Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 11-24-2014, 12:04 AM   #401
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
PM sent
Originally Posted by Beaumont@ View Post
Would like to get a set of brackets for a 12 bolt Chevy sent to Canada if possible
Old 12-05-2014, 03:59 PM   #402
scottycrossin
Still trying to decide whether to go 6 lug or 5 lug, is there a 6 lug rotor that will work?
scottycrossin is offline   Reply With Quote
Old 12-05-2014, 04:40 PM   #403
scottycrossin
Sorry, I should also add that it is a 68 c10, 12 bolt that is currently 6 lug.
Old 12-06-2014, 02:43 AM   #404
Captainfab
60-66 Nut
There is not a 6 lug rotor that is interchangeable with the 5 lug Astro/Safari rotor.
I do make 2 different 6 lug rear disc conversion brackets.
http://67-72chevytrucks.com/vboard/s...d.php?t=637489
http://67-72chevytrucks.com/vboard/s...d.php?t=494411
Old 12-08-2014, 11:03 PM   #405
scottycrossin
Captain
Thanks for the reply. Do you have a conversion if I would decide to go with 5 on 4.75?
Old 12-09-2014, 12:15 AM   #406
Captainfab
60-66 Nut
I started working on e 5 x 4.75 rear disc conversion several months ago, but never had time to finish it. I'm just not sure when I will have time. I'm still working 70-80 hrs a week and no relief in sight
Originally Posted by scottycrossin View Post
Captain
Old 12-09-2014, 12:23 AM   #407
scottycrossin
Do you know what caliper and rotor you would use with that kit; or have you gotten that far?
Old 12-09-2014, 01:44 AM   #408
Captainfab
60-66 Nut
The rotor is a late '70's TA rotor. The caliper I would have to look at again and see what I was using on this one.
Old 12-09-2014, 06:02 PM   #409
czizza
Hello I came across this post as I was searching for a solution for my rear brakes. Would this work on 1979 Camaro 10 bolt rear? The shocks are staggered does that matter?
czizza is offline   Reply With Quote
Old 12-09-2014, 08:08 PM   #410
LDO
LDO's Avatar
oooh, I'm waiting too. I've got 5x4.75 on my 66 12 bolt and want read disks too!
LDO is offline   Reply With Quote
Old 12-10-2014, 01:15 AM   #411
Captainfab
60-66 Nut
None of my rear disc brackets will work on a car differential except for the Impala differential which has the same backing plate flange as the 1/2 ton trucks. They are all designed for use with the '64-'82 truck 12 bolt and '80-'91 8.5" truck 10 bolt
Old 12-10-2014, 01:16 AM   #412
Captainfab
60-66 Nut
Well I guess I need to figure out how to get more than 24 hours out of a day and get those brackets finished up.
Old 12-12-2014, 01:57 AM   #413
scottycrossin
Captain,
Will your brackets work with c clip eliminaters?
Old 12-13-2014, 12:45 AM   #414
Captainfab
60-66 Nut
I have not tried it but I don't think will work. The base bracket bolts to the backing plate flange on the wheel side just as the C-clip eliminator does.
Captain,
Old 12-14-2014, 01:20 AM   #415
Captainfab
60-66 Nut
I managed to squeeze a little extra time to work on the 5 x 4.75 conversion a couple days ago. If I get done early enough with the job in the shop tomorrow I'll see if I can make some more progress.
Captain
Old 12-14-2014, 10:53 AM   #416
LDO
LDO's Avatar
I have a truck 12 bolt but my axles have been re-drilled for the 5 x 4.75 pattern.
Old 12-15-2014, 12:29 AM   #417
Captainfab
60-66 Nut
The new brackets I am working on are designed for that application or a Impala/Caprice with the 5 x 4.75" bolt pattern.
Old 12-15-2014, 08:52 PM   #418
LDO
LDO's Avatar
Then I'm standing by!
Old 01-04-2015, 02:01 PM   #419
MySons68C20
MySons68C20's Avatar
Did you ever find the correct springs?
I'll let you know once I find the correct springs.
MySons68C20 is offline   Reply With Quote
Old 01-04-2015, 02:10 PM   #420
MySons68C20
PS PM sent
Old 01-05-2015, 12:12 AM   #421
Captainfab
60-66 Nut
Yes I do have the correct springs. I replied to your PM
Old 01-07-2015, 10:02 AM   #422
dkauffman05
dkauffman05's Avatar
What pads you guys recommend for the d52 ' s that aren't $150 a set. I've got wilwood ' s on the front and stock front calipers on the rear. Truck will be mostly street with some autocross.
dkauffman05 is offline   Reply With Quote
Old 02-02-2015, 05:04 PM   #423
bodydropped68
bodydropped68's Avatar
WOW my brackets came in today VERY impressive Thank you John have a great day Thanks again Paul
bodydropped68 is offline   Reply With Quote
Old 02-02-2015, 05:12 PM   #424
LDO
LDO's Avatar
Any updates?
Old 02-03-2015, 12:30 AM   #425
Captainfab
60-66 Nut
Thanks for the compliments Paul
Sorry Bob but no not yet.....still working 70-80 hrs a week every week and not getting caught up any yet.
Any updates?
