Old 02-11-2022, 10:09 AM   #401
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
Originally Posted by Jason 56 View Post
Dash is welded in. No problem getting the vintage air unit in. I have a good start on the bed wood.
Jason, your dash/console looks great. nice work
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 02-11-2022, 10:12 AM   #402
my56chevytruck
Re: My 56 build
Spent some time in the basement today. Outside temperature was only in the single digits so not a good day to heat the garage. So I got all the bed wood stained. Next is the clear.
wood stained color is great
1940 Ford Dlx Coupe
1969 Mach1
Old 02-12-2022, 10:05 AM   #403
Jason 56
Re: My 56 build
Thanks, I’m hoping it looks good against the hermosa blue
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 02-13-2022, 09:31 PM   #404
Jason 56
Re: My 56 build
A picture of the wood finished. I also plan on using some matching wood in the interior.
Old 02-13-2022, 09:40 PM   #405
Jason 56
Re: My 56 build
Fabricated some cup holders. I figured this would take a couple hour. I only underestimated that by about 6 hours. The first one took 5 attempts. They have a slight taper which made it more difficult.
Old 02-13-2022, 09:48 PM   #406
Jason 56
Re: My 56 build
Also installed my new seat belts. For the shoulder anchor I welded a nut to a 3x6” 14 gauge plate. Then fished them up with some welding wire and spot welded them in place. Worked well!
Old 02-18-2022, 12:18 PM   #407
tdishon
Re: My 56 build
Great build! Been enjoying this thread.
Current project: 59 Apache with 2012 Corvette drivetrain
Jeep Trackhawk(beast)
tdishon is offline   Reply With Quote
Old 02-18-2022, 01:33 PM   #408
6DoF
6DoF's Avatar
Re: My 56 build
i appreciate the welded n smoothed cup holders. :drool:
6DoF is offline   Reply With Quote
Old 02-18-2022, 09:21 PM   #409
Jason 56
Re: My 56 build
Thanks, yours is looking great also.
Thanks, Gotta have some to put that beverage on a long road trip
Old 02-18-2022, 09:36 PM   #410
Jason 56
Re: My 56 build
Little more progress today. Working on the interior door panels. Welded a tab to the door to anchor the handles to. You can see the plate I put in the handle in the second picture that bolts to the tab. Also finished installing the door slinkys (as I call them) for the door wiring.
Old 02-21-2022, 10:22 AM   #411
my56chevytruck
Re: My 56 build
you are one crafty dude, good job Jason.
1940 Ford Dlx Coupe
1969 Mach1
Old 02-22-2022, 08:49 AM   #412
Jason 56
Re: My 56 build
Thanks, son of a commercial fisherman… Jack of all trades, master on none
Old 02-22-2022, 09:06 AM   #413
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 56 build
Very nice work! Those door pulls on the panels are going to be sweet.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-26-2022, 10:05 PM   #414
Jason 56
Re: My 56 build
Decided to weld in a matching dimple for the push button start. Harvested one from a section of the dash I cut out. Also spent hours tweaking the passenger door. When the doors didn’t fit from the factory to begin with, it’s amazing how difficult they are to fit properly. Hopefully going to prime everything else tomorrow before I start laying filler.
Old 02-27-2022, 11:09 AM   #415
mrbuck
Re: My 56 build
Are the two big hole next to the gauge cluster for ac vents? Looking awesome !
Bucks build thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=825476
mrbuck is offline   Reply With Quote
Old 02-27-2022, 04:02 PM   #416
Jason 56
Re: My 56 build
Correct… they are AC vents. Here’s a picture of what they look like installed.
Old 03-04-2022, 08:32 PM   #417
Jason 56
Re: My 56 build
One last thing before I prime. I haven’t been happy with the hidden latches in the tailgate. The way they stuck out, I know I or someone else would chip the paint where they made contact. So I moved them further in and built a small ramp so the gate latches when I close it. Problem solved
Old 03-05-2022, 06:32 AM   #418
Dieselwrencher
Re: My 56 build
Very nice work and attention to detail!
Ryan
Old 03-05-2022, 09:15 AM   #419
Father&son56project
Re: My 56 build
Good catch on the latches. Those were definitely a future paint chip waiting to happen! Those ramps blend nicely.
Father&son56project is offline   Reply With Quote
Old 03-05-2022, 10:23 AM   #420
57FleetsideC4
Re: My 56 build
Nice idea. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-05-2022, 10:43 AM   #421
dsraven
Re: My 56 build
will you have a rubber bumper for the gate to rest against when closed?
you could install a "striker slipper plate" of stainless to cover the painted ramp you made, then the rubbing area on the ramp would always look good because there would be no paint to scratch as the latch striker pin moves up to the latch hole. a piece of teflon may also work well. just a thought. something you could screw on so it is replaceable.
nice work so far, great attention to the little details.
Old 03-05-2022, 03:06 PM   #422
Jason 56
Re: My 56 build
Originally Posted by 57FleetsideC4 View Post
Nice idea. Steve
Thanks guys. They turned out pretty good!
Old 03-05-2022, 03:09 PM   #423
Jason 56
Re: My 56 build
Thanks DS. Definitely, stainless is a good idea. I was going to come up with something like that.
Old 03-08-2022, 07:20 PM   #424
slammed57
slammed57's Avatar
Re: My 56 build
lookin great, awesome idea on the latch catch
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 03-09-2022, 12:41 AM   #425
Jason 56
Re: My 56 build
Thanks slammed. You must be getting close to painting. I’m starting to lay body filler this weekend. Today I primed everything I had left in bare metal. Here’s a couple pictures
