Old 09-05-2017, 03:54 PM   #401
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Got me some new parts. 44mm wastegate from VS Racing (aka Tial knock off) and a bellow.
Got my cross over done. Need to cut my bellow in but am waiting until I get exhaust gaskets.
Cut in my wastegate. The tape is actually backwards. I need to flip it around and grind it to fit the hole (just there for picture purposes).
David
Instagram: myfabguy
Old 09-05-2017, 07:28 PM   #402
HunterRotten
HunterRotten's Avatar
That really sucks with photobucket, I was looking forward to scrolling through. What is here to see is some very nice content, though!!
HunterRotten is offline   Reply With Quote
Old 09-08-2017, 05:14 PM   #403
tinydb84
tinydb84's Avatar
Thank you sir. I still have the pics (just not uploaded) so if there is something specific you want to see let me know.
David
Instagram: myfabguy
Old 09-08-2017, 05:17 PM   #404
tinydb84
tinydb84's Avatar
Cut the wastegate pipe to fit
Got the wastegate welded up.
David
Instagram: myfabguy
Old 10-16-2017, 09:10 PM   #405
tinydb84
tinydb84's Avatar
Still trying to get the rear done
Some welds
Added a brace to keep the bags from twisting into the center. Going to tie the rear of the triangle back to the frame.
David
Instagram: myfabguy
Old 10-17-2017, 12:23 PM   #406
daddyjeep
daddyjeep's Avatar
I really need to start playing with a TIG.
Glad to see you are making some progress.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 10-25-2017, 04:39 PM   #407
tinydb84
tinydb84's Avatar
Thank you sir. Life keeps getting in the way. You know how it is.
Had some more fun welding last night.
Almost done. Need shock mounts and a way to mount the gas tank down.
David
Instagram: myfabguy
Old 11-06-2017, 03:22 PM   #408
tinydb84
tinydb84's Avatar
Added in some bars. This should help support the gas tank and the rear of the bed.
I regret not tig welding in my watts link. The mount looks like crap next to the tubes. Blah...
David
Instagram: myfabguy
Old 11-06-2017, 07:25 PM   #409
rusty76
rusty76's Avatar
Nice
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-06-2017, 10:13 PM   #410
Joe Pass
Joe Pass's Avatar
Yes,,,real nice
Joe Pass is offline   Reply With Quote
Old 11-07-2017, 05:52 PM   #411
tinydb84
tinydb84's Avatar
Thanks guys.
Quickly painted the frame. I am redoing someones suspension this weekend and wanted to make sure it didn't rust since it is supposed to rain and I will have it out in the driveway.
David
Instagram: myfabguy
Old 11-12-2017, 07:28 PM   #412
Hankster
Hankster's Avatar
Dang, things starting to shape up.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 11-20-2017, 01:48 PM   #413
tinydb84
tinydb84's Avatar
Slow and steady! I'm trying to juggle a few side jobs, my brother's Nova, and work on my house but it will get done eventually!
David
Instagram: myfabguy
Old 11-20-2017, 01:49 PM   #414
tinydb84
tinydb84's Avatar
Rolled my truck into the driveway in order to do some work on another truck. Took a few pics.
I really need to change the oil pan so I can lay out properly.
David
Instagram: myfabguy
Old 01-31-2018, 07:18 PM   #415
tinydb84
tinydb84's Avatar
Havent done too much work to the truck. Here are a few updates.
Upper shock mounts. Look a bit weird but gave me the travel and angle I wanted. Plus they are stock shocks so replacements can be found easily.
Made some bumpstops
Did half my gas tank mounts
David
Instagram: myfabguy
Old 02-05-2018, 02:30 PM   #416
tinydb84
tinydb84's Avatar
Got my gas tank all mounted up
Boxed in my upper shock mounts. Forgot to get a finish welded pic.
David
Instagram: myfabguy
Old 02-05-2018, 07:03 PM   #417
crakarjax
crakarjax's Avatar
What do you use to cut and clean those metal pieces? Looks really nice!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-05-2018, 07:41 PM   #418
tinydb84
tinydb84's Avatar
The shock mounts were purchased but everything else is done with a sawzaw and flap disc on an angle grinder.
David
Instagram: myfabguy
Old 02-05-2018, 10:29 PM   #419
Joe Pass
Joe Pass's Avatar
nice.......
Old 02-05-2018, 11:27 PM   #420
crakarjax
crakarjax's Avatar
So for the shock mount boxing bracket with the curves, you cut that with a reciprocating saw? Or did it come with a kit. I'm wondering how you get the nice curves in your pieces
Old 02-06-2018, 01:36 PM   #421
tinydb84
tinydb84's Avatar
I made the piece to box them. Just an angle grinder with a flap disc. It takes some practice but you can also use a finer grit to make curves without digging into the piece.
Michaels craft store sells a piece of plastic that has a bunch of curves of different radiuses that you can use to trace out the curve. I can post a picture later today if you want.
David
Instagram: myfabguy
Old 02-08-2018, 01:55 PM   #422
daddyjeep
daddyjeep's Avatar
It is amazing what we can accomplish with minimal tools with some patience and determination.
04 1500 crew cab
Old 02-20-2018, 01:32 PM   #423
tinydb84
tinydb84's Avatar
My truck is being built on frustration, determination, and harbor freight
David
Instagram: myfabguy
Old 02-20-2018, 01:32 PM   #424
tinydb84
tinydb84's Avatar
Finished the shock mounts
Brazed on my AN fittings to my sending unit
David
Instagram: myfabguy
Old 02-20-2018, 01:34 PM   #425
tinydb84
tinydb84's Avatar
Built a battery box. Still need to figure out the hold downs.
[url=https://flic.kr/p/GoQGF9]
20180219_182744
David
Instagram: myfabguy
