Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 02-26-2016, 09:29 PM   #401
GMCNUT
GMCNUT's Avatar
Re: GIANT 60-66 parts Stash Barn Find!!
Originally Posted by Franklin1775 View Post
My current shipping zip code is 28460. I might need the steel shaft. My truck currently has a late 70's jeep steering column in it... Could you pm me a picture of the chevy one?
Well, Franklin, I went and retrieved the 2nd column and pulled the aftermarket steering wheel off, and discovered it to have a GMC Turn Signal switch in it - so the turn signal switch and wiring are complete and the switch seems to actuate, so there is a higher than normal chance it works, but if it doesn't you'd have to buy a 1963 Chevy Turn Signal switch to replace it, because GMC columns use a Pontiac designed metal switch vs plastic Chevrolet switches, and the bolts don't line up between Chevy reproduced switches and the GMC housing unless you use the 63 Chevy switch. So point being, neither of my columns are Chevy columns, but are otherwise identical to Chevy columns in terms of appearance and operation. Let me know if you are good with this, and I'll wrap it up and weigh and get a shipping quote and pics
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline
Old 02-26-2016, 09:32 PM   #402
GMCNUT
GMCNUT's Avatar
Originally Posted by The Rocknrod View Post
Do you have an ashtray that's not rusted through? Mine has a hole in it. The dash side (or cover/handle) of mine is great. Or if you just want to sell the assembly.
I bought a low mileage truck that was in a million pieces, and the old guy who disassembled it put every part in a bag or marked box in a very detailed fashion. Somewhere in all those bags I saw the original ash tray and it was real nice if I recall - I'll be in the bldg again tomorrow and will look for it for you
GMCNUT is offline
Old 02-26-2016, 09:36 PM   #403
GMCNUT
GMCNUT's Avatar
Originally Posted by 70chevytruck View Post
65 Chevy shortbed.
Need tailgate and trunions.
Need trim on sides of truck for whole truck.
Need badges C10 that go on sides of cowl.
Got any of that?
Thanks.
No spare tailgates, and you don't want used trunions - buy the aftermarket ones - they are cheap and nice. Don't think I have a full set of trim but will dig out what I have. Don't have a set of the 65 style C10 emblems but I think my buddy Randy does - will check and post back
GMCNUT is offline
Old 02-27-2016, 01:53 AM   #404
The Rocknrod
Moderator
The Rocknrod's Avatar
Okay, thanks.
The Rocknrod is offline
Old 03-01-2016, 03:35 PM   #405
AJCK87
Hello,
Do you have a 60-66 passengers side barn door for sale? I am looking for one that is in decent shape to replace the one I have.
AJCK87 is offline
Old 03-02-2016, 09:08 AM   #406
GMCNUT
GMCNUT's Avatar
Originally Posted by AJCK87 View Post
Hello,
Sorry - all I have is a Suburban tailgate and liftgate - no barn doors
GMCNUT is offline
Old 03-02-2016, 04:21 PM   #407
AJCK87
Thank you anyways! Should have a line on a door with one of the other members.
AJCK87 is offline
Old 03-02-2016, 06:41 PM   #408
lasher78
lasher78's Avatar
Do you have a complete fleetside shortbed 64-66?
live like you are dying
lasher78 is offline
Old 03-02-2016, 06:45 PM   #409
lasher78
lasher78's Avatar
And is the panel truck still in tack? Might be intetested in it for parts truck..i also have a 64 panel
lasher78 is offline
Old 03-03-2016, 07:19 AM   #410
GMCNUT
GMCNUT's Avatar
sorry - panel truck is long gone....this is a growing but very old thread so a lot of the first pictured items are gone, but we may have several matching items now depending on what you guys are asking for.
