#401 |
Re: Power Steering Adapter Plates
Thanks! PAYPAL sent.
#402 | |
#403 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
There is a seller on ebay that fabricates some nice PS, alt and AC brackets for the Chevy I6 engines. Have you checked in the '67-'72 classifieds here on the forum? They show up over there every so often also.
#404 |
I have a 62 chevy truck that I need a power steering adapter plate and power brake booster adapter for. I have an excellent donor car (1975 monte carlo). Can I use the power steering box, steering column and power brake booster from this car with your adapter plates?
#405 | |
60-66 Nut
I do not yet have a power steering box adapter plate for the '60-'62's. Hopefully in the next few months. However I have sold a few of these to guys that have made them work on their '60-'62's. You can not use any car steering box on your truck. It must be from a '68-'86 C series or '87-'91 R series pickup, Suburban or 2wd K5 Blazer.
I am not familar with the Monte Carlo boosters, so I do not know if they are compatable with my booster bracket. Does your truck have an auto trans or does it still have a manual trans with the hydraulic clutch? As for the steering column, most anything can be done if you want to put the work into it to make it work. In other words, it will not be a simple bolt in swap. Quote:
#406 |
hi - fixin to buy all the parts to FINALLY get PS on my 70 C10...do I need one of these brackets for the 70 model?
thanks! ![]() |
#407 |
Hello Captain.
I recently purchased one of your adapter plates. I will start with what I have, I ordered my parts for a 70 chev pick-up. My truck is a 65 C20 Cardone 27-7501 box which has the Saginaw # 7802644 on it. Moog K 6131 pitman arm. The differences are that on the template the center of shaft to center of pitman arm measurement is 6 1/2 inches. The measurment of pitman arm is 6 1/4 inches. Do I have the wrong pitman arm ? Or is the quarter inch nothing to worry about. As expected your plate and steering shaft adapter look great. Thanks |
#408 |
60-66 Nut
No you do not need this adapter plate. A power steering box will bolt right up to your frame. The trucks from '68 up were available with integral power steering, so the frame will accomodate the box.
#409 |
thanks Cap - preciate the quick response you rock!
#410 | |
60-66 Nut
The pitman arms should be 5-1/4" center to center. I just checked the template and it does show to be 5-1/2". I did not realize that. I will have to see about correcting that. The main thing to be concerned with is the hole locations.
#411 |
Thanks for getting back so fast.
I did forget that when I took those measurments I started at 1 inch on the tape. Interesting no one else picked up on that. Good thing is I have the right Pitman. Thanks Cal. |
#412 |
![]() Join Date: Nov 2001
I have a local friend (non member) that needs a plate for his '63 2wd. Is there a way he can contact you directly? Do you take pay-pal or what are you payment options?
I also sent you a PM
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
#413 |
60-66 Nut
I replied to your PM
#414 |
60-66 Nut
Here is a helpful thread for those of you that have 4x4's and are installing power steering.
http://www.67-72chevytrucks.com/vboa...power+steering
#415 |
Hello captainfab, do you still have the brackets for sale? PM me?
I have a 64 c30 and am using an 86 c20 suburban to swap everything. Thanks. Blane
1964 C30 - project to be static slammed work truck 1985 LTD - race car 1997 Civic - daily |
#416 |
60-66 Nut
#417 |
![]() Join Date: Sep 2013
PM sent to purchase an adapter plate from you Captainfab
Dan |
#418 |
60-66 Nut
PM replied to
#419 |
[QUOTE=Captainfab;6500400]I do not yet have a power steering box adapter plate for the '60-'62's. Hopefully in the next few months. However I have sold a few of these to guys that have made them work on their '60-'62's.
Hi Captainfab, just wondering if you have had a chance to make up an adapter plate for the '60-'62 frames yet or if you will have one in the near future? I hope to do the conversion on my '62 in the next 2-4 weeks. Also wondering if any of you guys that have installed Captinfab's adapter plate on your '60-'62 frames can give any feedback on how the plate worked and if there were any modifications (from the instructions supplied) needed to make the plate work? Pics of your '60-'62 install would be great too, could not find any on this thread. Thanks. |
#420 |
60-66 Nut
I do not yet have a power steering box adapter plate for the '60-'62's. It's been tough to get this done with Winter, still working 70-80 hrs a week and trying to make room in my shop to work on it. I haven't given up, but I can not make any promises as to exactly when I will get it done.
#421 |
i am new to all this, so please excuse my ignorant question. currently working on my 1965 c10 and was wondering, whats the purpose of the adapter plate? does it serve as a extra support for gear box?
#422 |
60-66 Nut
The adapter plate is needed to install a '68-'87 power steering box to the '60-'66 frames as the power steering box is not flat on the side that bolts to the frame.
#423 | |
thanks Captainfab for the info ![]()
My truck: 1965 C10 Fleetside, 327 SBC, TH350 |
#424 | |
60-66 Nut
When installing power steering, the steering column shaft must be shortened. The installation instructions give you the exact measurement and show you how to reuse the original flange. However if you do not have a drill press and a welder, the tube and flange that I sell makes the connection very easy.
#425 | |
Thanks again for the great info Captainfab . How much do you sell this kit for? and you mention that instructions are included right?, as I mentioned before I am learning as I go, zero experience under my belt, so all your info is greatly appreciated.
