unless something crazy happens, this is it - motor and trans are in, waiting for start up. More later -
Dan
06-07-2023, 02:29 AM | #393 |
Big Dan
Strong Work You gotta have cut outs in your twice pipes nutz
Been there, wrecked that |
06-08-2023, 10:38 PM | #394 |
Headers are back from my friends powder coating shop. We used cerakote glacier coating (he's a gunsmith) in titanium (matched the block), rated to 1800 degrees. More parts going on for the last time! Thanks for looking -
Dan
06-09-2023, 09:25 AM | #395 |
Coming along nice Dan. Headers look great. What size tubes are they 2"? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
06-09-2023, 09:29 AM | #396 |
Looks clean. Will you install a heat shield on the balance pipe to protect the trans seal and u joint? Not needed?
06-09-2023, 11:54 AM | #397 | ||
Thanks all- Dan
06-11-2023, 05:13 AM | #398 |
And a little more progress. With no real bodywork to fight with, I'm at the assembly point finally. Finished installing the EFI manifold, put some color on the firewall, finished installing the exhaust, moving along. Hoping to have the cab mounted for good in the next month or so. More later-
Dan
06-11-2023, 09:25 AM | #399 |
Very nice. A month???? Come on
06-11-2023, 12:40 PM | #400 |
I'm hoping! Keep in mind, for some reason I tend to make progress in bursts, not steady as she goes . . . I'll make good headway for a month then just go fishing! Goal is to get a fairly accurate idea on wiring before installing the cab, so I'm just sniffing everything out, measuring, etc. My goal - if it's possible - is to fire it up by September; that'll be 4 years since I started the swap. Fingers crossed . . . . .
Either way - here's the Pro-flow harness laid out to start plotting. Only concern at this point is how short the cam and crank connectors are. More later - Dan