GMCNUT is offline
Old 03-03-2016, 07:57 AM   #411
GMCNUT
GMCNUT's Avatar
I sure do - problem is, there's no way to get you current pictures of it and its mostly in bare metal. I have two pairs of imperfect short fleet box sides too - one set for 60-61 trucks only (has 60-61 trim holes) and one set could be used for anything 60-66. I would recommend someone coming here in person and seeing with thier own two eyes whether or not these parts are useable to them
GMCNUT is offline
Old 03-03-2016, 04:52 PM   #412
lasher78
lasher78's Avatar
I live in southern mo so i would need pics of complete bed to decide if to make drive
lasher78 is offline
Old 03-03-2016, 04:53 PM   #413
The Rocknrod
Moderator
So did you go to that building and see the ashtray?
Old 03-04-2016, 12:22 AM   #414
hayseed71
hayseed71's Avatar
I know this thread has been going on for a few years and i may be out of luck but would you hae any heater parts? Like the door or flapper that the "heat" cable controls on a deluxe heater? Its in the heater box under the hood and controls how much air blows across the heater core. Also do you have any 6 lug aluminum slots? Thanks.
hayseed71 is offline
Old 03-10-2016, 07:23 PM   #415
verdell
verdell's Avatar
Hey GMCNUT,
I'm looking for a passenger side door for a 60-63. Any left over there? I'm about 3 hours away here in MS.
verdell is offline
Old 03-10-2016, 11:43 PM   #416
buick1
Nevermind on the inner fenders! I scored a nice set on Ebay! Thank You Anyway!
buick1 is offline
Old 03-16-2016, 03:43 AM   #417
badherb
badherb's Avatar
"I know this thread has been going on for a few years and i may be out of luck but would you hae any heater parts? Like the door or flapper that the "heat" cable controls on a deluxe heater? Its in the heater box under the hood and controls how much air blows across the heater core. Also do you have any 6 lug aluminum slots? Thanks."
if he does not have a complete heater box I do. will only sell whole thing but let the poster find his if he has one.
For original poster>>>>> I need turn signal bezels for a 60 ugly hood like these
I need both you gots????
badherb is offline
Old 03-16-2016, 08:05 AM   #418
62chevy302
hillbilly
62chevy302's Avatar
I need a core support for 65 c10
-1962 C-10
62chevy302 is offline
Old 03-18-2016, 08:07 PM   #419
64k10burb
64k10burb's Avatar
I would be interested in any 64-66 suburban interior window trim you might have left-thanks
Brian
1969 c-10 (soon to be short bed)
1982 Malibu Wagon-For sale -SOLD
1964 k10 suburban project
1947 Dodge chop top rescue project-SOLD
64k10burb is offline
Old 03-23-2016, 09:12 AM   #420
sampsmit000
sampsmit000's Avatar
do you have any gauge clusters
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline
Old 03-25-2016, 11:29 PM   #421
vetnat
Hi. Passenger door mirror arm? I have a mirror with rectangular head.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline
Old 03-31-2016, 07:48 PM   #422
gfogg
I've got a 66 GMC pick up with dual head lights. All the headlight stuff on the left side is messed up. I need the panel that that the headlight buckets are mounted to. It has the headlight adjusters and retaining springs. I need them as well. I also need the headlight buckets and the retaining rings for the head lightd. Anybody can help please contact me by e-mail gfogg@suddenlink.net or call (928) 680-7709. Oh I tried some repop stuff didn't work. TIA
gfogg is online now Report Post
gfogg is offline
Old 04-02-2016, 01:40 AM   #423
Isaiah92260
Isaiah92260's Avatar
Do have a 60-63 heater dash controls housing/cover. Thank you
Isaiah92260 is offline
Old 04-03-2016, 09:12 PM   #424
urmyboyblue
GMC Nut- are you trying to buy this one?
https://bham.craigslist.org/cto/5489133223.html
If you are, I want to talk to you about the hood. I called but I am 7th in line.
urmyboyblue is offline
Old 05-11-2016, 02:48 PM   #425
Bpilcher72
Bpilcher72's Avatar
still got 2 good doors to fit a 61?
Bpilcher72 is offline
Closed Thread
