Old 01-08-2013, 10:04 PM   #426
ryanroo
ryanroo's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Originally Posted by Mattman2010 View Post
Well last night I was able to make my trip to pick up a dana 60.
D60. Gears are flawless all that needs fixed are the u-joints.
Love me some dana 60! have fun with those knuckle joints, they can be a PITA. be careful when you hammer or press out the caps. i have seen times when they are in so tight that it will bend the ears of the axles.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-08-2013, 10:59 PM   #427
Mattman2010
Mattman2010's Avatar
Ryan
Yeah Im glad I finally got one. Been wanting one sense I got the truck two years ago! That does not sound fun at all. Maybe I should pay a shop to do it. That way if they mess it up its their problem
Got the cab off tonight.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-09-2013, 12:06 AM   #428
ryanroo
ryanroo's Avatar
if you have access to an arbor press, you can load them with the press and tap the axle ear with a hammer. small taps with the cap under pressure will pop it free usually. they are pretty easy if you use the hammer. ive done a few that had an a lot of pressure on them when they pop and it makes a really sweet bang
Ryan
72 K20 12v build
Old 01-09-2013, 06:37 PM   #429
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice score on the D60! Or you can use a U-joint press if you have one. A couple more big parts and you'll have it near driving.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-09-2013, 06:47 PM   #430
Mattman2010
Yeah, where are these parts at? I have a big ass vice and sockets. That what I've done with other ujoints.
Build Thread
Build Thread
Thread
Old 01-09-2013, 06:51 PM   #431
Dieselwrencher
Craigslist with your personals ad I'm guessing.............
Ryan
Old 01-09-2013, 08:29 PM   #432
Mattman2010
Got the transmission cross member all finished up and stuck the drive train in for mock up so I can finish some stuff on the frame.
Build Thread
Build Thread
Thread
Old 01-09-2013, 08:46 PM   #433
Devillusion
Devillusion's Avatar
jealous
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 01-14-2013, 02:09 PM   #434
Mattman2010
The frame sat level before I put the dana 60 in the truck. So it raised the front some when I put it in. So i decided to do a shackle flip on the rear of the truck. I used the rear front mounts that where on the frame when it was 2wd. I will be adding some extra bracing to them from the bottom of the frame.
Build Thread
Build Thread
Thread
Old 02-06-2013, 04:30 PM   #435
Mattman2010
Well its been a while sense I have worked on the truck. But I finally got some parts thinks to DieselWrencher.
Power steering pump and vacuum pump
Also got a steering arm from him as well that looks like it will work perfect for cross over.
Rope is the angle of the drag link
I also got some parts for my goose neck hitch. Using a B&W ball and a 2.5" receiver.
Also picked up some trailer ubolts to use for the safety chain hook ups.
Build Thread
Build Thread
Thread
Old 02-06-2013, 05:08 PM   #436
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks good Hombre. Are those welfare parts?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-06-2013, 05:13 PM   #437
Mattman2010
Yeah those are. Part of the Ryan's Welfare Plan.
Build Thread
Build Thread
Thread
Old 02-06-2013, 09:27 PM   #438
ryanroo
ryanroo's Avatar
You may consider a block for the steering arm, or a raised arm. that thing is going to have some bumpsteer at that angle
this is my jeep, and it still has bumpsteer
better toss in one after the Howe!
im looking forward to seeing how you do your gooseball
ryan
72 K20 12v build
Old 02-06-2013, 09:49 PM   #439
Mattman2010
Well the tre's really should make it more level when I finally do buy that stuff
Build Thread
Build Thread
Thread
Old 02-06-2013, 10:03 PM   #440
meatwagon83
meatwagon83's Avatar
you wanna git rid of that tailgate panel and those door panels, im having a hard time coughing up the 400 lmc wants for them!!
meatwagon83 is offline   Reply With Quote
Old 02-08-2013, 08:52 PM   #441
Mattman2010
ryan
Ryan, what kind of steering arm do you have on your jeep? The one I got from DieselWrencher didnt come with any kind of new cap or anything. To make it work I put a spacer in the cap that was the same height of the steering arm. If I put a block under the steering arm I am not sure what I would do for the cap.
As of right now I am keeping everything I have. The tailgate band might get painted black and stuck back on. And I am not sure what door pannels I am going to use right now.
Work on the truck some more today. Started out with a cardboard template of the cross member and finally made it into steel.
Also went ahead and cut the cross members that my goose neck will be mounted to.
I think I am going to go ahead and box the frame all the way to the back once I get the cross members for the goose neck and also figure out how im going to mount my fuel tank in the rear, probably going to use some 2x4x1/4 to make cross members for the fuel tank. Might as well go with the beef on this truck.
Build Thread
Build Thread
Thread
Old 02-08-2013, 09:08 PM   #442
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
If you get the two burb or blazer (I think they are the same) rear cross members you could cut them to width and weld them in once its all boxed.
Tony
Old 02-08-2013, 09:14 PM   #443
Mattman2010
Why use small stock cross members when I can add beef? There might even be a 1/4" skid plate lol
Build Thread
Build Thread
Thread
Old 02-08-2013, 09:20 PM   #444
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh I just mean use those for holding the tank, I would still do cross members like what you have for your gooseneck.
Tony
Old 02-08-2013, 09:29 PM   #445
mrolds88
Hitch looks nice. Only mod I think I would make would be to turn the outer tube 90 degrees so the hole goes side to side. That way you could weld the pin onto a rod to run out to the framerail. That way you dont have to crawl under to take the ball out.
mrolds88 is offline   Reply With Quote
Old 02-08-2013, 10:04 PM   #446
Mattman2010
That's the plan, I just had it like that so it wouldn't fall. My plan is to make it work just like a b&w just a lot more beef added to it
Build Thread
Build Thread
Thread
Old 02-08-2013, 10:46 PM   #447
ryanroo
ryanroo's Avatar
i made my own springless caps for the jeep. the style you have i think is intended to be bolted over the stock stamped cap. i would recommend that you only run it until you can get the style that replaces the cap and has tapered holes for the studs.
Cross members look good!
72 K20 12v build
Old 02-08-2013, 11:06 PM   #448
Mattman2010
I thought it would fit over the stock cap as well, but it wouldn't. Ive been thinking about making a new cab that I would just weld to the arm and also have the arm machined with tapers and get some arp studs.
Build Thread
Build Thread
Thread
Old 02-09-2013, 12:25 AM   #449
ryanroo
ryanroo's Avatar
That may be what was intended. high country machine built or still builds an arm that has a machined weld on cap for the spring. i had forgotten about that until you mentioned it. i have one somewhere that i had before i built the springless caps for the jeep.
that may be what you have, a arm that needed a cap. if you make a cap, be sure to get it very close in depth to the stock stamped one. the tension on that spring is what holds the knuckle together and if it is too loose, its easy to get some wicked deathwobble.
72 K20 12v build
Old 02-09-2013, 12:44 AM   #450
Mattman2010
Yeah I have thought about cutting the stock one down 1" because I dont really like the spacer in the spring. I have not really fully figured out how I am going to do this. Id hate to buy a new arm to make it work.
Build Thread
Build Thread
Thread
