10-06-2010, 09:52 PM | #401 |
Re: Project: Recycle
Looks like .120 wall.
10-06-2010, 11:03 PM | #402 |
My measurements from last night were accurate.
I cut the flange portion (where the rubber trans mount/bushing sits) off of the ECE trans x-member today @ lunch & cleaned up the welding slag. I grabbed a 4x6 piece of .250" plate & tacked it in place (now on the 'bottom' of the square tube vs. the 'top'). I installed the x-member & lowered the drivetrain. With a 3/16" 'shim', I'm @ 0.1° off from level (measured @ the intake/carb mounting pad). I put the level/angle finder on the trans yoke & I'm getting 2.7°. Another thing I verified is the ECE T/A x-member d.shaft loop isn't going to be tall enough to clear the shaft (needed the drivetrain in to 100% verify). Looks like I'll need to increase the height an inch or 2. I think I'm good to go but will confirm a couple of questions first. If my answers are what I expect (and I can't believe I'm about to say this), the chassis will come apart for some blasting & color.....
10-06-2010, 11:08 PM | #403 |
Slots go on anything!
Do you have to disassemble the whole thing for Krylon?!?
just kidding, Scot. Glad it is coming together.
1974 Jimmy- 5.3/4L80e/NP241 |
10-06-2010, 11:09 PM | #404 |
You do realize I'm thorough right?
10-07-2010, 12:06 AM | #405 |
Yeah, I forgot. I found an extra spray can trigger so let me know when the big day is.
10-07-2010, 08:49 AM | #406 |
Happy to be here
He "said" he was going to go ahead and powder coat it. Lets hope that's still the plan.
10-07-2010, 09:19 PM | #407 |
If you decide to paint instead of powdercoat let me know, I've got a few connections on stuff.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
10-21-2010, 10:18 PM | #408 |
Dang, you guys sent me to the 2nd page. Where's the love??
Ok..... I'll make a small update to keep things on track. I got the sbc/700r4 into the spare frame in order to verify the driveline angles & needed some pinion shims so I could accurately set the trans mount height. I got the shims in today so I'll try & get some time on it this weekend. Baseball (Rangers are in the play-offs) has been occupying some of my spare time so until the 'fat lady sings', I might be going to the home games. Oh.... the other thing taking up my time (& thoughts) is my new to me dually that I swapped my 74 for. Although not a project, I'm getting a few 'essentials' to make it unmistakenly 'mine' . . . ......
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-21-2010 at 10:22 PM. |
10-21-2010, 10:23 PM | #409 |
Under Construction
Congrats on the trade. Now what are those pieces, ya lost me . And u know we need a pic of the dually.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-21-2010 at 10:24 PM. |
10-21-2010, 10:41 PM | #410 |
low n' slo
nice (new to you) ride. ive always wanted to bag one of those rigs...
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-21-2010, 10:44 PM | #411 |
Man that sure is a nice dually, it just needs to be a little lower.
10-21-2010, 11:29 PM | #412 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-21-2010 at 11:31 PM. |
10-22-2010, 08:54 AM | #413 |
Happy to be here
All the luxuries of home in that baby. And if Momma gets made you got your own coach to sleep on..
10-22-2010, 09:47 AM | #414 |
I think the dually is going to be sweet, once you work your magic on it. I am looking forward to seeing that. Also looking forward to seeing the '64 rolling down the street. It is going to be amazing.
10-22-2010, 10:13 AM | #415 |
The 64 on the trailer (prior to it's maiden voyage), behind the dually should be an avatar worthy shot.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-22-2010 at 10:14 AM. |
10-22-2010, 10:24 AM | #416 |
and think you should start a thread for the dually
CHEVY ONLY |
10-23-2010, 03:45 PM | #417 |
I agree with this guy^^^^^!
Those dually's are sweeeet! |
10-23-2010, 04:32 PM | #418 | |
It's a mobile tool-box .
10-23-2010, 05:51 PM | #419 |
Thats ok. I just like to day dream about owning one.. I have to convince the wife a dually would be practical for a daily driver.
10-23-2010, 08:30 PM | #420 |
1 thing at a time is progress.
Nice Dually!!! It's even in my favorite color.
Alan
Philippians 2:14-16 |
10-23-2010, 09:37 PM | #421 |
Tot Roddin'
Nice dually SCOTI!
Will we see it towing your '64 to KS next year?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-23-2010, 09:44 PM | #422 | |
It doesn't have to be a full resto to start a build thread. Just post lots of pics and we will all be happy!! Take us on the journey with you Posted via Mobile Device
CHEVY ONLY |
11-07-2010, 03:39 PM | #423 |
I guess it's time for another update. I'm really, actually, no bs-ing, closer to getting it PC'd.
I got off work yesterday & spent the day re-stripping the rails & various x-members to try & get any residual grinding gouges out so that when sand-blasted, everything has a nice, smooth finish for the PC. About 3/4 through stripping the pass side frame rail, my DA took a crap. I've done this drill before (get 6hrs non-stop work time but spend most of it chasing parts/tools) & it was frustrating so I kept it going forward.... The chassis is no longer a chassis. I had that sucker 100% apart in a little over an hour (working solo). The rails & rear end housing are still in the shop (need to finish that pass side rail) but everything else was loaded into the dually & is waiting for the trip Monday to the PC shop. I hope to convince 'her' of the need to allow some late-night shop time tonight so I can get things loaded first thing tomorrow am.
11-08-2010, 10:33 AM | #424 |
Happy to be here
Glad to hear it Scoti. Lets see some shiny stuff...
11-08-2010, 02:23 PM | #425 |
I'm just glad to be here!
Sounds like a lot of progress just working solo. Looking forward to seeing it back from the coater.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
