Old 01-10-2013, 09:44 PM   #401
luifer76
luifer76's Avatar
Re: My 73 c10 project.....
Originally Posted by canadian 4x4 View Post
Those look awesome man!
thanks man.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 01-10-2013, 10:20 PM   #402
moregrip
moregrip's Avatar
Originally Posted by luifer76 View Post
i woke up feeling a litte better today so i got a little more done i cut all the metal for both of the lca's and i got one of them all welded up from top and bottom...
very tidy work!
moregrip is offline   Reply With Quote
Old 01-11-2013, 12:08 AM   #403
luifer76
luifer76's Avatar
Originally Posted by moregrip View Post
very tidy work!
thanks bro....
Old 01-11-2013, 10:17 PM   #404
luifer76
luifer76's Avatar
today i got the other lca all done so their both done i just have to drill the holes to mount the bags and drill a couple more holes for draining purposes and i also ended up pie cutting the uppers i wanted to do more but is freezing outside so this was it for today here are some pics.....
Old 01-11-2013, 10:19 PM   #405
luifer76
luifer76's Avatar
i was goin through some parts i have in the garage and i found a new set inner and outer tierod ends i bought them for this truck a while ago but i never got around to use them so im gonna use them now ....
Old 01-11-2013, 10:20 PM   #406
budget78gmc
budget78gmc's Avatar
Its always nice to find things you bought and forgot about. Happens to me all the time.
SOLD 1978 GMC Sierra Grande "Slow Budget Build"
1969 C10 Build
http://67-72chevytrucks.com/vboard/s...d.php?t=440536
budget78gmc is offline   Reply With Quote
Old 01-11-2013, 10:21 PM   #407
lolife99
67-72 parts collector,…
lolife99's Avatar
You gonna paint or powdercoat the arms?
Keith
Convert to disc brakes.
Old 01-11-2013, 10:25 PM   #408
luifer76
luifer76's Avatar
paint them with rustoleum paint i have to keep it in the budget lol....
Old 01-11-2013, 10:27 PM   #409
luifer76
luifer76's Avatar
yes sir it is...... i actually have more new parts for this truck in there that maybe this sunday im gonna pull the other two trucks out of the garage so i can get to them since this is the time to use the parts....
Old 01-11-2013, 10:34 PM   #410
budget78gmc
Yea buddy. I have 2 new brake calipers somewhere in my mess of a garage. LOL
1969 C10 Build
Old 01-11-2013, 10:42 PM   #411
luifer76
luifer76's Avatar
lol.... if im right i have new brake pads for the rear and front, new speedo cable, new kickdown cable, and i know i got more stuff the question is where? lol
Old 01-11-2013, 10:55 PM   #412
maxxxy
maxxxy's Avatar
How'd you do the bend in the pie cut off of the truck?
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 01-11-2013, 11:03 PM   #413
luifer76
luifer76's Avatar
well since i know how much to cut i just used my vice to hold them in place and bent them with my hands and after i made sure they were both even i welded them from bottom and top...
Old 01-11-2013, 11:16 PM   #414
luifer76
luifer76's Avatar
in the next couple days the plan is start putting the tierod ends together and after that start painting all the suspension components and engine compartment and also the front part of of the frame...
Old 01-12-2013, 09:13 PM   #415
luifer76
luifer76's Avatar
ok so here we go again i feel like a damn crab going backwards lol.... i got my tierod ends all put together i used the same sleeve since there is nothing wrong it and i started to paint the frame inside the engine compartment and the Xmember but because all the damn oil and grease that xmember had and because the frame and xmember are gonna be diff colors there was no way to paint it without making a mess and i know i wouldnt be happy with the results so i decide it to take the Xmember off and all the steering parts this is gonna set me back a little bit but i think ill be happier with the results here are some pics....
Old 01-12-2013, 09:14 PM   #416
luifer76
luifer76's Avatar
i washed it with degreaser and the high pressure hose and i took the grinder with a wie brush to it and got it all cleaned up....
Old 01-12-2013, 09:17 PM   #417
luifer76
luifer76's Avatar
and started to paint the xmember with the hammered style paint.... i love this paint it lays on thick and it hides all kinds of imperfections and i like the way it looks ....
Old 01-13-2013, 12:35 PM   #418
moregrip
moregrip's Avatar
Is that rustoleum?
Old 01-13-2013, 01:46 PM   #419
luifer76
luifer76's Avatar
Is that rustoleum?
yes is Rust-oleum $10 a quart with one quart you can do all your suspension parts and still have half of the quart left.... the can says black but once is applied is like dark gray....
Old 01-13-2013, 01:58 PM   #420
luifer76
luifer76's Avatar
i forgat to post this last night should i get new motor mounts? one of them looks really cracked....
Old 01-13-2013, 01:59 PM   #421
luifer76
luifer76's Avatar
and whats the deal with poly mounts? i been reading here that poly mounts shake too much and the regular rubber ones dont what is your guys opinion on this? i thought poly were better than the regular replacement ones....
Old 01-13-2013, 02:12 PM   #422
moregrip
moregrip's Avatar
great info......is it made to go on bare metal or do you apply an etching primer? Any idea what the durability is like on that stuff?
Old 01-13-2013, 02:13 PM   #423
made2drag
made2drag's Avatar
nice!
made2drag is offline   Reply With Quote
Old 01-13-2013, 02:45 PM   #424
luifer76
luifer76's Avatar
i been using it for years i never applied primer before using it but im sure it will help if you do.... as far as the durability im sure is better than just spraying it with a cheap rattle can but im also sure is not as good as P.O.R 15 since rustoleum is cheaper...
Old 01-13-2013, 02:45 PM   #425
luifer76
luifer76's Avatar
Originally Posted by made2drag View Post
nice!
thanks brother...
bagg em and drag em
