Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-02-2007, 01:15 AM   #426
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Originally Posted by 1LoC10 View Post
Originally Posted by FRENCHBLUE72 View Post
You dont want the ones with the little lights in em I had em and hated them..... Little lights were not bright enough..
Good info guys, thanks.
Originally Posted by va_tlc View Post
i always like things better if someone else, doesnt have one like it...
I totally agree
Originally Posted by method2mymadnes View Post
There is only one mod that u left out of ur list, another door on the driver's side
That would be cool, huh? What about adding the 4th door and making both rear doors suicide? Imagine how cool that would look at a show with all the doors open and the rear hatch up!
Frizzle Fry is offline   Reply With Quote
Old 09-02-2007, 10:24 AM   #427
Rokcrln
Rokcrln's Avatar
Sounds good, get to it!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-02-2007, 11:26 PM   #428
method2mymadnes
method2mymadnes's Avatar
Now we're talkin!!!!!!
87% of all statistics are made up on the spot.
method2mymadnes is offline   Reply With Quote
Old 09-03-2007, 12:09 AM   #429
smbrouss70
smbrouss70's Avatar
Well, you might as well do LFD's forward-tilt hood too!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-03-2007, 01:04 AM   #430
Frizzle Fry
Originally Posted by smbrouss70 View Post
Well, you migt as well do LFD's forward-tilt hood too!
Link Please
Old 09-03-2007, 01:15 AM   #431
smbrouss70
smbrouss70's Avatar
Here you go!
LINKY
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-04-2007, 12:32 AM   #432
Frizzle Fry
You see what's happening here? This was supposed to be a "could have been factory" type build. Then I decided the hatch "could have been" made one-piece from the factory (minus the gas-struts). Then I thought since I already put a 476 in it that the "could have been factory" would apply only to the body. So I went ahead and notched the rear and bagged it. Now I might just have to throw that whole concept out the window
We'll see. Things could change a lot when "Tubby" gets kicked out of the garage for the 61 to go in...
Old 09-05-2007, 01:01 PM   #433
Frizzle Fry
Met up with a couple board members at the PIR cruise-in last week. That's Brad's 67 shorty converstion next to Tubby (thanks for the pics Brad):
Old 09-06-2007, 12:58 PM   #434
Frizzle Fry
Ok, some real work...
I finalized the routing of all the air, fuel, and brake lines. Before clamping everything in place I covered the fuel and air lines with nylon braided sheathing similar to what's used on aircraft wiring.
I figured out where I wanted to put the floor cross-sill and cut holes for the body-bushings as can be seen in the last pic.
Then I shortened the cross-sill (only one side had to be cut bc the other side was already short to make room for the spare tire well), and notched it for the tank.
All of this will be blown apart again for POR-15'ing
Then I cut the temp ply-wood to fit and bolted it in.
Old 09-06-2007, 01:05 PM   #435
Frizzle Fry
...and as can be seen in the last couple pics, I finally got around to building the drive-shaft tunnel.
First I used half of a 5" OD 1/4" wall tubing section (2.5" wide) to reconnect the floor brace/seat mount.
Then I built the tunnel in two sections.
Still need to cover the frame cut-outs, but I can tell you that floor section around the tunnel is STRONG!
Old 09-06-2007, 02:14 PM   #436
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Good Job on The Tunnel & Sheathing, You at one Time said you were Going to Do the Rear Floor similar to the Pick up with Oak Strip's, Is that still Planned? If So, What are your Plan's to Cover the Frame rework area?
Thanks Again For The Inspiration, Rick
toomanytoyz is offline   Reply With Quote
Old 09-06-2007, 03:59 PM   #437
Frizzle Fry
Yep, that's still the plan. I already have the wood kit and chrome strips But I'll probably just mock it up with the wood kit (it's pine) then have nice pieces made in teak or Ipe. I need to move the rear tubs up a few inches to make room for the 22's. Then I'll make a notch cover out of metal that goes all the way across from tub to tub. It'll either be painted body color or covered to match the inner panels (tan vinyl like the kick panels or...?).
Old 09-07-2007, 12:22 PM   #438
Frizzle Fry
Made one of the frame covers/floor sections and burned it in. The other side should be cake now that I have a good pattern.
Old 09-07-2007, 12:39 PM   #439
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Getting close, and it's looking awesome! When done, are you going to go back to the same colors it was before it became a hoe?
Oh, and I love the avatar pic too!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-07-2007, 01:49 PM   #440
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeeeeeeeeet
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-07-2007, 02:09 PM   #441
Frizzle Fry
Hey man, just because she's promiscuous doesn't mean she's a hoe
Ya, I'm going with the scheme on page one/post #1, but with white also below the lower trim. I need to re-install PS and do another render.
Thanks man!
Old 09-07-2007, 03:23 PM   #442
berencam
berencam's Avatar
great thread, i envy you guys that have a shop to do this kinda thing in, im 20 and still livin out of an apartment so 1 day projects is what im limited to. cant wait till i get a house with a BIG GARAGE! then my truck will go under the knife to get some much needed tcl... untill then i can droll at your projects.
berencam is offline   Reply With Quote
Old 09-08-2007, 12:03 AM   #443
Frizzle Fry
Take it all in man! I can't tell you how much I've learned from this site... and still learning. I know I woudn't have done half this stuff without it!
Old 09-08-2007, 12:30 AM   #444
glock35ipsc
Had it not been for this place, I probably would have towed mine out back after it got hit. It would probably still be sitting out there too! I learn something new almost every day here.
On the other hand, it can be a bad thing too. My truck isn't just another truck anymore. And Frizz's burb, well........ it turned into a hoe!
Lookin good Frizz!!
Bob
Old 09-08-2007, 07:14 AM   #445
L0WRIDE
L0WRIDE's Avatar
nice work as allways Mike
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 09-17-2007, 04:01 PM   #446
Frizzle Fry
Been working on making room for those 20's! I posted this little project over in suspension.
Old 09-17-2007, 04:25 PM   #447
glock35ipsc
That looks great Frizz! I'll bet most people will never notice it. On one hand it kinda sucks when people don't notice things you have spent a lot of time on, but on the other it tells you that you accomplished your goal of keeping it stock looking. Which in a way is just as rewarding. Great work!
Bob
Old 09-24-2007, 04:43 PM   #448
ksucatz
Suppose to be workin........
ksucatz's Avatar
Thumbs up Re: Joined the Short Wheelbase Club *69 Tahoe Project*
FF. I have been away from the boards for a while, but came back and saw the awesome work you have done. Maybe I can use the final image to convince the wife to get rid of the Trailblazer and make a Tahoe. Might be neat to stuff the guts of the TB into a Tahoe.
You could always run the wheel tubs across to cover the notch, then you could go 335 or bigger in the rear. Might need them to handle the power!!
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline   Reply With Quote
Old 09-24-2007, 10:59 PM   #449
Frizzle Fry
Thanks Brent.
Trailblazer interior would probably work really well. I wonder if GM would let you use an On-Star subscription if your transferred the system over...
I haven't posted much on this thread lately but I haven't stopped working. I built a leaf guard, I'm modifying my 68 fenders, and I spent two days removing undercoating from the 68 hood (what a PITA!).
So my next big milestone is putting the 68 clip on.
Old 09-25-2007, 05:37 PM   #450
Frizzle Fry
Here's the 68 hood. I think I'd rather buy a new one than do that again...
Took the braces off and went through it with a wire wheel and cup to be sure ALL that garbage was removed. This way I can chrome them if I want to and bolt em back on with some nice SS hardware. Next step is solvent!
15 lbs of undercoating:
